Question about Kenmore 62602 Electric Dryer
Dryer got wet
An over-head water heater burst getting the dryer wet.  Water was found in the lint trap.  Does this warrant a repair call to the manufacturer?  It is a Kenmore dryer.
    Sergeant:
    Champion:
  • 324 Answers
Has the dryer dried yet? How much water got into the dryer?if the motor went bad it would probably just humm but if it dried out then it may be ok.
Posted on Oct 31, 2008
How do I retrieve a stick dropped down the lint chute?
if there is no water any where I would first use the wand of a vacuum cleaner that is going ( not the head just the pipe section)
Oct 11, 2015 | Dryers
Tip
Dryer - Tips for Cleaning Dryer Lint Trap!
Most people know where their lint trap is and most know or think they know how to clean them. BUT do you really know? For the people that use the fabric softner dryer sheets, they might find out that they still have not cleaned it properly. So if your dryer seems to take a longer and longer time to dry your clothes you might want to check this little tip out.<br /><br />Remove your lint trap and clean it normally. Then take it to your sink and run water onto it. IF the water doesn't pass through it immediately you have a blockage! You can't see it, but your dryer sheet is leaving residue on the screen and slowly building up.<br /><br />If there was any blockage, then you can use an old toothbrush to clean it. Just the toothbrush and water. To check to see how well you did run water and see if it passes through the screen immediately.<br /><br />This will increase your dryer efficiency and you save a little energy in the process.
on Jun 22, 2011 | Dryers
Had burst pipe, used geyser water to bath kid. Water supply now restored but geyser switch in box keeps on tripping... Help!
Use hair dryer and see if you can dry out parts.
Often, when electronics get wet, they cannot be repaired... like dropping cell phone in bucket of water.
Gene
h
Aug 28, 2013 | Mountain Plumbing Water Heaters
After every load, the dryer lint trap is wet and there's water condensation on inside of the glass door even days after use. I've thoroughly cleaned the ducts and the lint filter as well as inside where...
Is it gas dryer?
If it is might be problem with the heat exchanger, Water is one of the by products of combustion.
By chance do you have a Carbon Monoxide sensor?
Easy way to tell if a cracked heat exchanger is the problem.
Other thought I have is the dryer heating up when its drying, if the heater isn't working and you are throwing wet clothes in there that could be part of the issue.
a couple thoughts anyways
Aug 23, 2013 | Kenmore 7.3 cu. ft. Electric Dryer w/...
How do you wire the dryer MDE300AYW
Instructions
    • 1 Remove the lint screen from the dryer. If you are unsure how to remove the lint trap, refer to your owner's manual, as removal directions vary among Maytag models.
    • 2 Use your fingers to remove large chunks of lint from the lint screen. You should remove the lint from the lint trap after every load.
    • 3 Run the lint screen under the faucet. Use hot water and thoroughly wet down both sides.
    • 4 Scrub both sides of the lint screen with a wet nylon scrub brush. Rinse the screen again under hot water to remove loosened buildup. Allow the lint screen to air-dry on a towel before putting it back inside of the dryer.
    • 5 Make a paste of powdered laundry soap and warm water into a small bowl. Use three parts powdered detergent to one part water. Stir with a spoon until a paste forms.
    • 6 Dip a soft rag into the paste. Wipe down the entire interior of the dirty Maytag dryer with the rag and paste. Apply more paste to the cloth as needed.
    • 7 Rinse the interior of the dryer with a damp rag to remove the paste.
    • 8 Dry a load of damp towels in the Maytag dryer. Run a complete dry cycle to remove any residue left inside.
    • 9 Wipe down the exterior of the dryer with a rag moistened with all-purpose household cleaner. You can also use the household cleaner to remove certain stains from the interior of the dryer. Make sure the cleaner you are using is noninflammable.
Jan 15, 2013 | Maytag Dryers
Hi there, I'm hoping somebody can help me out? I have a washer/dryer and the dryer is not working. The drum rotates but does not heat up and the clothes are still very damp/wet Whilst the washer...
There are several reasons why a dryer would not heat up the clothes.
  1. The vent is plugged with lint or the blower set-screw is loose (blower slips on the motor shaft instead of spinning full speed). If you do not have good airflow at the outside exhaust when the dryer is running, you'll need to check the ductwork all the way back to the lint trap. If the lint trap is torn, repair or replace it.
  2. The heaters are not working due to a bad contact in the timer or one of the two thermostats. Check for continuity in the heater circuit with the dryer unplugged.
  3. The heaters are burned out. Note the plural - most dryers have two heaters, one for low heat, the other for medium, and both for high. Try a different heat setting and see if you get warm air. If you do, the heater you normally use is the problem.
Jul 03, 2011 | Hoover Washing Machines
I have a problem with the performance of the dryer on my Zanussi WD1272. the clothes get hot but at the end of the cycle are still wet. No problems with washing. Please help
Could be condenser or water solonoid valve fact that s hot says heater ok.fact that its wet perhaps not cooling down to water and pumping out fully, also check that the filter is clean....
Nov 26, 2010 | Zanussi WDA1055W Front Load Washer / Dryer
Kenmore 64672 dryer gets hot but clothes still wet
you have a clogged wall vent or clogged dryer vent or a clogged lint trap,you are trapping all the hot wet air in the dryer and that's why it's taking so lont to dry-mike
Apr 22, 2009 | Kenmore 64672 Electric Dryer
Condenser tumble dryer water problem
Took advice...isolated from electricity supply...removed left side panel (side with condenser tank), to access the pump. Cleaned it all out (masses of water and grey lint!) and put it all back together again. Bit fiddly getting the panel back on...no screws left over...result!
All working great now.
Simpler solution maybe...There is a 'trap door' that can be removed, which gives access to the area where the water and lint accumulate.
1) Isolate from electricity supply.
2) Take out the condenser unit at the bottom LHS front of the machine (routine maintenance).
3) Underneath of where the condenser unit usually lives..at the back...reach in and open the 'trap door'. This needs a flat head screwdriver and you must release the two plastic clips holding the trap door.
4) You can now access the area where the water and lint accumulate...which makes the 'float' give a false container full fault.
5) Clean out this water and gunk regularly (once a month)!
Hoping this will avoid taking the side panel off again...
Jun 02, 2008 | Bosch WTE86300 Electric Dryer
Kenmore 62602 Electric Dryer Logo
94 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
