Question about Cerwin Vega LS-15 Speaker
Loudspeaker Repair or Buy New Replacement?
I have a pair of 8" loudspeakers in my home speaker system that are producing no sound. I am considering buying replacement, but they are quite expensive from the manufacturer. I see there are companies on line that will repair them for less. Any opinion on whether a repaired speaker is just as good as the original? OR, am I better off to just buy the replacement from the manufacturer at a higher cost? They are actually Martin Logan Ascents, but the Product description below would not take that info.
    Problem Solver:
  • 11 Answers
Here is a site that offers great deals on all varieties of drivers. I have ordered many times from them before and their customer support is very helpful. Hope this helps,
Hortona
http://www.parts-express.com/
Posted on Mar 25, 2009
    Problem Solver:
  • 12 Answers
I have tried the repair thing before. They can be repaired the only problem is they dont seem to hold up as good or for long. I found it better just to replace speekers with new ones
Posted on Oct 23, 2008
Where is sound mute btton
What is the brand and type of the laptop?
Oct 19, 2014 | Computers & Internet
No sound in speakers, do i need new speakers or is it something i can fix?
Try a pair of headphones. If you can't hear any sound it's not the speakers. If you can hear sound, it still might not be the speakers. As sometimes headphone sockets which cut the speakers off when headphones are plugged in, can go faulty. To test any loudspeaker connect a 1.5 volt battery accross it's terminals for a few seconds. It should POP.
Feb 27, 2013 | Audio Players & Recorders
My amp isn't producing any sound. It works when headphones are in but that's it. Please help
The headphones socket is on the preamp stage - it works so the problem must be after the pre-amp.
Do you get any sound at all from the speakers (hiss or perhaps a click) when you turn it on?
If yes it is an amplifier problem.
Here are some possible causes
  • A wire has come off the loudspeaker - easy to fix
  • Speaker protection fuse has blown - small glass fuse mounted on main amplifier chassis - replace with correct rated and type of fuse (note some of these are 'slow' blow type - important that you get the right one)
  • faulty component in the main amplifier stage - requires attention from qualified repairer
  • Loudspeaker burnt out - this can be tested by connecting another speaker across the terminals of the built in speaker.
  • The headphone jack socket automatically disconnects the loudspeaker when phones are plugged in - it could be that the contact in the headphone jack socket is bent and not re-making contact when the headphones are unplugged.
Feb 26, 2011 | Orange Crush 15r 15w Reverb Guitar...
M-audio av20 right speaker has no sound coming out of it at all...
To troubleshoot the problem start with the bit that is working - the left speaker.
  1. Unplug the input leads on the back of the left speaker and swap them round.
  2. If sound now comes out of right speaker and not the left the problem is with your sound source (computer, IPOD or whatever) or the connecting cable is faulty.
  3. If there is still no sound from the right speaker try turning the volume control knob up and down quickly several times - does this produce any sound from the right speaker? Sometimes the electrical contacts get dirty and this can help clean them.
  4. Turn the speakers off using the volume control knob. Disconnect the speaker wire for the right speaker from the OUTPUT on the left speaker (push the red and black tabs downwards and gently pull the wires out. Find a small 1.5 volt battery (an AA or AAA size will do nicely) and touch the bare ends of the speaker wire briefly on the battery terminals. If you hear a slight crackling sound the wire and the speaker are okay and the problem is in the amplifier, which will need repair or replacement - not a job for an amateur.
  5. If you don't get any sound from the battery test find another piece of speaker wire (any piece of 2 core cable with bare ends will do for testing) and repeat the battery test. If you get sound then replace the speaker wire. If not remove the speaker wire again and go to next step.
  6. Lay the speaker face downwards and carefully unscrew the back panel (don't do this if it is still under manufacturers warranty - take it back for repair or replacement). Lift the back panel off carefully and slowly taking care not to pull the connecting wires inside the cabinet, which will probably be quite short. You may have to settle for just rotating the back panel slightly so that you can see inside if the wires are too short to do otherwise.
