Machine in constant professional use
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
SOURCE: Bernina Activa 135 sewing machine
Hi , the pedal micro switch are stuck , you may visit fixya repair service just , (enter zip area), you can find sewing machine repairman near you
SOURCE: needle stuck in right position, will only sew tiny,tiny stitches
oil it. down the shaft if you can get to it. and where ever there is a hole it always helps.
SOURCE: Viking sewing machine model 6430 will only sew backwards
bbragg77 is mostly correct. It is not the camstack. Although they will crack, but that is all together another problem. It is the stitch length/reverse mech. You can manually work it back and forth to free it and I like to use break cleaner to get it free then re lubricate. A good service shop can put you back in business. And yes Viking does not support 6000 series machines any longer.
