Question about EuroCave Refrigerators
My Eurocave v283 won't cool any more - problem celsius/fahrenheit?
I've a 5 year old Eurocave Classic cabinet V283. Until recently it worked fine but now it won't cool any more. Normally it works in celsius degrees. The temperature sensor works ok but I can't set the desired temperature below 41 degrees. And 41 degrees celsius a far too high to store wines, the cabinet start to heat instead of cooling it. To me this sounds like a celsius/fahrenheit problem. It measures in celsius but the setting is done in Fahrenheit. Anybody a suggestion? According to Eurocave I need to order a new circuitboard 590 euro but to me this sounds rediculous. The display works fine, the sensor works fine, alarms works fine...it's just te temperature setting which won't work.
3 Suggested Answers
  • 3600 Answers
SOURCE: whirlpool 6 sense model WSC5513- A+ X side by
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Posted on Aug 20, 2009
  • 25 Answers
SOURCE: breezaire wkce 1060 does not cool my wine cabinet
I'm not familiar with your unit, but sounds like condenser problems. Check for a dirty coil on the backside or underneath the unit. Also, if it has a fan for that coil, make sure it's running when the compressor is running and that the blades are clean. Other than that, it could have developed a refrigerant leak.
Posted on Sep 15, 2009
Change from Celsius to feherenheit
There is a formula for converting Celsius to Fahrenheit temperatures.
[Celsius] times 9/5 plus 32
or
(°C) * 9/5 +32 = Fahrenheit
For example,
20 in Celsius needs to be converted,
20 * 9/5 + 32 = 68
Hence, 20 Celsius is 68 Fahrenheit.
Kudos!
Apr 04, 2018 | Miscellaneous
When is fahrenheit equal to celsius
c = 5/9 f + 32 Water freezes at 0C and boils at 100c They are never equal.
Jan 12, 2017 | Office Equipment & Supplies
How do we change F to Celsius.
How to convert Fahrenheit to Celsius 0 degrees Fahrenheit is equal to -17.77778 degrees Celsius:
0 °F = -17.77778 °C
The temperature T in degrees Celsius (°C) is equal to the temperature T in degrees Fahrenheit (°F) minus 32, times 5/9:
T(°C) = (T(°F) - 32) × 5/9
or
T(°C) = (T(°F) - 32) / (9/5)
or
T(°C) = (T(°F) - 32) / 1.8
Example Convert 68 degrees Fahrenheit to degrees Celsius:
T(°C) = (68°F - 32) × 5/9 = 20 °C
See webpage
http://www.rapidtables.com/convert/temperature/fahrenheit-to-celsius.htm
Sep 23, 2015 | DMI / Briggs Healthcare 15-681-000 -...
How to change from Celsius to Fahrenheit
To convert degrees C to degrees F, Multiply the Centigrade temperature by 9, then divide by 5, then add 32
Or, degrees F= (9/5 degrees C) + 32
Here's link to website which explains difference between Fahrenheit & Centigrade scales, & how to convert between them:
http://www.mathsisfun.com/temperature-conversion.html
Jul 11, 2014 | 1996 Buick Park Avenue
How do I change the temperature reading from Celsius to Fahrenheit?
with the switch in the 'lock' position, hit the C/F button (also labeled as the 'min' & 'date' button)
Dec 30, 2011 | Elgin Travel Alarm Clock
The stove is stuck on celsius. I pressed and held the CANCEL AND BAKE buttons for 3 seconds and nothing happens. I don't know how it got on celsius. How do I get it back on Fahrenheit?
You can get Whirlpool manuals from http://www.whirlpool.com/custserv/index.jsp
Just got it from there:
The temperature is preset at Fahrenheit, but can be changed to
Celsius.
Style 1 - Electronic Oven Control
To change: Press and hold PRECISE CLEAN for 5 seconds, and
"TEMPERATURE UNIT CELSIUS" will appear in the display.
Repeat to change back to Fahrenheit.
To exit mode, press OFF/CANCEL.
Styles 2, 3 & 4 - Electronic Oven Controls
To change: Press and hold BROIL for 5 seconds. A tone will
sound and "°C" or "°F" will appear on the display. Repeat to
Mar 18, 2011 | Whirlpool GR563LXS Kitchen Range
Change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Nov 11, 2009 | Comfort Zone CZ-800 Heater
Switch from Celsius to Fahrenheit Temperature setting
Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit. Hope this helps!
Feb 10, 2008 | Magic Chef 31000 Gas Kitchen Range
Refrigerators Logo
62 people viewed this question
Top EuroCave Refrigerators Experts
 steve
steve
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
