Question about LG RHT397H DVD Recorder
Stuck hello issues - LG RHT397H DVD Recorder
Check the capacitors on the power board to see if any are bulged i had the same problem with a rht498h and found it to be a bugled capacitor on the power board
Posted on Apr 17, 2013
Ice doesnt come out of ice maker , seems to get stuck. Have to stir ice around
Hello Phyllis Hopkins, thank you for your inquiry!
It sounds like you could have a possible issue within the dispenser, auger, or auger motor of your Frigidaire refrigerator. Since it could be any one of these underlying issues I would recommend having a technician come out to properly diagnose and repair your appliance to avoid any unnecessary part purchases. -Matt
Sep 08, 2014 | Frigidaire Refrigerators
Samsung L 301 digital camera lens stuck half way out help please westlynnhouse@live. co. uk.
Hello
Unfortunately this issue indicates lens damage to the camera and is not something that you will be able to fix. This issue requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Mar 18, 2011 | Cameras
Heat blows only when car is in drive when coming to stop light it blows cold air. Have added more coolant but it has not fixed the problem
You problem sounds like a "Blend Door" issue, you have these doors that open & close and everything in between to adjust air temp. These doors have a "peg" that is connected to an arm or wire just like on a ten speed bike to shift gears, that peg may have broken off.
Another issue may be a stuck open thermostat, if you have a temp gauge is it running at normal temp? If the thermostat is stuck open then heat may become an issue.
I have found several 2007 Chevrolet Impala blend door issues here in fixya.com.
Hope this helps.
Dec 29, 2010 | 2007 Chevrolet Impala LS Sedan New Cars
Hello, the 'Fn' key make me type numbers and
press Fn + nmLk, it will resolve the issue.
Oct 14, 2010 | Lenovo 3000 Y410 Laptop
Hello paper jam error appears with no paper jammed. Then printer refuses to print or doesn't print well
To resolve paper jam issue, follow the steps
1. Open the rear access door.
2. Remove any bits of paper stuck.
3. Clean the rollers using lint free cloth ( upward position )
4. Close the rear access door
5. Open the front panel door
6. Check for any paper stuck between the rollers.
After doing all these steps, to make sure if your printer is working fine, try to make a copy.
If the printer can make copy, Click on the link to resolve printing issue -> Link
Oct 12, 2010 | HP Photosmart 2575 All-In-One InkJet...
Cant get rid of the popup menu for contrast on my monitor. it keeps popping up and none of the other buttons respond.
Hello
It sounds like the button is stuck and is overriding all other buttons.
If the button is not stuck, then the monitor is having other issues and is probably going out.
Assuming the button is stuck - Unplug the monitor from power, use isopropyl alcohol and cotton swabs to clean around the edges of the button.
Dec 03, 2009 | Soyo Computers & Internet
Paper Jam Toshiba 250
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
Thanks! mannu_rakesh
Aug 31, 2009 | Office Equipment & Supplies
Paper jam check drawer two t640 printer
Hello there,
If you are getting "Paper Jam check drawer two message" I would suggest you to check for any paper stuck inside the paper drawer two. If you don't see any paper jammed inside drawer two, you might also want to check out if its is stuck anywhere in the paper path. Removing the paper jam should fix the issue. Try cleaning the pick rollers (the rollers which pick the paper) in drawer two. This should help fixing this issue.
Merry Christmas!
Aug 20, 2008 | Lexmark T640 Laser Printer
Toshiba DVD player gets stuck on certain scenes and won't play!
Sounds like it is not changing layers on a multi layer DVD. Replacement will of course fix this issue as the new ones will be compatible with newer system DVDs.
Oct 17, 2017 | Televison & Video
LG RHT397H DVD Recorder Logo
496 people viewed this question
Computer Repairing
Computer Repairing
