Question about Intel Motherboard
Ide master parameter out of range
The computer has a black screen with the problem ide master parameter out of range and asks to regularly do data backups.
the computer is a Optiplex gx270 pentium 4
    Scholar:
  • 89 Answers
Try reinstalling the m/b drivers--
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_CEL_GX270&os=WW1&osl=en&catid=&impid=
Do the chipset, and the IDE & EIDE Controllers.
If that doesn't work, most likely board is ready to go out.
Thanks
Posted on Oct 28, 2008
    Scholar:
  • 195 Answers
Sounds like your hard drive was recently replaced. if thats the case your IDE cables were put back wrong, especially if you have the IDE cable for two hard drives. or your Jumper Pin on the back of your hard drive is in the wrong place. If neither one of those are the case, then Re Boot your computer, when the start up screen appears press the appropriate F-Key for set up, at the bottom of the screen you will have options. Press the appropriate key that says load default settings save and exit. Restart the computer. Good Luck.
Dell Studio 540 will not start shows black screen with parameter error message
Not very helpful info! I would try tapping f12 on booting up which takes you into the Dell Diagnostics mode. Then come back here.
Feb 24, 2014 | Dell Studio 540 MT Pentium DualCore E5300...
A message appears on my boot screen that a parameter has exceeded its range so i need to back up. My mouse alone freezes all the time
The message about parameters is from SMART monitoring, a function of the motherboard. SMART monitoring keeps a watch on several hard drive parameters, and warns you when they go out of preset limits. It's meant as an early warning that the drive may be failing, and you should back up any important data while you still can. The message doesn't mean that hard drive failure is imminent, but it's a good idea to do the backup if you haven't. It's probably also a good idea to buy a replacement hard drive now. They aren't expensive. Use a program like Norton Ghost to copy the current drive image to the new one, and you won't need to restore your system from scratch later.
Your mouse problem might be related to the disk drive, or it could just be a coincidence. A new mouse is cheap if the freezing keeps happening after you resolve the hard drive issue.
Jun 24, 2011 | Dell OptiPlex GX270 PC Desktop
Dell Optiplex 260 IDE hard drive dead. Would like to replace it with external Sun Brite hard drive. Windows 2000 installation stopped because it couldn't gain access to ext. drive. Says that special...
Windows 2000 cannot access USB drives for installation.
You need to replace the dead drive with a new IDE or PATA drive. That machine will not accept an SATA drive.
Feb 03, 2011 | Dell OptiPlex GX260 PC Desktop
My dell Optiplex GX270 will not start up. it gets to the microsoft xp loading screen and it begins to load but then it restarts. it gives me a message "the primary IDE master hard-drive self...
Sad to say, you need a hard drive. The clicking sound you're hearing is typical of a drive that has gone bad. The monitoring message you see is from the motherboard's SMART monitoring, which checks several drive parameters and tells you when something is out of normal range. Often this gives some advance warning of a drive going bad, but this time it's just another sign the drive is already bad.
Installing a new hard drive is quite simple, with only two cables to plug in and some screws holding the drive in place. You will need to reinstall Windows and your applications since the new drive will be blank. There isn't anything you can do to repair the bad drive. If you have data on the drive that you don't have backed up on some other medium and you must have, there are companies that offer data recovery services. Just be aware it can be expensive.
Sorry I can't give you better news, but thanks for using Fixya.
Nov 11, 2010 | Dell OptiPlex GX270 PC Desktop
Can't access hard drive getting IDE master hard drive SMS mess
You are getting a SMART error indicating that the hard disk drive is/has failing/failed. Likely, the only way to get data off the drive is to send it to a data recovery center, then install a new hard drive. Data recovery is generally expensive, but if you are interested you can contact places like DRIVESAVERS 800.440.1904
May 27, 2009 | Dell OptiPlex 170L PC Desktop
Can't boot my Dell Optiplex GX280 from the
Hi there
hey if you boot into bios and you need to make sure that the computer will recognize the hard drive and that the jumper that is on the hard drive is set as either master or slave depending on what you want than make sure that of the parameters are right and apply it. than restart the computer and than see if the cd will now boot and you should be able to continue from here ok
best regards mike
Mar 07, 2009 | Dell OptiPlex GX280 PC Desktop
Screen comes up stating; self monitoring system
The error refers to the SMART system (read more about it).
Your hard drive may be getting ready to fail or you may have received a false error message (which can occur). If possible go into the bios/CMOS and disable the SMART system so that you may be able to boot normally. Once booted you need to make a backup of your data immediately.
If you are unable to boot the machine even after disabling SMART you may need to replace the hard drive and hook the old one up either externally (the preferred method) or as a slave so that you may backup the data on it.
Mar 02, 2009 | Dell Inspiron 530 Desktop Computer
Dell GX270 Maxtor 7Y250M0
If you are getting bad block reports on your hard drive, it means that your hard drive media has suffered some degradation. It could very well be that some system files are being affected by this, thus continually triggering the problem. You may not like the suggestion I have, but it looks to me like the most solid solution (saving you hours and hours of troubleshooting).
Backup all files from your hard drive, save all of your browser shortcuts to backup files, then perform another Windows XP installation with a low level format of the hard drive. I know a PC specialist with many years of experience that says hard drives develop faulty areas over time and that every 5 years or so, it's just best to back up data from the hard drive and perform a low level format. This resets the device completely. If there are any faulty areas on the disk, they are skipped over--to the operating system, the drive will be perfectly fine.
This is not a guaranteed solution, but it sounds to me like it will eliminate a lot of possible culprits for you. Good luck.
Dec 30, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
IDE MASTER DRIVE ERROR
Sure sound like you hard drive is starting to have a problem. I would clean and defrag it after backing it up. start- my computer- right click on hard drive-properties-disk cleanup/  After that then 'tools defrag hard drive. then run scan disk
Jul 14, 2008 | Dell OptiPlex 170L PC Desktop
Intel Motherboard Logo
1,999 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
