Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan 295 farm boss chainsaw
It cranks on 2-3 pulls, it will idle for 6-8 seconds and does not run when giving it throttle.
  • Anonymous Mar 23, 2014
    wont start
Try to adjust the air and gas intake pin. It is a screw type dial usually found sticking out the carburetor. You are tuning your carburetor, so you will have to test different adjustments until you get your desired running idle and power. I suggest you start with adjusting the air intake screws to decrease air supply going to the cumbustion chamber, It will probably make the chainsaw run when you give it a throttle.
Keep me updated
Mark
Posted on Oct 24, 2008
2010 Ford F150 would suddenly loose power and only idle. Pull over shut off sit a couple minutes crank and run fine for a while then do same thing again. Wrench would show up on instrument panel
Sounds like the catalytic converter or muffler maybe getting plugged up and the computer is putting the truck in limp home mode. Did you put a scanner on the truck. You might try to remove the 02 sensor ahead of the cat and see if it runs a little better it will not be perfect but should stay running if so do an exhaust check. When the cat or muffler gets plugged it puts back pressure on the engine and won't allow the fuel to be pulled into the engine properly.
May 19, 2017 | Ford Cars & Trucks
2003 Yamaha V Star 1100 Classic slow to drop to idle
Hi, Ronald and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector
10. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links blue below. Good luck and have a wonderful day.
http://www.starbikeforums.com/forums/49-v-star/1194-rpm-slow-return-idle.html
star 1100 high idle untill complete stop
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
YAMAHA XVS1100A Owner Manual
Apr 13, 2016 | 2003 Yamaha V Star 1100 Classic
My Honda rancher 420 is idling bad. it will crank and idle good for a few seconds then it starts revving up and back down. then when I put it in gear it takes off without giving it any throttle.
Hey Bj,
Sounds like the throttle position sensor is going bad, take it to a professional and let them trouble shoot it.. it WILL be cheaper in the long run!!
Feb 20, 2015 | Honda 2010 FourTrax Rancher 4X4 With Power...
2007 Yamaha 115 Hp 2 stroke idle problem
Check the idle mixture. Sounds to me like it is too lean.
Mar 20, 2017 | Clymer EvinrudeJohnson Outboard Shop...
'97 crown vic cranks but stalls immediately
Idle air control valve. And/or gunked up throttle body, pcv port at throttle where mating to intake manifold.
Jul 08, 2017 | 1997 Ford Crown Victoria
It will turn over but not crank. it did crank once and as long as I didn't give itigas it would run. I had just put gas in the tank from Shell. Why will it not crank?
there is a micro switch in the throttle housing that will kill the spark if the cable is crimped or broke anywere. if you pull the cap and press the throttle and release it and you hear a click you just have to adjust it so the switch stays pressed when the throttle is all the way out to idle possition
Jan 22, 2010 | Polaris ATV
2001 MPV Runs Rough at Idle and Low end Throttle
This could be a bad fuel injector. Lean implies low fuel to the cylinder which will cause a misfire.
Feb 01, 2009 | 2002 Mazda MPV
1991 maxima crank, putts for 6 seconds, touch accelerator it dies
1st thing to do is try cleaning the inside of the MAF sensor and having the ECT sensor tested, that controls cold enrichment, it does the same thing as a choke, sounds like you have a lean run issue. You might also consider getting the fuel injectors professionally cleaned, it can make a real difference.
Nov 15, 2008 | 1991 Nissan Maxima
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
520 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
