HP dv6139 loses Inet connection after 5 minutes (both ethernet & router)
The dv6139 loses its Internet connection on both the ethernet & wireless connection after about 5 minutes. I can get it back after re-booting for another five minutes or so and then I see the "unable to connect" message. Any suggestions would be greatly appreciated. I am running XP Pro. Thanks, Herzingmark
  • davidhhawley Feb 17, 2009
    Mine is the same - after 5 minutes the Internet connections goes down or a least the http does. I have found that Skype still works so my connection is good. This happens whether the computer is connected via wireless or ethernet.
    I have another laptop which is the exact same model an HP/Compaq nc6320 and this other one is not affected so it is clear that it is something up with the computer not the router.
    I have uninstalled just about all software that I thought could be affecting it including (for a short time) all the antivirus software and disabled the firewall and this made no difference.
    Reboot and I am back on line for another 5 minutes or so, then it looses the connection. Reboot and it is back, completely consistent and reproducible.
  • Jerry May 11, 2010
    What anti-virus and or security software are you using?
    Have you tested in different locations?
    Thanks
  • 4 Answers
Most probably it's the router's fault, if you have one. I've seen many cheap routers randomly loosing wireless connection with their computer clients. Try with another router. One possible solution: upgrade the router's firmware.
Posted on Oct 24, 2008
INET light is on not able to connect to internet
Checked the instruction manual online. There's no INET light indicated. There's Power, Status, WAN, WLAN, and LAN LEDs. The WAN LED only indicates that the WAN port is connected to another device, e.g., cable or DSL modem. Check on your cable or DSL modem to see if the Internet light is on. If so, then you'll need to log into your router and go through the configuration/setup per the manual for your type of connection.
Oct 18, 2013 | D-Link 802.11g Wireless Router WBR-1310...
I was having trouble getting a signal on my xbox 360 so i unplugged and plugged my router back in, this caused it to not put out a wireless signal, it does produce internet through an Ethernet cord, but...
It can take up to 2-5 minutes before your router starts broadcasting a wireless signal and for the xbox to be able to connect to it, turn your xbox off and the router wait a minute then turn your wireless router on, wait a further few minutes and turn your xbox on and try using the wireless connection
Jun 27, 2011 | Paradyne Zhone 6218I2 ADSL2+ 4 Port WiFi...
Cannot access internet wirelessly,Have tried several routers but cannot connect wirelessly, talktalk suggest that there is a problem with my wireless adapter
I faced the same issue and had to change 3 different routers of 3 other brands first of all switch off your router for 10 minutes and then change your ethernet cable (BLUE COLOR CABLE) with a new one also try changing the sides REMEMBER its a cable that connects from your MODEM to your WIRELESS ADAPTER !! and then switch on your ADAPTER (WIRELESS ROUTER) and wait for 10 last minutes :)
hope i FIXED your problem :)
Mar 22, 2011 | HP Computers & Internet
How to confirm that the BSNL modem is having problem & cannot be used any more if INET light is continuously blinking?
There are several lights on your modem/router. Each one has a function and signals whether it is working correctly by the color it is displaying and a few other factors.
All of the lights on your modem/router should be green and solid - EXCEPT for 2 which are for your internet and wireless services. Blinking means activity. If you INET light is continuously blinking that means its healthy. Blinking means activity. The internet always has activity. The blinking does not signal your activity - it signals the traffic and connection on the internet. Your wireless connection also has a light which should show activity and availability. A blinking light on your wireless connection means that either someone is connected wireless and using the internet or that the connection is up and available for wireless access.
All of your lights should be green. If you see a red or yellow light - regardless of whether it is flashing or not - it means that there is trouble or problems that need to be corrected.
Each light is marked with its function. They should say things like "power", "link", Internet or INET, and "wireless". When you turn on the modem/router during your first set up, let it power up and finish its testing before connecting your pc and turning it on. The modem will test each light, make them all go from red/yellow to green - then make them all turn solid green (not in that exact order) and this is all normal. You will know when it is done when all lights are solid green and stop blinking and/or moving (except the INET & wireless lights which will be constantly blinking). When all lights other then those two are green and steady - then its time to connect the cable to your pc and power it up.
If you are having problems with your internet connection - you can rule out the cause being your modem/router by following the instructions above. When you rule out that the modem/router is not the cause, you can continue by checking your PC.
For a wired connection (wired meaning that you are connecting your computer to the internet by using a cord/cable) the first thing you want to do is make sure that the computer is automatically sensing the connection.
Your computer should automatically sense that there is a live internet connection when you connect the ethernet cord from the modem/router to the pc. When its working right, the computer will display a connection picture which is called an "icon" on the bottom right side of your screen near the clock area. Sometimes there is a downward arrow by the clock which needs to be clicked on to expland this area and show all icons for running programs. If you see a downward pointing arrow by your clock on the bottom right side of your screen, click on the arrow.
Test that it is sensing the internet connection by unplugging the ethernet cable from your pc and watch the bottom right side of the screen at the same time. Unplug it and repeat if necessary while watching the bottom corner to see a change which indicates it senses the connection. A normal internet connection icon looks like the picture of a computer monitor. Some glow green when they are active and the ethernet cable is connected. Some show a red "X" over the picture of the monitor on the bottom right side of your screen when the internet connection is down or not working. Some will say "cable disconnected" when you unplug the ethernet cord. Some show "Cable now connected" when you plug it back in. You should see something change and/or appear if your pc is picking up the internet connection correctly. When you have verified this as true - then you can continue on to the next step of troubleshooting the internet connection.
DSL service is an internet connection that is always on. Its considered a "live" connection. DSL connections usually do not require any set up (programming or changing settings). The only time that this is not the case is when someone tries to to set up a dial up connection like aol over the top of a dsl connection. You can check this by going to your control panel, click on internet options, and choose the "connection" tab at the top. In the connection area box there should be "nothing". The connection area box is for dial up connection settings. If a dial up service was set up in the pc it would show it here (you would see AOL dial up ect). If you see a dial up connection set up and you know that you have dsl, click on the remove box and delete it from this area.
You do not need to install anything from a disk to establish an internet connection if you have a dsl line. That means you dont need an "aol" disk or software to make the internet work.
to start the internet click on the blue "e" on your desktop which stands for internet explorer.
If you have any questions you can reply to my solution by going into the problem you posted on Fixya and click on the "reply" option.
Mar 03, 2011 | Samson Technology X6v ADSL ModemWireless...
Lose connection to internet at random times
There could be several things that can cause this problem, ranging from low signal strength, electrical interference, clashes with other wireless routers in your area etc.
Please click on this link and follow my instructions for possible solutions to your problem :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
May 12, 2010 | 2wire (2701HG-B) Wireless Router
After losing power I lost network conaction
Try to power cycle the whole network and make sure that everything connected properly. Turn of the pc then the router and lastly the modem. Wait for 5 minutes then turn on the modem then router and pc. Modem should be connected to the internet port on the router and pc to the ethernet ports.
Jun 29, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
Computers & Internet Logo
310 people viewed this question
David Payne
David Payne
