Question about Sony (41989) Hi-8 Tape
Hi8 camera tape shows white noise in camera and playback mode
I have a Sony CCD-V8000E camcorder. It's pretty old and hasn't been used for a few years although it worked fine when last used. It's been properly stored in the box it came in. Now, when I insert a tape and try to record all I get is some white noise which is probably the data not showing properly. There is no image at all. I see the same thing when the camera is in playback mode. I haven't yet tried cleaning it. Any suggestions most appreciated. I can't really afford to have it professionally looked at as I could practically buy a new camera for the same money, but this is a great camera and I'd love to have it working again. Many thanks.
JoeO700
  • 80 Answers
SOURCE: not reading Hi8 tapes
Fidus, I am not sure where you are located but the camcorder you're trying to use now is a PAL version of Sony's 8mm camcorder. If the tapes you recorded earlier were recorded in D8 (digital 8) or 8mm/Hi8 format NTSC, they will not play correctly in this unit. The NTSC and PAL formats are different and not compatible. Hope this helps you. Joe Weibel customelectronics.org
Posted on Mar 01, 2007
SOURCE: Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Posted on Aug 02, 2007
philipp
  • 217 Answers
SOURCE: cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Posted on Sep 15, 2007
SOURCE: very grainy playback
Same problem with my Sony CCD-TR416 recently. Know what finally worked? With camera playing a tape, I picked up the camera and tapped it sharply on a solid desktop. Had to do it 3 times. I held the camera with two hands, one on each side of the camera, raised it about 3 to 5 inches off the desktop and then quickly tapped it on the desk holding the camera parallel to the desktop so that it solidly hit with all of the lower surface of the camera body.
I know it sounds crazy. I swear it worked. I had tried cleaning the heads over and over. I examined them with a 20x loupe and they looked fine. I doubt that the problem was oxide and debris build-up on the heads.
I planned to order a new head/drum just to see if I could manage the replacement procedure by myself (I'm a chronic do-it-yourselfer/experimenter). I guess I don't need to do that now.
Why did the slam technique work? My guess: Inside the rotating head, there must be some sort of electronic track like the brushes of a motor or something similar.. Some sort of debris must have been involved in a corruption of the transfer of impulses from the heads. A few taps and it broke free.
If banging it on the desk didn't work, I was next planning to remove the drum to check for bad connections. I'm sorry I didn't have to do that.
Nevertheless, don't listen to everyone when they say that the "heads must be dirty." Nope. With the loupe, I could see mine were sparkling clean. But, I still had those multiple horizontal rows of short white streaks obliterating the video image. Tap. Tap. Tap. Now they're gone.
Try it. Couldn't hurt. Though chances are, you won't see this. I'm posting 6 months after your original post. I just happened upon your post as I researched the problem through Google. Neverthelss, someone might see my response someday and maybe they, too, will get luck with the tap, tap, tap procedure.
Posted on Jan 15, 2008
SOURCE: Sony Hi8 Eject Tape Issue
Cournane1, you're genius; at first I thought you're just teasing; I got the same problem and spent many hours trying, and finally took your advice - it works !!!! SUPER !!!
Posted on Apr 01, 2008
Can tapes from a Digital 8 camcorder play on a Hi8 xr ccdtrv87?
No, CCD-TRV87 is analog camcorder that can not playback digital format video-8 tapes.
Jun 23, 2010 | Sony Handycam CCD-TRV87 Camcorder
No sound on tape playback.
Are you using the sony software to download and convert the video?
Sep 08, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony ccd trv43 doesn't play hi8 after placing an old video 8 tape
Try to clean video head with cleaning cassette, if same position than video head need to be change
Mar 28, 2010 | Sony Handycam CCD-TRV43 Camcorder
Sony digital video camera mode no. DCR-HC14E not showing pictures/recording
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost.
Click Sony CCD Imager Support for details.
Jun 10, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
Sony Hi8
If you see the line while in the camera mode (actually recording a scene), then the line will be on the recording most likely. Check your tape for damage by lifting open the front of the cassette (tab on left side of tape), pull tab back while opening cover and inspect for creases or damage. Either of these cases will be non-repairable (bad recording). If the tape path is out of line the then it may be possible to have a tech realign the tape path to correct problem.
Apr 23, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Play back problem
Your camera playback heads appear to be dirty. You can purchase a head cleaner cassette from an electronics store or take it to a service centre where they will clean the heads.
Check that the tape itself is not damaged, as this can cause the same symptoms.
Jan 03, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Camcorder won't playback most Hi8 tapes
may be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
Aug 11, 2007 | Sony DCR-TRV285E Digital-8 Digital...
Cannot playback hi8 ccd trv107e pal
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Old tapes don't play
I have the same problems. Makes me mad. I have a years worth of tapes that I can no longer view. My dog at peed on my old camera which was a digital one.
Mar 03, 2007 | Sony Hi8 CCD-TRV138 Camcorder
Sony (41989) Hi-8 Tape Logo
88 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
