Question about Canon EOS-AE-1 35mm SLR Camera
Lens inside the camera locked in the upright position and shutter not retracting?
So this is my parents camera and Im using it for a black and white photography class this semester. It has been working fantasticly up until a few hours ago. I had take around 10 pictures on the roll and when i went to snap the 11th one the shudder opened up like normal then just stayed in place. I can not advance the film at all and the lever only goes about half way till it can not go any further. By taking of the camera lens, the lens inside the camera is in the upright position (letting light in) and will not stay down at all. I know this is asking alot since you can not physically see the problem but I need to solve the problem as quick as possibly since I need it for a class. Buying another one is sadly out of the question as well. Thanks!
  • Christopher Feb 09, 2012
    I also changed the battery out and that is not the problem.
    Top Expert:
  • Canon Master
  • 14,161 Answers
Posted on Jul 18, 2016
SOURCE: AE-1Problems... Advance lever, Shutter, and more.
This happened to me to both the Canon's I had. I found out it was a dead battery. Once I replaced those it worked fine. The battery is hidden under the hand grip which can be taken off using a coin in the screw slot.
Sincerely,
Karin
Posted on Nov 24, 2007
cpt100
  • 154 Answers
SOURCE: Canon AT-1 (Similar AE-1) Shutter Fires Upon Advancing Film Lever
No need to look at the schematics. It only will give you a little headache. Replace Shutter release magnet (MG#3). While winding stage the Mg#3 suppose to catch the lever and any dirt or particle may prevent it. Clean it and it shoud take care of the problem. Good Luck -James. For further assistance email, go to www.camerarepairjapan.com
Posted on Mar 26, 2009
cpt100
  • 154 Answers
SOURCE: Automatic aperture setting on canon FD lenses not working on AE-1
You have a case of AE(auto exposure) Unit faulty or getting bad. It suppose to register as it move within the AE unit according to the exposure calculation but somehow it is broken. Technician usualy replace the AE unit and takes care of the problem. It can also be rebuilt if new parts are not available. This requires complete disassembly and mirror box removal. The average cost of repair probably runs around $100. Yes, "A" mode is correct for most of the shots and it was a state of art electronic system and more computerized than you think. It has 3 IC chips in there for precessing and 1 chip for the exposure. All works together for good. -James
Posted on Apr 01, 2009
  • 13 Answers
SOURCE: have a Canon AE-1 Program that I've received
Camera has a bad magnet, the A series were plagued by this.
Repairs will cost more than probably what it's worth.
The AE-1's used an electromagnet system to activate the shutter for a smoother press and less shake from the camera system.
I got lucky and recently purchased an AE-1 program that doesn't have this problem, it seems to be a hit and miss with these.
Posted on Nov 14, 2009
  • 571 Answers
SOURCE: I have an Canon AE-1 and the film advance lever
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Posted on Dec 05, 2009
Shutter lense is stuck out, want retract. Display went black. want retract and display is black.
Hi, It sounds like the lens is stuck, possibly from dropping? Either way if lighting tapping it doesn't work then unfortunately there's no way it can be fixed.
Aug 29, 2011 | HP CB350 Digital Camera
When trying to turn the camera on, the lens will not extend fully. it extends partially, and then the camera turns itself off, leaving the lens in the partially extended position. you have to try and turn...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 23, 2011 | FUJIFILM FinePix JX250 Digital Camera
Canon Powershot A510 - lens covers stuck
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it. There are many non-invasive techniques that people have come up with to accomplish this. Some may be seen on this blog article. You can also open the lens barrel up to fix the covers, but only as a very last resort. The article also gives examples for this type of procedure.
Jun 06, 2010 | Canon PowerShot A510 Digital Camera
Canon powershot s2 15 shutter won't open
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
May 10, 2009 | Canon PowerShot S2 IS Digital Camera
My son pulled out one of the shutters that opens and closes over the lens. The shutters no longer open all the way. The camera is brand new. How can I fix the rest of the shutters? Should I pull them...
You can pull off the other one if you want. To put it back in your basically going to have to take apart the camera. The "Shutters" on the outside is nothing more but to protect the lens will its in the camera. The actual shutter is inside the lens that open and closes very quickly when you take a picture.
Think of it this way, the shutter in the lens opens up to let in light that shows the image to the sensor behind the lens. Then it closes to "finish" capturing the light".
The "shutters" or "doors" on the outside do not move once you take a picture. They only close once the lens retract. (When the camera is turned off or idles)
Hope this has been helpful.
Mar 30, 2009 | Fuji J150w Digital Camera
Leica C1 -- Unusable, electronics haywired
hi,
your camera needs cleaning of lens and lens shutter; because some time dust particles gose inside and effect the alignment of lens and cause camera not working.
please give me good rating if the solution works
Thanks for using FixYa.
Jan 05, 2009 | Leica C1 35mm Point and Shoot Camera
Canon digial camara, have picture is black
Black picture = faulty lens shutter. If lens shutter is always in closed position, no light can enter the camera lens. Replace camera lens part.
Nov 12, 2008 | Canon Cameras
Spring visible through the lens
Defective Lens Block.
Needs to be replaced.
Aug 15, 2008 | Pentax Optio 555 Digital Camera
Shutter won't close all the way
The lens cover of PSA60 opens along with the move of the objective lens. Normally the camera will sound an error beep when the lens does not end to the end position -- the lens cover is also not fully opened. In reverse, the lens will be retracted when the camera is switched off.
The "shutter" (outside lens cover) might have something stuck inside the blades or other mechanical parts that prevents the lens cover fully closed. Try to blow with a clean air (no hot air - because it can damage the electronics or plastics).
Or maybe the blades are probably not flat that may create resistance on the surface. Try to flatten the blades by hands.
Or maybe the mechanical systems need to be calibrated (by Canon service center).
My suggestion, try to exchange/trade-in your PSA60 with the latest model at the Canon center, because I have done it last year (trade-in with PS S5IS).
Aug 08, 2008 | Canon PowerShot A60 Digital Camera
Shutter will not close!
very small dust particals are the reason of this problem.I m suggesting an idea but apply it on your own risk.Keep camera in off position then slightly strick with ur fingernale around the lens ring evenly.This can make the lens shutter contrct.Once the shutter closed,clean gently with a painting brush over the edges where shutter slides from.do this for several times so that any hard dust partical causing may removed.do not insert anything inside.
Aug 12, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Canon EOS-AE-1 35mm SLR Camera Logo
190 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
