Question about Ricoh Aficio Office Equipment & Supplies
Need to reset Ricoh Aficio MP2510 after replacing Photconductor unit.
I already know how to get to service mode, not sure where to go from there.
3 Suggested Answers
  • 400 Answers
SOURCE: Ricoh aficio 1515mf photoconductor reset
Found some information here:
http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
Try the following
press the yellow “C” button
enter 107
press the red “C” button and keep it hold till the display changes
turn the power off with the big red switch on the front side
turn power on again.
OR
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
Posted on Jun 01, 2009
  • 990 Answers
SOURCE: Installing PCU on Ricoh Aficio MP2510.
Hello sir; The procedure little bit difficult, Remove PCU, remove the front cover(two screws), remove the rear bushing by remove one lock ring, remove the front joint, remove the developer hopper cover( 3 hook ) dump the old one out vacuum entire unit ( magnet roller ), fill in new developer, replace hopper cover, after replace PCU and developer you need to do some simulation, #1, press "clear mode" "107" and press hold "clear/stop" for 3 seconds, then touch screen on "copier sp". #2, enter sp3902-9 to1 for black drum unit, sp 3902-10 to 1 for yellow, sp3902-11 to 1 for cyan, sp3902-12 to 1 for magenta, #3, enter 3902-005 for black, 3902-006 for yellow, 3902-007 for cyan, 3902-008 for magenta, set 3902 to 1 for each of these if replaceing developer, press "exit" twice to end the service.
Posted on Sep 18, 2009
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
There is a little green light that is flashing when I try and print certain documents.. Is this the error warning? Also it is telling me to replace my photoconductor, would this be the reason it is not...
The flashing green light means that the machine is receiving the print data that you are sending when trying to print. Depending on how the dealer set up the machine, yes it will shut down and stop printing when the "replace photconductor" indicator comes on. You will either need to order a replacement unit or have a local service guy come out and reset the counters. If you order your own unit, it will come with installation instructions and they are designed to be end user replaceable.
Good Luck and Thank You for using Fixya
WheatlandServices
Nov 18, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Sep 18, 2009 | Office Equipment & Supplies
My Ricoh Aficio 1027 has a fuser code SC542. Is there a way to reset this in service mode (I know how to get in) to continue printing or will I need to replace or repair a part? The copier no longer has a...
to reset it just enter service mode and cycle power. But first take out the fuser ( right side of copier 2 screws ) and check that the 2 rollers hot and pressure are touching each other no gap between them. The unit you have is a nice unit, for service to fix if replacement is required would be about 300.00 or so... -Carl
Jul 24, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Try the following
enter 107
OR
  • Press Enter
  • Press Enter
  • Press Enter
  • Power off and on.
Jun 01, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
SC322 on Ricoh Aficio 2035
forget the laser unit your developer is shot... machine cant detect vsp and vsg... therefore gives a laser error... replace developer run developer initialization in sp mode copy sp drum... should solve the problem
Feb 16, 2009 | Ricoh Aficio 1035 Copier
Ricoh aficio cl3500n reads replace colr pcu what is this?
The PCU is the photconductor unit. There is a black pcu and a color pcu. Did you replace these or replace the toner cartridges??
http://www.websitetoolbox.com/mb/copierquestions
Jan 19, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
509 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
