Question about Husqvarna Garden
How to adjust husqvarna 254 carburetor?
The question is how should be adjusted the carburetor?
4 Suggested Answers
  • 211 Answers
SOURCE: Carburetor problem
Hi
High speed H=3\4 turn
Low speedL=1 1/4 turn
idle speed t adjust accordingly.
regards savumihai71
Posted on Dec 14, 2008
  • 120 Answers
SOURCE: husqvarna chainsaw carburetor adjustment
Find the 2 screws. There will be a (h) high and (L) low. These are for hig rpms and low rpms. First tighten the screws. Then unscrew them about 1-1/4 turns. Then start the saw and let it warm up. Start with the high rpms first pull the trigger all the way then adjust the screw in 1/8 turns either way until it is running good at high rpms. Then work on the L rpms. Get the saw to idle then pull the trigger, there should not be any hesitation when going from L to H rpms. Just adjust the low same as the High. They have to work together so if the high is good and the low is not just right turn the h a small amount. If you have any more questions let me know
Posted on Jun 20, 2009
  • 243 Answers
SOURCE: I have a Husqvarna 455 rancher I have been trying
husqs are sensitif for dirt in carb and fuelsystem clean everything real good. airfilter, carb, tankfilter. after building together make sure it can not take false air. start with both screws closed and open for 360 degrees. after that start adjusting. compression must be ok. saw must hang on cord and not go down. good luck lot of work.
Posted on Feb 11, 2010
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
Need tool for adjusting air fuel ratio for husqvarna 235 chain saw
It should be a spline tool. It is the most common one.
Genuine Poulan Weedeater Part 530035560 Carb Adjusting Tool
If you work a lot 2 cycle trimmers and chainsaws you might buying the set of four adjustment tools.
2 Cycle Carburetor Adjustment Kit Includes 530035560
Nov 07, 2014 | Husqvarna Garden
How can i adjusting the throttle on a husqvarna ?
Depending on the model Husqvarna, there is an idle adjustment you can make. However, Federal Government and EPA will not allow you to change the settings on the carburetor's High and Low needle settings. This must be done by a certified Husqvarna dealer.
Aug 09, 2014 | Husqvarna Garden
Husqvarna problems
If spark is ok then I would say the carburetor is the likely problem or the fuel is not entering the engine. Something like the following instructions might help.
How to Adjust Husqvarna Carburetor eHow
Look at this manual for model 51 carburetor adjustments.
http://www.getsaws.com/PDFs/w9600001.pdf
Aug 06, 2014 | Husqvarna Chain Saw Models 51, 55
How do I adjust the air gap on the ignition coil
The best way is with an air gap tool. Most Husqvarna saws run a 0.3 mm or .012" air gap.
May 01, 2014 | Husqvarna Ignition Coil 55 257 245 51 254...
My husqvarna yth2348 riding mower is havering carb issues not getting fuel
Here are a few tips to look at, I would first check your inline fuel filter to make sure its not clogged up. See Page 26 of the Manual for additional help.
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_NAen/HUSO2010_NAen_YTH2348_532441716.pdf
PROBLEM
Will not start
CAUSE CORRECTION
1. Out of fuel. 1. Fill fuel tank.
2. Engine not "CHOKED" properly. 2. See "TO START ENGINE" in Operation section.
3. Engine flooded. 3. Wait several minutes before attempting to start.
4. Bad spark plug. 4. Replace spark plug.
5. Dirty air filter. 5. Clean/replace air filter.
6. Dirty fuel filter. 6. Replace fuel filter.
7. Water in fuel. 7. Empty fuel tank and carburetor, refill tank with fresh gasoline and replace fuel filter.
8. Loose or damaged wiring. 8. Check all wiring.
9. Carburetor out of adjustment. 9. See "To Adjust Carburetor" in Service Adjustments
section.
10. Engine valves out of adjustment. 10. Contact an authorized service center/department.
Apr 15, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Carberator adjusting
Many new units have a very limited adjustment possibility. This is due to EPA regulations. If the saw is hard to start, it may need to be richened up a little. Your dealer should have proper tool to adjust.
Apr 14, 2014 | Husqvarna 36 41 50 51 55 136 141 154 254...
Husqvarna Model # 246 Chain Saw: starts but will not maintain on idle. How do I adjust low speed?
I recommend cleaning the carburetor, air filter, and replacing the diaphram in the carburetor before tweeking the adjusting screws.
Aug 12, 2011 | Husqvarna Garden
Husqvarna chainsaw carburetor adjustment
Jun 11, 2009 | Husqvarna Forest & Garden No.967012396 345...
Carburetor problem
Hi
regards savumihai71
Dec 14, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
1,039 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
