Question about Campbell Hausfeld Air Tools & Compressors
Need part # for WL350102AJ gasket kit - Campbell Hausfeld Air Tools & Compressors
  • Campbell Hau... Master
  • 885 Answers
The part number for a valve plate kit for your motor/pump is WL201400. The kit includes the head gasket (XA010800AV), exhaust valve, valve plate, intake valve and cylinder gasket (XA010300AV). The two parts with numbers after them are the only ones available by themselves, all other parts are only available in the kit.
Posted on Feb 10, 2012
Testimonial: "Thank You Repair Man."
Install crankshaft kit on 2004 hyundai sonata 6 cylinder 2.7l engine
Really need more information...It sounds like they didn't give you a complete gasket kit...You will have to remove and re-install other components just to be able to see the crank shaft....You need the front and rear oil seal for the crank..,Oil pan gasket..,exhaust will have to be removed also...etc.......NEED MORE INFO..
Jan 24, 2015 | Hyundai Motor 2004 Sonata
I have a sp-710x32 Vari-Flor Filter control valve. When I turn filter on pool runs but water is also coming out from hose for backwash.
Thank you for posting your question here on Fixya.com.
You need to replace the gasket inside the valve to stop the leak. The gasket kit is pretty cheap and not too hard to replace. It should be a "go kit 10" or gkit10. You should be able to call any local pool store to get the part you need without any trouble. The kit includes other gaskets parts to ensure as you replace the key gasket you change the rest while you are at it. You may be able to just purchase the key gasket but for the money difference, the kit is the way to go.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Aug 18, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
WOULD LIKE THE PART NUMBER FOR REBUILD KIT TO A 1999 F150 4.6L ENGINE. COMPLETE SET AND GASKET SET ONLY PLEASE.
the 'kit' that you are looking for varies from parts distributors. if you are going to the dealership for this then you will be getting a very long list of numbers that you really don't need any how. If you are replacing the gaskets for this vehicle then you want to go to the local parts store and ask for the "upper gasket kit" for (insert vehicle here) and then you will get what you are looking for. if you are looking to rebuild the bottom end, the block, then you want to get the "lower gasket kit" but a good upper gasket kit (ie. Felpro, Victor Reins, etc...) then you should get a head gasket, valve cover gasket, and intake and exhaust gaskets. the lower gasket kit can include but not always (you should ask what gaskets come in it) oil pan, freeze plugs, and front and rear main seals.
Apr 18, 2011 | Ford F-150 Cars & Trucks
How to do change my transmission fluid on a 2005 g6
give the vin ID to the dealer an they can tell you how to fill it (once you replace filter/gasket). Either it's a classic fill tube, or the more cumbersome check-plug type. Ether way, you still need a filter/gasket kit. Make sure you so NOT use the junky Duralast kit from Autozone. Your best bet is to use a gasket that has a wire bead built into the gasket (semi-rigid)
Dec 01, 2010 | 2005 Pontiac G6
I tried to start my troy vac/blower and it takes for ever to start and when i used the vacuum it runs slower and finally stalls and wont start backup
Your machine probably needs: 1. the carburetor adjusted 2. The carburetor cleaned 3. A gasket and diaghram kit installed in the carb
1. To adjust: http://www.zamacarb.com/tipspage.html
2. To clean: Remove, disassemble and clean. Here are the carb parts: (Only clean the metal parts)
http://tech.flygsw.org/walbro_tuneup.htm
3. Gasket and diaghragm Kit: You will need to know the carb model (probably a Zama)
Find the model of your repair kit here: http://www.zamacarb.com/pdfs/QuickKit_CR2010.pdf
An RB kit is a complete rebuild kit (contains all the parts in the G & D kit)
A G & D kit is a gasket and diaghragm kit and will cure most of the carbs ills.
Many online vendors sell these and there are an abundance of them on Ebay.
Nov 12, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Excessive oil . white smoke over heats guessing
You will go to a Chevy dealer and they will know exactly what you will need. Any auto parts store expects the buyer to know what they want always it seems
Get a set of head gaskets, a intake manifold gasket kit (complete kit) and some silicone sealer, Coolant also and a thermostat & gasket
Apr 11, 2010 | 2000 Chevrolet Venture
1999 S10 blazer 4.3. need to replace lower intake gaskets. went and bought the kit and the kit has upper and lower intake gaskets with it. do i need to replace them all?? the kit also came with gasket...
If your going to replace the lower intake and the set came with the upper why not replace it, your removing it any way.the silicone you need to used it at the 4 corners where the heads meet the engine block or you will have leaks.
Feb 02, 2010 | 1999 Chevrolet Blazer
Gasket Kit 916/996/998
base gaskets and side cover gaskets. Does it also include necessary o-rings or do they need to be purchased separately?I just bought one of these kits for a 916 a few weeks back it includes; Head gaskets Base gaskets Inlet manifold gaskets Valve seals Numerous green O-rings - not sure what they're all for because I didn't use them. The gasket kit cost the same as 2 head gaskets seperately.,,
Nov 10, 2008 | 2002 Ducati 998 S Bayliss
Nov 10, 2008 | 2002 Ducati 998 R
Air Tools & Compressors Logo
247 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
