A firewall router is limiting my network traffic
While downloading movie afirewall router is limiting my nework traffic
  • Jerry May 11, 2010
    And where are you getting this info from?
A Firewall/Router is Limiting my network Traffic. I need to open up a port so others can connect to me.
Posted on Mar 12, 2010
This guide should help
Optimizing µTorrent for Speed
http://www.techsupportalert.com/content/...
Posted on Dec 19, 2008
How connect cisco 5015 vpn with barracuda linkbalancer 330
Your Internet gateway <--- primary router
Port #1 on primary router <---> VPN server
Port #2 on primary router <--> Load Balancer
Load Balancer <--> web-server #1
Load Balancer <--> web-server #2
Load Balancer <--> web-server #3
VPN traffic enters your network, through the router to the VPN server, and then VPN-server back through the router to your internal servers. Web-traffic goes through the Load Balancer, for distribution to the collection of servers.
Jun 12, 2014 | WatchGuard Technologies WATCHGUARD TECH...
Cant send
Are you talking about sending email? A common problem is that all internet traffic works fine except for sending email, and this can be caused by a firewall either in the hardware(router) or on the client(computer).
Try disabling any firewalls you have on the router and client computer, or if you know how to navigate around the programs you need to allow email traffic.
I hope this helps giving the limited details provided :)
Regards,
G33k
May 04, 2011 | Computers & Internet
My router is limiting my network traffic
You router have limited NAT table size and if you use P2P this will slow down your network traffic for sure. The second reason is ports not forwarded and outbound connections cannot reach your PC. To solve both problems, download and install Router Commander that unleashes NAT table and forward ports automatically.
Dec 07, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Firewall/ Router Limiting Network Traffic.you need to open up a port so other can connect to you what it mean, how to over come tis problem
You need to write a rule on your firewall so that the traffic can be permitted. If you need help in writing the rule let me know the following details.
1. When you are getting this message (e.g yahoo messenger, MSN messenger, Internet access)
2. What is the firewall you have
3. do you know the administrator username and password
Nov 24, 2009 | Computers & Internet
Wireless security
You can disable the network card to block all Internet access.
This doesnt help though when you want to check your email etc.
Try turning off Windows Automatic updates, and any antivirus automatic updates, these two things are the bane of wireless broadband users as it will use most of their data before they even realise.
Aug 21, 2009 | Computers & Internet
How to configure ports on my modem
U will have to learn port forwarding.............u didn't mention router ur using since differnt router have different settings.......goto http://192.168.1.1 and search for port forwarding settings. Me too had this prob before port forwarding speed 15~20Kbps download and after 197~208Kbps.
Good luck with port forwarding.
Jan 18, 2009 | Computers & Internet
Network connection?
Log into your router. You should have a manual on accessing it. Find a selection called port forwarding. What your going to do it set port 6881 to be forwarded to your computer to get your IP address by going into /Start/Run/ type cmd.
Once the prompt is open type ipconfig /all and retrieve your IP address. once that port is forwarded to your computer you should be good to go.
Jan 15, 2009 | Zyxel P660HW-D1 Router
Restricting websites at router or firewall level
The pix does not allow you to block urls except if you use it in conjunction with websense for example. You could however deny all outgoing traffic to port 80 except for the ip address of the websites you want to be able to access.
To do that you would setup an access-list allowing you internal network to access certain ips on port 80 and deny all other traffic outgoing.
Let me know if you need more information on how to accomplish this.
Jan 04, 2009 | Cisco PIX 515E Firewall
Hai
Port forwarding only applies when you have a router.
You're on a PC with a direct link to internet.
So... there must be a software firewall, like the one in windows? disable it.
Try again...
I'm not familiar with nokia 5310... does it create a lan connection? or is just like some other regular modem?!
maybe your operator is blocking that kind of traffic.
Jul 15, 2008 | Computers & Internet
Youtube connectivity issue, on wifi movies will not load ...
First thing i would double check is to make sure the Iphone is being allowed on the network at all at home.
Some routers you have to go into the setup and manually allow a new device to access the network.
This is done with your MAC address on the Iphone, to find the MAC of your phone go to your home page, touch settings, then general, then about. Your MAC address is called your Wi-Fi address.
Every router is a little different but usually there is a Mac Filtering section under most routers. Add this address into the Filtering section and allow it to the network.
Hope this helps and enjoy your Iphone, I know I do ;)
Dec 27, 2007 | Apple iPhone Smartphone
Computers & Internet Logo
8,048 people viewed this question
David Payne
David Payne
