Question about Hitachi 53SWX10B 53" Rear Projection Television
Picture jumps my picture on my TV jumps it will fill the whole screen then it will jump and cut off the top three or four inches of the picture leaving black at the bottom of the screen. Sometimes it over sizes the picture so that it is larger then the tv and cuts off 2 inches at the top and bottom. it gets really frustrating when a movie has any subtitles as you cant read half of what they said.
    Sergeant:
    Champion:
  • 227 Answers
You might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Posted on Oct 23, 2008
My lg plasma tv is cutting off the edges of the shows we are watching. I cant find a setting that will take care of it. Can you help
hmm normally these settings are found in the picture settings of the set top box or just a setting in the tv's picture settings now there might be an option to say fill screen that may work best for some or leave the tv in 16:9 some broadcasts may only be in 4:3 at times this is normal broadcasting and not much can be done unless the setting on the picture option is set to fill screen
Jan 08, 2017 | LG Televison & Video
Portion of the screen is very dark, gets better after 20 minutes
Your LCD panel has failed, it will be cheaper to get a new set. If I have helped you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
Apr 17, 2014 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
I have a sanyo modle no DP46848 1/2 of the screen keeps going black and after it warms up it starts jumping in and out if you shake the th it will come on 4 a little while then starts cutting out it a
It sounds like a loose plug or connection and would require someone to take the set apart and do a visual inspection to locate and correct the issue.
Mar 13, 2012 | Televison & Video
Old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture jumping
If this jumping is accompanied by a sharp snapping sound, it may be the high voltage circuit discharging to chassis. Leakage can cause the jumping and a discharge can momentarily blank the picture.
If you want to try a 'cleaning cure,' I suggest you pull the plug (not just turn it off) for several hours, preferably overnight. Sets of this size can carry enough static charge to punch a hole through your thumb if you get careless.
Remove the rear housing (shouldn't be more than 6-8 screws) and using a clean paintbrush, and possibly a vacuum to **** up the dust, clean it well and pay special attention to the area around a largish misshapen black plastic object bigger than most anything else and connected to the back of the picture tube via a fairly thick cable.
Dec 09, 2008 | Televison & Video
Philips 52" LCD TV
I think what you're talking about is the feature of the TV that auto-adjusts the screen for different pictures. What is does is tries to auto-fill the screen in case there are black bars on top (because of widescreen content) or on the side (regular tv content). It does it mistakenly if it notices too much black anywhere... happens a lot to me when credits are rolling. You can turn this off in your TV settings... I think you just set it to a specific type (widescreen, etc) instead of "auto".
Aug 21, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
The picture is jumping, sometimes the tv shows three of the picture.
The solder joints on the vertical output IC have cracked. This is a common problem in those sets and resoldering the pins of the vertical outpit IC will cure the problem.
May 28, 2007 | Zenith C27A25 27" TV
Hitachi 53SWX10B 53" Rear Projection Television Logo
348 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
