Question about Intel Motherboard
Ide master paremeter out of range
Optilpex gx270 pentium 4
Jh v c cbcx xb
Posted on Nov 24, 2008
    Scholar:
  • 89 Answers
Try reinstalling the m/b drivers--
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_CEL_GX270&os=WW1&osl=en&catid=&impid=
Do the chipset, and the IDE & EIDE Controllers.
If that doesn't work, most likely board is ready to go out.
Thanks
Posted on Oct 28, 2008
Can't get ECS PM800-M2 to boot to SATA drive.
You need to make sure that your SATA drive has an Operating system on it. It can't boot if it only has a data drive.
Feb 19, 2013 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Dell optiplex gx270 says drive D: disconected - how do i reconnect it
Unplug the power. Open case. Unplug and reconnect cables at drive. There are only two. IDE / SATA and power.
Oct 06, 2012 | Dell Optiplex GX270 Desktop Computer -...
Beep from the system unit
1) Please make sure that the HDD IDE cable is plugged in properly on both ends. It is a 40 pin female cord which should be seated on IDE channel 1 on the motherboard.
2) Make sure that all the CD/DVD drives are on IDE 2 or on SATA
3) Make sure taht the Jumper setting on the back of the HDD is set to MASTER
4) Login to bios and make see if you can find the HDD from the IDE drives menu. I am sure you will. From Boot menu select the NATIVE mode that will activate both the SATA and the IDE channels. Select HDD as second boot device.
Feb 01, 2012 | Intel Pentium 3 , 450 MHz Pentium III...
I have two hard drives. Both hardrives are recognized but only one has a drive letter of c the other does not have a letter. Both drives are set for cable select. I have also set them for master and slave...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Hope this helps you
Oct 15, 2011 | Dell OptiPlex GX270 PC Desktop
There is no problem whatsoever, I just would like to have the disposal of a practical user's manual for desktop computer DELL GX270. The only documentation I was able to lay my hands on is a printed...
If I understand correctly, you are looking for the user manual for the GX270 line of optiplex just in case the need arises. Please see This site for the Dell issued manual in a nice web format.
May 16, 2011 | Dell Optiplex GX270 Desktop Computer -...
Can i use 2.8ghz cpu for my p4s533-e?
this is what asus says:
arrow-org.gif Latest P4 CPU Support
The latest P4S533-E motherboard supports Socket 478 Intel® P4 processors, which utilize the most advanced 0.13um process technology to provide frequencies up to 2.53GHz
Mar 23, 2010 | ASUS P4S533-E Motherboard
Installed new hard drive and dell will not reconize it as primary drive
make sure that the jumper setting of your harddisk is properly mounted in master and connect the IDE cable to IDE 1 or SATA 1 connector...
Feb 08, 2010 | Dell OptiPlex GX270 PC Desktop
Video card upgrade
Yes you can put that new videocard. Your computer requirements meets videocard needs
Aug 05, 2009 | Dell OptiPlex GX270 PC Desktop
Proper pin numbers to install inserts in a Dell SATA 34 pin GX270 motherboard
why do you need the IDE cable pin out if you are using SATA?
they are diiferent and not interchangeable. if you want to use IDE pin out for SATA, then you need to get a adapter from IDE to SATA.
May 19, 2009 | Dell OptiPlex GX270 PC Desktop
Ide master parameter out of range
Thanks
Oct 23, 2008 | Intel Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
