Question about iRiver T10 MP3 Player
Why do i get not supporting format on some of my music
T10 mp3 player
    Problem Solver:
  • 6 Answers
I have same problem please solving this problem
Posted on Feb 16, 2009
Sumsung YP-T10 some files wont play
You have to convert them. Make sure you use the file format that the mp3 player can support
Jun 12, 2009 | Samsung YP-T10 Digital Media Player
I just bought it today
Check the files that say "non-supported format" by right-clicking one and going to "properties". Click the "license," "digital rights mgmt," or "media usage rights" tab (wording varies by configuration). See if the license is expired or says, does not support transfer to device. Make sure your music svc sub is up-to-date. If so, convert them all to mp3 format - problem solved.
Another poster said that they got same error with 128 kbps bit rate.
-Tha Mp3 Doctor
May 08, 2008 | Samsung YP-T10 Digital Media Player
WMAs and MP3s getting a "not supported format"
Check the files that say "non-supported format" by right-clicking one and going to "properties". Click the "license," "digital rights mgmt," or "media usage rights" tab (wording varies by configuration). See if the license is expired or says, does not support transfer to device. Make sure your music svc sub is up-to-date. If so, convert them all to mp3 format - problem solved. Another poster said that they got same error with 128 kbps bit rate.
Irivet T10 "file check error"
i threw mine at a wall but that only made it worse
Jan 13, 2008 | iRiver T10 MP3 Player
Mp3 player no instructions
go to www.iriveramerica.com. click on support, then ultra portable support, then T10. download user manual. You should also be able to download a music manager for loading music onto your player from the website. Windows media player works well. you can also use Rhapsody.
Jun 21, 2007 | iRiver T10 MP3 Player
My T10 IRiver Browser will not work
re-format it. on player go to settings, then advanced then format. select format, say yes and it should reboot. if that doesn't work you need to upgrade the firmware. got to iriveramerica.com, support, ultra portabale support and download firmware updater software. Not a bad idea to upgrade firmware in either case. Your music will be lost when you format but you can simply re-load it from your music manager on your PC.
Mar 19, 2007 | iRiver T10 MP3 Player
Iriver T10 will not allow me to add songs
The updater that I could find directly via iRiver support did not work, but based on one of the other tips, I googled for the Version 2.7.0.0 updater ([MTP] iriver Firmware Updater for MTP devices).
http://www.iriver.com/flash/popup/flash_pop.asp?board=down&code=736
I recommend that you try the "normal" updater from the website (maybe yours is not an MTP version), and if that can't recognize your player, try the updater from the link above.
Note: The updater seemed to hang at 50% for over 5 minutes... I gave up and unplugged it. Then it asked me if I wanted to upgrade the firmware. "OK," I said. It took a few minutes. The screen went blank. I put in a fresh battery. Turned it on. It works. I was able to use Media player 11 to synch some songs to it.
BTW: It did blow away all the songs on the device, even though I chose "update" instead of "recover".
Dec 27, 2006 | iRiver T10 MP3 Player
Iriver t10
Try to re-format it. on player go to settings, then advanced then format. select format, say yes and it should reboot. if that doesn't work you need to upgrade the firmware. got to iriveramerica.com, support, ultra portabale support and download firmware updater software. Not a bad idea to upgrade firmware in either case. Your music will be lost when you format but you can simply re-load it from your music manager on your PC.
Sep 03, 2006 | iRiver T10 MP3 Player
iRiver T10 MP3 Player Logo
47 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
