Question about Kenmore Oasis HE 27082 Top Load Washer
Control Unit Assembly
Biggest mistake I made was purchasing this Kenmore Oasis set. My control board just went out after 14 months, guess what Sears says...2 months out of warranty, too bad. So now I have a $150 to replace on this high dollar washer. I'll remember this info on the other problem because I'll probably be having it soon too!
I will not buy any more appliances from Sears, and I hope word of mouth means something to them.
  • Tinlz Oct 28, 2008
    Kenmore Oasis HE 27082 Stainless Steel Top Load Washer SUCKS! Ours went to the dogs on the FIRST Machine which they completely replaced it with another Kenmore Oasis HE 27082 Stainless Steel Top Load Washer. We have had repair here twice to get change out of the pump. REALLY BAD DESIGN FEATURE. Now that this second machine is out of warrenty, we are having the same old problems, it won't spin the water out and leaves the clothes soaking wet. Only thing is, now they tell us we need two different pumps for an F 32 error and won't clean the change out on a regular repair call. Tried to drain it after taking the clothes out and it sat at 7 minutes just sitting there until I unplugged it.
    Going to war with Sears tomorrow. The repair man told me to get a plain old top loader washer and DON'T spend more then $350 to $400 for it. Don't get one with a computer, just get a regular dial without all the bells and whistles, and you will do 1000 times better then with the Oasis.
We are researching for new laundry machines (10) for our condominium laundry room. I'm glad I found this site, and I guess we won't be buying Kenmore products.
Saratoga Condominiums
Posted on Oct 28, 2008
F1 CODE ONSEARS ELITE OASIS WASHER MODEL #110.27032603 SER.#CU0670188
F then 1 flashes when there is a primary control failure. Replace the machine control assembly. The part number for the control board is W1018966
it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apwagner.com
appliancepartspros.com
apdepot.com
Gene
Aug 15, 2011 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Oasis HE is about 4-5 years old. Withing the last 6 months or so, it has started faulting to UL(uneven load) in the final spin cycle every load. It doesn't matter if I am only washing 1...
Sears has a recall for the Kenmore Oasis washer. I have the exact same problem. Call Recall Line @ 1-800-659-7026 with Model number and serial number. The part is a control board that works with the spin cycle.
Feb 25, 2011 | Kenmore Oasis HE 27082 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I have the kenmore elite oasis CT5170215 it just went bad this week. it seemed to last longer that some of them. is this a control panel issue also.where can i get one if so
this unit may be under a service recall for control problems call sears to check and they can ship part right to you if needed 1-800-469-4663
Sep 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Junk
Please pass it along to Kenmore as well.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 25, 2009 | Kenmore Washing Machines
Kenmore elite oasis washer 3rd repair
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!
Jun 01, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer fills and starts for a while and then stops
I recieved the followng letter from sears last week since we had registered our OASIS He washer two years ago since we purchased it new. The washer has a serial number that is authorized to get a replacement board, and the part has been shipped to my house. Once it arrives, we are to call the local Sears dept for someone to install the new board.
For washers that have the first four of the serial numbers as:
CS48-CS52 or CT01-CT49 qualify for the replacement Control Board.
1-800-847-9083 between 8am-8pm M-Saturday.
Good Luck all.
Mar 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis He 27082603
Folks F1 means the board is bad, I would definitely call the line listed above with model and serial number. They will schedule a tech, maybe me if your in Phoenix and they will give you a receipt, but if there smart the call will be set to transfer the charge to Sears:)
Sep 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
I too had the misfortune of dealing with the continuous beeping on my washer (model # 110.27062600). No code was given.I called the Sears hotline and asked for the manufacturers warranty department. I then called the recall line at (800)659-7026 and after giving my model number and serial number they discovered is was indeed recalled or being "upgraded"! They have ordered the part and are sending someone out. For those who have already paid to have it repaired I would call Sears and ask for a refund. Good luck!
Jan 06, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Power trouble with Kenmore Oasis HE 4, Model # 27082601
More than likely it is the control assy again, make sure the unit has a good ground before replacing the control assy.
Sep 17, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
120 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
