Only had the tv for 2 months, but it wont turn on. the remote wont turn it on and it wont turn on manuelly the light on the front remains red
SOURCE: My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON
2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
SOURCE: Hisense LCD Tl2020
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
SOURCE: need new remote
Why not phone Hisense and ask them. The phone number number should be listed in your directory and they will tell you where the Hisense outlet is to purches .. and u can ask them about a universal one
SOURCE: need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