  7. Use sticky tape to tightly attach the bare ends of the speaker wires to the terminals of the battery. Touch the loose ends of the speaker wires on the two metal terminals where the internal wires are joined onto the back of the big loudspeaker cone. If this produces a crackling sound it is the internal wiring in the cabinet that needs re-soldering. Otherwise the loudspeaker unit has failed and will need replacement.
Jan 29, 2011 | M-Audio Avid Maudio 99005226600...
The loud speaker on my g1 doesn't work how do I replace
  1. 1st OF ALL, YOU WILL HAVE TO UNSCREW THE PHONE
  2. THEN YOU WILL REMOVE THE BAD LOUDSPEAKER
  3. THEN YOU WILL HAVE TO GET A NEW LOUDSPEAKER @ ANY PHONE REPAIR SHOP
  4. THEN FIX THE NEW LOUDSPEAKER IN THE PHONE
  5. TEST IT
Jan 10, 2011 | HTC G1
What's the output of the speaker system in watts ?
Hello
Audio power is the electrical power transferred from an audio amplifier to a loudspeaker, measured in watts. The electrical power delivered to the loudspeaker and its sensitivity determines the sound power level generated (with the rest being converted to heat).
Amplifiers are limited in the electrical energy they can amplify, loudspeakers are limited in the electrical energy they can convert to sound energy without distorting the audio signal or destroying themselves. These power ratings are important to consumers finding compatible products and comparing competitors
Do rate, if got help
Dec 04, 2010 | Logitech Z523 2 Speakers
Dropped Tea in E63 loudspeaker not working...Kindly Help
I think your mobile ringer no working it need to be clean. So if you have any Mobile repair worker to near your home go to over there & tell him to make it clean but carefully then check your mob. ringer.
I hope than it will work very fine as working before...
Jan 25, 2010 | Nokia E63 Cell Phone
I dont find screws .a pair of samsung loudspeakers from a mini component .each loudspeaker has an eigth inches speaker .I need to open it for replacement but I dont see any screw. the face is made of vinyl...
along the rim (outside circumference) of the 8" Wooffer there is probably padded material that covers up the screws check under there.
(did I make you say underwear?)
Oct 05, 2009 | Samsung Audio Players & Recorders
In my mobile there is no loudspeaker option in Nokia 6681
For volume and loudspeaker control increasing or decreasing the volume level when you have an active call or are listening to a sound, press left or right scroll, respectively. Sound applications use the loudspeaker by default.
To use the loudspeaker during a call, start a call, and press the button with the talking face icon and press again to return to earpiece.
If it does not work the speaker, or amp circuit is bad or there is a glitch in the firmware. Replacing the speaker is the only economically viable repair. If the amp circuit or firmware has malfunctioned a new phone is in order.
Jul 05, 2009 | Nokia 6681 Cellular Phone
follow instructions to step 8 (with thanks to Anny for posting it)
http://www.annystudio.com/misc/ipaq4700/
With the motherboard removed, you will see the back of the speaker pictured in step 10.
I seem to recall that the 'official' replacement loudspeaker (17 UKPounds) looked identical to one taken out of an old Nokia mobile telephone I had lying around. I didn't try it - so I don't know if it would work but the DC resistance across the terminals were about the same.
The loudspeaker in the hx4700 is notoriously unreliable and can apparently be damaged by some software titles. I recall that HP published a firmware patch some years ago. I have also found that it is easy to miss the stylus receptical in the top of the device and it is possible to inadvertantly jam the stylus into the earphone socket. This can cause damage to the switch contacts in the jack socket that disconnects the loudspeaker when headphones are used giving the false impression that the loudspeaker itself has failed. I checked this with a multimeter before changing the speaker. In my case the contacts were OK but I doubt that I would have been able to repair the switch contacts without some serious soldering iron weilding.
A final note. The ribbon connector for the screen is VERY fragile. Be ultra careful when removing it.
Hope it helps.
Steve
Sep 02, 2008 | HP iPAQ HX4700 Pocket PC
Cerwin Vega LS-15 Speaker Logo
269 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Steve
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
