SOURCE: Installing Fuser kit
are you a service eng. or a User isf you are a user you have be more care when you diassemble it . It can cause malfuntion I can get you a service manule for this . or check google for that
SOURCE: New maintenance kit
Hi Did you run up the developer unit? Menu button down to Other then to Service and press enter on developer and switch off and turn on will run for a while. In the service menu after you run up the dev unit you may have a option in there to press enter on the MK Symbol.
Cheers
SOURCE: XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
SOURCE: how to reset maintenance counter on a Dell 5310
1. Turn off the printer.
2. Press and hold (check) and .(right arrow).
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
5. Select Reset Maintenance Count from the Configuration menu.
6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset.
When the reset operation is complete, the menu returns to the Printer Setup Reset
Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press
Select to Return to Ready status.
SOURCE: Need to reset the counter
First, you enter the config menu by powering off the printer. Hold the middle and right arrow buttons and turn the printer back one. Continue to hold until you see Performing self test. Then release. You will then see config menu. Scroll down to reset maintenance count and press select. It will reset and bring you back. Then restart the printer.
