Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Craftsman 6hp / 60gal air compressor
Motor starts and pressure gets to 15/20 psi then motor slows down and trips. Motor is new and valve is new. If i take intake tube off tank motor will run, when the tube is attached to the tank is when the problem occurs.
    Scholar:
  • 65 Answers
Make sure your pressure switch is set correctly. Check your pressure gauge and make sure it is functioning correctly. Also,seems sometimes if there is any time when there isn't the adequate amount of power demand supplied the motor heats up more causing the thermal protection switches to act a little finicky which in turn shuts it down.Check how many amps the motor is rated compared to the breaker controlling the circuit. Is it a dedicated circuit only for the compressor or are there other things also drawing power from the circuit ?
Posted on Nov 17, 2008
    Scholar:
  • 121 Answers
Does this trip on pressure or is it a breaker tripping? If you took off the intake then there is no pressure build up, thus it wouldn't trip the pressure switch. But would at the same time add a load to the motor. First check and make sure motor is wired properly, then check that pressure switch is wired properly and is adjusted to the right pressure. I don't believe that the intake tube would be clogged, it's a straight hole into the tank. But could be a possibility.
Posted on Oct 23, 2008
Dewalt Emglo 55168 motor starts to slow down as pressure builds to about 30 PSI. It really starts to labor. Any thoughts as to what could be causing the motor to strain and slow?
Most likely in tank check valve is leaking or belt is slipping. Belt tension easy to check, should not deflect with thumb pressure. Check valve should not let air escape out of tank. Easy to check. Run compressor till pressure builds to around 50 psi. Then unplug machine from power outlet. Listen for air leaking out of tank. In bad cases, air will actually leak out of intake filter. Replace check valve as needed. Good luck
Oct 26, 2016 | Dewalt Air Tools & Compressors
Compressor will not come on, and it is tripping my breaker
THIS IS ALL I COULD FIND ON THE INTERNET NOT SURE IF ITS GOING TO BE OF ANY HELP TO YOU.
Do you have any other electrical appliance in the circuit that might cycle on when the compressor is starting? If there isn't enough current to go around, that might be an issue.
it could be a failing pressure switch.
Check your unloader valve. I think that it has failed, and as a result, the motor can't overcome the additional load on start up.
If the compressor is blowing the breaker, you know that it's either a short of some kind, or the electrical motor is pulling more amps than the circuit can handle..
If you are sure that it's not a short, and the motor actually starts (it's not the capacitor), and the motor shaft turns easily (meaning that the power train into the compressor head is not binding in some way and overloading the motor) then it's got to be the motor that's at fault.
Try this. Unplug the compressor, drain the tank all the way down to no PSI on the gauge, close the tank drain, and plug it back in / start the compressor.
Does it start?
I suspect either you are overheating your compressor to the point where it starts to seize (thus drawing more amps and popping the breaker) or you've already damaged the motor and it's cycle gets shorter and shorter before it's overheated to the point of seizing.
OR TRY THIS LINK.
air compressor starts then trips breaker Google Search
Oct 29, 2017 | Craftsman 33 Gallon Vertical Portable Air...
Compressor runs to 175psi but trips pressure relief when pressure drops tries to restart motor but motor wont turn blows breaker. changed whole pressure switch have same problem.
The problem is lilkely the check valve between the compressor and the tank -- it is alowing pressure to build from tank to compressor preventing the compressor from turning over. Clean, maybe replace, check valve...
Charlie
Jan 09, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
Pressure in the tank only builds to 30 psi
Bad check valve. But I would check the regulator, by turning it down to about 10 PSI and running it and see if it builds again, if that works then it is the check valve. But from what you are saying I would replace the check valve anyways.
Jun 05, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
2 hp 120 v motor on compressor. motor will not start under load
bleeder valve is bad or dirty drain air unplug machine pull the back up plate control plate and make it shinny with emmeory cloth then clen it and try again, if it still does the same thing your going to nedd to replace unloader valve.
Apr 14, 2010 | Hitachi EC12 Portable Electric 2hp Air...
My Sears 1 HP compressor motor starts to slow down to almost zero RPM as pressure approaches 60 psi. Up until recently it produced 100 psi. Compressor rotates freely at shut down (no binding, etc). Is this...
IF IT HAS BELTS THE BELTS COULD HAVE BEEN LOOSE AND SLIPPING.. MOTOR COULD BE GETTING HOT DUE TO TOO SMALL OF CORD OR SMALL GAUGE DROPCORD. INTANK CHECK VALVE COULD BE GETTING CLOGGED NOT ALLOWING AIR TO PASS THRU IT. UNHOOK DISCHARGE LINE FROM HEAD TO THE TANK, THIS WILL ALLOW PUMP TO RUN UNDER NO STRESS AND SEE WHAT HAPPENS.
Apr 03, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
CRAFTSMAN 7HP 2 STAGE 60GAL. STOPPED CREATING
take the air fiter on pump off and see when pump in running if it has suction if not could have debris under valve keeping it open
Mar 25, 2009 | Air Tools & Compressors
Craftsman compressor won't cycle off
Hi, First, I think the cutoff pressure is 135psi and there is an overpressure valve so let it run a little longer. I don't know exactly which model you have ( some of these were oil less) but if it is running longer than you remember, be sure to check the oil if necessary, make sure you are not using a long extension as this will cause the motor to slow down and definitely check to make sure the water is drained and the drain petcock is closed all the way. Also check it without an air hose attached. Good Luck!
Feb 14, 2009 | Craftsman Air Tools & Compressors
Craftsman 6hp 150psi 30gal won't keep running
It sounds like the internal circuit breaker in the motor is heating up and then the breaker trips to shut down the motor. This is the protection so you don't have a fire if the motor burns up. The smell you have is the coils in the motor. Sorry to say that you will need a new motor for this unit. I hope this helps out.
Jan 17, 2009 | Air Tools & Compressors
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
747 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
