Technics double cassette deck RS-TR232 - won't play
Power is on, tape deck is hooked up correctly, tape is inserted in either side. If play button or rewind button is pushed, it will make a clicking sound & the tape will start to move but stops, tried different tapes, and they move freely
SOURCE: Technics RS-TR272 dual cassette deck
My RS-TR272 tape deck plays the cassette but no sound. I have not even used it much, may be 3-4 times in last five years. I tried demagnetizing it but still no effect. It is brand new unit, only thing I did last time was that plugged in the RCA cables in opposite ways one time (Output in In and In into output one). I am not sure if that had any bad effect on it. Can someone please help on this as unit shows cassette playing. There is no volume switch on the unit itself as someone else recommended in the previous answer.
Posted on Nov 25, 2007
  • 319 Answers
SOURCE: Technics RS-TR272 Dual - Won't Reverse
Cassette decks that have been sitting for long periods have problems with drive belts and idlers becoming slack or decomposing of the rubber compound. If you wish to keep the unit, please have it cleaned and have belts/idlers replaced with new ones by a professional service. Also have controls and switches cleaned of built up tarnish and mildew to prevent noisey or drop-out audio
Posted on May 12, 2008
Grubhead
  • 5056 Answers
SOURCE: Technics Tape Deck RS-M227X. VU needles jump to the maximum right
More than likely the pre-amp IC has failed! Trace the wires from the VU meters back they should locate the source of the problem. Remember it will be something common to both channels!
Posted on Nov 02, 2009
  • 99 Answers
SOURCE: I need to know how to record 1 tape onto another
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
Posted on Jun 29, 2010
antoman
SOURCE: tape deck not working on a technics rs-eh600
My tape deck is not working. When starting play it goes forward and then reverse. What can I do?
Posted on Oct 11, 2010
RS-X501 DOUBLE CASSETTE DECK PROBLEM WITH TAPE DRIVE ON BOTH DECKS
Usually the fault is the failure of the BELT on the mechanism. You will need to remove the covers to have a look on the motor drive behind the mechanism of the tape drive. Thebelt can be changed if you are technically capable to remove and reset the mechanism.
May 06, 2011 | Technics RS-TR272 Single Cassette Deck
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
Need to find user manual. I have a problem in recording a tape. I put in deck1 --- cassette to be recorded in deck2 new cassette start play on deck1 ... turn on record and play in deck2 as...
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
Mar 01, 2011 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR373 is chewing tapes
A lot of tape chewing problems are caused by the capstan roller being worn. Check for wear or oxide on that first.
Jan 18, 2009 | Technics RS-TR373 Single Cassette Deck
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Help
Just connect you EQ to your receiver as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop. To hear the EQed signal with all receiver sources you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Nov 22, 2007 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR272-no sound during play
CHECK CONNECTIONS AT THE BASE OF THE READ HEADS AS THEY HAVE A TENDENCY TO CRACK OVER A PERIOD OF USE. CAREFULLY STRIP BACK AND RESOLDER, REMEMBER TO LEAVE SOME SLACK AS THE HEADS REVOLVE ON TAPE REVERSAL.
Jun 09, 2007 | Technics RS-TR272 Single Cassette Deck
Ahh, Another Dual cassette deck. These are typically not worth a repair charge. I went looking for a service manual but Hi Fi Engine did not have one but they had a Owners Manual. Any unit that has a specification as to wow and flutter starting new at .18% was never made to be a long lasting deck of any quality. I don't like to be negative about people equipment but you might be better off getting a better deck from the start. If you think it is worth the repair, then send it to someone but I don't think you will want to sink $100 into a unit like this.
I am not saying it is unrepairable but that with what you come out in the end you could have made a better choice for a deck to buy.
It is probably a bad solder joint or bad capacitor on the circuit board.
I am in Chicago and would look at it for you if you want.
153 people viewed this question
 Grubhead
Grubhead
