Question about KEF Audio KIT100 System
Need to know how to hook up my kit 100 to my tv
The tv is a Mitsubishi 60 in digital projector screen
VS-60719 60 in. Rear Projection Television: Blue Convergence is off, can't solve by using the ...
When the convergence problems happen.100% ur tv convergence board the 2 STK convergence ICS,and some or all it resistors are dead.These parts must be change,to be solved convergence problerms.Tries Websites like TvrepairWorld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.Only if u know how to do soldering,and have soldering equipments and solders.The shop will cost u $300-350 for the parts and labors.
May 18, 2010 | Mitsubishi VS-60719 60" Rear Projection...
Three colors bleed on screen and shadows reduces to portion of top screen model mitsubishi 60'' 2001 how to fix
** Caution! Hazardous voltages inside. Technical experience required.
This is a convergence problem. You will need repairs done. likely will cost $200-$600 depending on parts, service call, labour, etc. The convergence ICs are not particularly hard to change but you need good solder skills.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Need assistance with installing new converter box to televesion, the colored cords, no welcome screen/
i have a 60 hz mitsubishi screen t.v before i move to inpls i had it fix found out they mad th screen to little i had my husband take it a part now he doen't know how to put it back together he took the hole thing apart just the front screen can you tell me how to put it back thanks alot.
Aug 30, 2008 | Mitsubishi Traveller (SCRNTR60R) 60" 4:3...
Shadow effect
I think it's called "tubes" for the TV, the projection tubes are messed up, and you probably killed your bulbes. Very expensive to fix, just part out what can be used and get a new TV, or get a 60" tv with a smashed screen, and reuse your screen. People sell those on craigslist.org all the time with broken screens because they do not know how to replace them for only 100-200$
Apr 05, 2008 | Mitsubishi VS-6043 60" Rear Projection...
TRYING TO UPGRADE A MITSUBISHI WS-65807 BY TRYING TO LOCATE A SR-HD400 RECEIVER ? FOR HDTV
I believe the government is offering help on buying conversion kits for older tvs. They were either $50 or $100. Ask a few friends if they have heard of it.
You might search google for "HD upgrades" and see what you find.
Mar 11, 2008 | Toshiba TDP S3 Multimedia Projector
My screen is turning colors
May it have been knocked about so the projectors are out of alignment, or may it have been standing next to a powerfull magnetic field?
It may also sound like a mirror may have become misaligned, since the top half is affected
Nov 07, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Lines across my tv
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
Nov 03, 2007 | Mitsubishi VS-60705 60" Rear Projection...
KEF Audio KIT100 System Logo
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
shaqsatin
Level 1 Expert
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
