Question about Toys
Robopac Robot 2001 Manual
Stretch wrap machine
How to stew a stretch stitch
If your machine has a built-in stretch stitch, consult the owner's manual. However, a zig-zag stitch is also considered a stretch stitch--it doesn't use as much time or thread as a built-in stretch stitch...
Dec 13, 2017 | Sewing Machines
Can't find the stretch stitch on my singer xl100. Where is it?
Here's the manual:
Singer Quantum XL 100 Instruction Manual
I did not find a stretch stitch in the manual. FWIW, a zig-zag stitch works in place of the stretch stitch. It is also much faster and uses less thread.
Oct 13, 2017 | Singer Sewing Machines
Which is the stretch stitch on my elna club 500
Here's a copy of your owner's manual:
ELNA 500 ELECTRONIC Manual Page 16
Although it does not show a "stretch" stitch per se, there are several that can work. Machines without any stretch stitch can simply use a zig-zag.
Jun 10, 2016 | Elna Sewing Machines
Elna 2005 I don't have the manual. Which setting is for the stretch stitch?
A special stretch stitch is not required to sew stretchy fabric. All one needs is a zig-zag that is wide enough and close together enough to allow the fabric to stretch without breaking the stitching thread. (Test it on a piece of scrap fabric you are using, give it a good tug and see if the thread breaks.)
NOTE: be sure to use a ball-point needle. A sharp needle will tend to cut the fabric threads and your stretch fabric will eventually develop holes and runs commonly found in knits.
There doesn't appear to be a manual for your machine, however, you can usually find a manual close to your machine model and the instructions will be similar enough to suffice. Perhaps you will find one with instructions for sewing stretch fabric:
ELNA Other manuals
Jan 10, 2016 | Elna Sewing Machines
Where can i find a free download sewing machine manual for a stretch pinnock model number 5201
http://homeappliance.manualsonline.com/manuals/mfg/brother/vx1435_2.html
Jan 21, 2015 | Sewing Machines
Stitch length dial is stuck on SS
Likely broken threads wrapped around internal components. Have it prefessoinally serviced.
Jan 09, 2014 | Brother XR-65t Mechanical Sewing Machine
Sews fine on cotton, but skips on synthetic stretch cloth. Manual doesn't really offer a suggestion.
Needs to be a ball point needle for stretch fabric, sounds like you are using universal sharp needle. Stretch fabrics require ball point to push between the fibres, also, a slight zig zag stitch is more durable as when you stretch the garment during wear a straight stitch will often break, need some elasticity in the seams. Some machines have a stretch stitch too.
Oct 31, 2012 | Elna Xplore 8600 Computerized Sewing...
How to fit belt to wmm39a
Use a tie wrap to hold the belt it in position on the main pulley. Hold the belt in position on the small pulley while rotating the drum to wind and stretch the belt around the main pulley. Once on, cut the tie strap and discard.
Jan 30, 2011 | Hotpoint WMM39 Front Load Washer
Toys Logo
605 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
