Question about Canon imageRUNNER 3570 Copier
REMOVE PAPER FROM OUTPUT TRAY
COPIER STILL DOES NOT COPY
  • 100 Answers
SOURCE: system error indicated paper in output tray to be removed
I would unplug the machine and start back up.
Besides that you can take a canned air can and blow around the area where the paper comes out. Esp around the back. This is either a dirty sensor or a sensor flag that is hanging up or out of position.
Posted on Jan 09, 2009
  • 199 Answers
SOURCE: Canon IR2020 copier says "resizing paper" and wont copy.
operate copier without AUTO
Posted on May 22, 2009
JayBlair
  • 328 Answers
SOURCE: Display says need more paper, but it has paper in lower tray
Pull the tray out and look inside to see if the paper flag is dislodged.
Posted on Jun 11, 2009
FixinFax
  • 3085 Answers
SOURCE: my copier keeps saying output paper tray what do i
look to see if a little black tab where the paper comes out is stuck in the up position.
Posted on Oct 16, 2009
SOURCE: The ip4500 will not print - says the paper output tray is open!
Just fixed this problem on mine. Need to remove the covers, watch these 2 vids to see how..
http://www.youtube.com/profile?user=martop49#p/u/1/iQdHDR6po80
Then on the right side where the on switch is, near the hinge is a little switch with 2 yellow wires, it's probably broke. Pull the 2 wires out and solder or twist them together, then put everything back together. It will now assume the door is always open. Jobs a good'n :)
Posted on Jan 07, 2010
Copier displayed that, "Remove the paper from the output tray", but there is no paper jam in the output tray. What could be the cause and solution to this error?
Check the output tray for any bits of paper that may be triggering this error. Use a flashlight and look carefully, one tiny piece will do it.
Feb 08, 2017 | The Office Equipment & Supplies
What's your question?please how do I copy multiple copies with canoniR2000? mine copy's one n display incorrect paper size
Copying What You've Already Drawn ' SketchUp ...
https://help.sketchup.com/en/article/3000092
SketchUpWhen you copy and paste with the Move tool, you can make a single copy or createmultiple copies and tell SketchUp how to space them - if you know the ...
For Sale Canon IR2000 digital copier ' Facebook
https://www.facebook.com/media/set/?set=a.144875105642811...3
For Sale - Canon IR2000 digital copier Copy Speed 20 CPM First Copy ... Time 30 Sec Zoom 50-200% Duplexing Not supported Multiple Copies 1-99 Copier ...
Can I make multiple copies of the same DVD? - DVD-Cloner
www.dvd-cloner.com > DVD-Cloner Knowledge Base
Of course you can. Please use the option: "Number of copies" in the "Burn I/O" tab of the "Advanced setup" window. You can make multiple copies of the same ...
Canon Ir2000/2010/251/271Digital Copier - Buy and Sell Plus
www.buyandsellplus.com/.../Canon-Ir20002010251271Digital-Copier
Aug 28, 2012 - First Copy : Approx. 8.2 seconds. Max Copy / Orig. size : A3. Copying Resolution : 1200 x 600dpi. Multiple Copies : 1-99. Magnification Zoom ...
[PDF]iR2000/iR1600 Reference Guide - Canon
Dec 26, 2015 | Office Equipment & Supplies
I have a Gestetner copier. When I make a copy, there are lines on the right side of the copier. The lines are not solid-except for one. There are 8 lines. It covers about 1/4 of the page. The lines...
Try to make a copy on the copy board glass are the lines there? If not, make a copy using the adf, if they are there you need to clean the smaller , thinner piece of glass to the right side of the copy board glass. Good Luck
Sep 06, 2013 | Gestetner DSm725 Color Copier
Clc color copier error code E061-0321
Disable potential control by going into service mode Copier > Option > Tempo > F-POT-SW. Now copies can be run.
1) A solid black copy means laser is defective.
2) A white copy means you should check the Primary corona and HVT.
3) A good copy means you should check the Potential sensor PCB.
Dec 01, 2012 | Canon CLC 4000 Copier
Copier would not copy, when you press the copy button, nothing happens
Hi:
If the copier is at the ready screen and you press the copy button and nothing happens, Remove the toner cartridge and verify that is is not empty. If it is then the copier will not copy.
Andrew
Feb 16, 2011 | Toshiba estudio 305 Copier
My copier keeps showing an error: remove paper from output tray but there isn't any paper there? How do I proceed?
on the output tray you will see sensor flapper... it can get stuck ed... try to manually lift or down it, it usually gets out of his holder.
Keep me posted,
Hope that help's!
Nov 18, 2010 | Canon imageRUNNER 4570 Copier
Copier will not feed copy paper from tray into copier?
you might have a paice of paper blocking the feed tires,pull your paper tray out and look in the copier whear the tray goes in to see if you have a sheet of paper in their.
Apr 21, 2010 | Sharp AL 1631 Copier
How to clear code on ir 3235?
wich code?
E000, E001, E002 You can clear under service mode:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
TURN OFF AND ON
Hope that helped
pls.rate
Apr 17, 2010 | Canon ImageRUNNER 3235 Black and White...
E-5 light is on. What does that mean? Can't use copier at this time.
When the copier detects the E507 condition, "E-5" is displayed in the copy counter. Hold down the "·" key, and "07" is displayed in the copy counter.
for reset thiscode.
It would be necessary to know as it is the code to be able to help it better
Mar 25, 2010 | Ricoh FT5832 Copier
I have a Minolta cs pro 2080 copier, shading on copies
3 possible causes:
1) The optics are dirty thus making your copy darker. The test for this is to manually lighten the copy using the exposure control on the panel of your copier. Lighten the copy several positions and see if the copy gets better. If it does then the optics need to be cleaned.
2) The copier is overtoned. This means that the toner to developer concentration is to high. This will require a trained technician to lower the toner ratio and then recalibrate the toner/developer ration using the F8 mode.
3) If the shading gets much worse as you run say 10 copies in a row then the drum cleaning blade would be the cause. So run 10 copies of something and compare the first copy out with the tenth copy out. Do you see a dramatic difference in the amount of background or "shading"?
Good Luck and thank you for using Fixya.
Mar 16, 2010 | Minolta EP4000/5000 CS/PRO Copier
Canon imageRUNNER 3570 Copier Logo
42 people viewed this question
old marine
old marine
