Question about Onkyo TX-8211 Receiver
Need Power Board
I need a power supply board for this unit any know of any sources.
    President:
  • 3,130 Answers
Try here first http://www.onkyousa.com/
Posted on Aug 06, 2006
47 LG tv with blown power board - need to identify replacement options
https://www.ebay.com/itm/Vizio-0500-0412-1000-Power-Supply-/292401650643
Feb 12, 2018 | LG Televison & Video
Is the Backlight inverter and the power supply unit in the same board for this tv?
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
http://electro-medical.blogspot.com/
May 18, 2016 | Televison & Video
Computer power supply does not work
Need to know how old a computer it is as over the years the power supplies' use different methods of starting.
On newer computers the power supply is connected to the mother board by a 20 or 22 pin connector. The power button on the computer is just a momentary switch to start the computer. Make sure the large connector is firmly seated in the mother board. If you are comfortable with doing that have someone else check it. You do not want to damage the connector or mother board. You need to have some sort of anti static device conntected to your body to avoid any static discharge that could damage the mother board.
Feb 09, 2014 | Antec TruePower Quattro 850-Watt Power...
Dead set (no indication lights coming on when I push the power button.
Hi Gwendolyn,
First of all thank you for posting your question here at Fixya.
I'm assuming here that you're TV is a Vizio L32 HDTV.
My initial advice is to ensure that the AC source(outlet) is live. Please plug the unit to a known working outlet, if you are using a surge protector, directly plug the power cord of the TV to the outlet to confirm that the AC source is not the issue here.
If you've confirmed that the AC source is not the problem, then the fault is inside the TV and most likely the power supply. Most of the TV with a dead set symptoms that I've encountered is a power supply issue but of course needs to be confirm.
If your unit is not under warranty period (if so, avail it because the manufacturer will fix it for free, opening the rear cover will void the warranty), open the back cover, check the internal fuse of the power supply board, this is near where the AC power cord's directly connected. Check its continuity using the multimeter/ohmmeter, if you found it open, replaced it with a new same current rating that is printed on its body itself. Sometimes internal fuse fail due to voltage surge/flactuation, aging, etc, replacing with new one resolve the issue, however if the fuse blow again, this is an indication of more serious problem on the power supply board, it needs to replaced the entire board.
If the fuse is intact, you have to measure the output voltage of it through connector J1 (pin 9,10,11). You should be getting 5 Volts. If there's no voltage at these pin, you're power supply board is dead, replaced the entire board. If the 5 volts is present, replaced the main board.
I've provided you a links for the power supply board and mainboard below.
Vizio L32 Power supply board
Vizio L32 Mainboard
Let me know if you need further assistance.
Rating and feedback are highly appreciated!
Hope I helped you.
Good luck and take care!
Have a nice day!
Kind Regards,
Jdvillanueva
Dec 13, 2011 | Vizio L32 32 in. LCD HDTV
My KDF-50WE655 will not turn on. No power light, there is power going in to tv.
Hi kevin,
If there's no led light at the front panel of the set, this is an indication that the problem is in the power supply board (G1 board), I'm assuming that you've confirmed that the AC source/outlet is live. To resolve this issue you must troubleshoot the G1 board board to isolate the faulty parts. If you don't have necessary tools and test instruments and can't troubleshoot the unit yourself, I would advice you to replace the entire G1 board or seek for an assistance of a qualified TV Technician.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Nov 07, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
Unit hit by lightning. Replaced main fuse. Power supply works. Replaced main control unit. Both green and amber lights blink constantly
How many times does the standby light blink between each pause? Its a self-test diagnostic that will pn-point us to the source of the problem so please let me know.
Aug 18, 2011 | Sony KDL52NX800 52 in. TV
Unit is dead I need power supply schematics
U will not find schematic,the tv corporation don't release them.Just take the tv aparts.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Just compare the power supply board in ur tv and the website that selling the power supply board.The picture look alike,ask the seller questions.Just buy and replaced it.U know how to solders?Just searches around the power supply board for those bulges and puff up capacitors.Replaced these capacitors will get ur power back.Most just reqiure replaced these capacitors to get the power back.
Apr 21, 2010 | RCA L32WD26D HDTV/DVD Combo
Unit will not Power Up.
Terry, I had the same problem. Its a small capacitor on the power board labelled 'C16'(right in the middle of the board) its value is 16volt 100uf.
I also changed the biggest one on the board as well( 450volt 270uf @85deg). The big one was sourced through RS components @£5.14, the other I got through a maplins store for the grand sum of 13 pence.
Both are quite easy to change if your not adverse to taking the unit apart. (Just remember where all the leads plug in).
A torx T10 screwdriver, and soldering iron is all you need.
Jun 03, 2009 | InFocus ScreenPlay 5700 Multimedia...
Lightening struck my Xbox original
Replacing the power supply inside the xbox has always worked for me. If you want a cheap power supply buy one of ebay. Make sure you buy the right model. There are three different types. 1.0-1.1, 1.2 - 1.5 & 1.6 power supply. To tell which one you have look at the wire where it plugs into the motherboard. If it's a single row of pins, then you need the 1.0-1.1 power supply. If it's a double row and has an orange wire anywhere on it then you need the 1.2 - 1.5 board. No orange and you need the 1.6 board. You can also find a picture here: http://www.llamma.com/xbox/Mods/xbox_power_supply_conversion.htm
on how to distinquish the three apart. You can also fork out the extra $10 bucks or so by buying a universal power supply board. Replace the board and I'll guarantee you that you will get some more play time out of the system.
Mar 30, 2009 | Microsoft Xbox Console
Onkyo TX-8211 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
