Question about Dell 1600n All-In-One Laser Printer
Printing is faded and too light
The text is printing "faded". It is too light. The print just isn't dark enough.
The print quality is set to "text". All other settings appear normal, as far as I know. (But what should they be?)
The toner level is reported at 35%.
Thanks in advance for any suggestions.
  • OMAX Nov 03, 2008
    I have the same issue with this model
  • 3 Answers
More important than all that nonsense is:
is it faint when you do an internal report or make a copy?
if only on copies it is the film on the underside of the glass.
if on prints and copies it is the drum.
Posted on Dec 02, 2008
  • Alicia Mar 08, 2013
    prints are fine but copies are faded, What can I do to fix this?
    Sniper:
  • 53 Answers
Faint printing can be caused during the transfer phase of printing. There are 4 items to check, Biased transfer roller, this is what transfer the image to the paper. High voltage power supply, if this is not working properly, you can get faint print. The drum, if this is damaged in some way, it can also affect faint printing.
Faint printing can also be involved in the exposure phase of printing. In this phase the items to look at would be the print head, drum and the low voltage power supply.
Faint printing can also be involved in the development phase of printing. The items involved in this phase would be the drum and toner.
Faint printing can also be involved in the charge phase of printing. The items to look at in this phase is the drum, high voltage power supply and the charge roller.
One over looked cause of faint printing is not having the printer plugged directly into the wall outlet. A laser printer uses alot of electricity. It may work fine for a period of time plugged into a power strip, but there is always the chance that it will fail and you will get odd issues with the printer. You definately do not want to plug it into a UPS, for the same reasons as a power strip, but it is more likely to show itself sooner.
The first item that would be the easiest to replace would be the drum, the next would be the toner. The other items would more then likely require a tech to replace.
Posted on Nov 26, 2008
I had the same problem and I just fixed it.
It turns out that the toner cartridge I was using was not an authentic Brother cartridge. It was an Office Max knockoff.
I replaced the knockoff with an original BROTHER toner cartridge and BAM! Right back in business.
What tricked us for so long was that the knockoff worked for two weeks before it conked out, so while we were looking for the problem, we kept saying to ourselves, "No, the problem COULDN'T be the toner cartridge. It's practically brand new."
Hope this helps.
Posted on Jan 20, 2009
Why is my printer not printing the right color? its very faded
Is your printer set to Economode in the printer settings? It may be and so its printing at low quality.
Jul 16, 2014 | Xerox Phaser 7400DN Laser Printer
HP LaserJet 1007 Prints Light
First of all check your printing preferences
  1. Right-click the product icon, and click Printing Preferences to open the Printing Preferences window.
  2. Click the Paper/Quality tab.
  3. Check the paper or media type setting.
    1. Find the Type is: drop-down list.Figure 1: 'Type is:' drop-down list in the Printing Preferences windowc01855301.gif'Type is:' drop-down list in the Printing Preferences window, Paper/Quality tab (screenshot)
    2. Select the paper or media type you are using.
      • For thinner paper, select Light , Thin , or Vellum .
      • For thicker paper, select Heavy or Thick .
      NOTE:HP does not recommend the use of heavily textured paper, extremely thin paper, or paper with a basis weight heavier than 90 g/m2 (24 lb).
  4. Make sure the paper or media type setting is appropriate for the fuser temperature.NOTE:Unlike ink printers, laser printers use heat to fuse a plastic toner to the surface of the paper. Make sure to use heat-resistant paper, and labels and envelopes that use adhesives compatible with the heat and pressure of the product's fusing process.
    1. If you are experiencing any issues in the following list, adjust the setting.
      • If the paper is curled or wavy , try the following:
        1. Decrease the fuser temperature setting. To do this, select Light ,Thin , or Transparency .
        2. Use the archive print feature to improve toner fusing. To do this, select Archive or Bond .
      • If the printout has areas of fuzzy or dark print , or toner scatter , increase the fuser temperature setting.
        1. Select Heavy or Thick .If this does not resolve the fuzzy, dark print, or toner scatter issues, use a lower basis weight or thinner paper.
  5. Click Apply .
Step three: Check the print density settingsFollow these steps to check the print density settings in Printing Preferences and in Properties.
  1. In the Printing Preferences window, click the Paper/Quality tab, and find the Print Quality section.Figure 2: 'Print Quality' section in the Printing Preferences windowc01855302.gif'Print Quality' section in the Printing Preferences window, Paper/Quality tab (screenshot)
  2. If you are experiencing any issues in the following list, adjust the settings.
    • If the entire page is too dark , change the dpi setting, and turn on EconoMode .
      1. Select 600 dpi from the drop-down list.
      2. Select the EconoMode check box.
    • If the entire page is too light , change the dpi setting, and turn off EconoMode .
      1. Select FastRes 1200 from the drop-down list.
      2. Clear the EconoMode check box.
  3. Click Apply , click OK , and then close the Printing Preferences window.
  4. Open Printer Properties. To do this, right-click the product icon, and click Properties .
  5. Click the Device Settings tab, and find the Print Density section.Figure 3: 'Print Density' section in the Properties windowc01855303.gif'Print Density' section in the Properties window, Device Settings tab (screenshot)
  6. If you are experiencing any issues in the following list, adjust the setting.
    • If the printout has areas of gray shading or a gray background , decrease the print density setting.To do this, slide the bar to the left .
    • If the printout has light, dull or faded areas , increase the print density setting.To do this, slide the bar to the right .
  7. Click Apply , click OK , and then close the Properties window.
  8. Try again to print.If these steps do not resolve the light, dull or faded issue, the print cartridge is almost empty. Skip to Solution eight: Replace the print cartridge .
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , see the next solution.If this don't help you, here is instructions for refilling a toner cartridge.
http://www.uninetimaging.com/downloads/technical/hp/english/HP_P_1006_Reman_eng.pdf
Maybe you need to clean the drum, blades or the developer roller. Maybe the problem is in the toner you use.
Jul 08, 2012 | Office Equipment & Supplies
In my ir3300 xerox in very light
That means that you have to clean copy glass , lenses, ccd,...maybe even laser unit if you know how.
On digital machines dirty optics means light copy, on analog oposite, dirty optics dark copies.
Just one more question how do you mean " charge toner"?
Jun 07, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
Zebra lp 2824 faded printing
Many factors affect print quality: Heat settings, speed setting and label face stock quality and type are a great place to start. How old is your printer? How many labels have been printed through it (there is an odometer that tells your this on the config label). Is the printhead dirty? Use > 90% isopropyl alcohol on a cotton ball or microfiber cloth to gently clean the printhead.
I would start by checking the heat and speed settings in the driver - crank up the darkness and crank down the speed a notch or two at a time until you get the print quality that you are looking for. If all of this fails, you may need a new printhead (not too easy to replace on this model). Printheads are made up of an array of resistors. These can loose their electrical resistance over time and require more energy (controlled by the darkness setting) to get the same results as a new printer. Printheads, like labels and car tires are considered a consumable commodity.
Jan 14, 2010 | Zebra Eltron LP 2824 Thermal Printer
How do I adjust the darkness of the printing, it is currently set at 2 out of 4 darkness?
You will need to follow below process.
Print quality settings always affects on print resolution and toner usage.
to change print quality setting:
1. go to Start/settings/control panel/printers
2. then go to printer's properties.
3. go to paper/quality TAB. and select the setting that you want to use. you will get following options.
a) 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
b) 1200 dpi effective output quality: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
c) 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology (REt) for improved text. (this is what you may need to get)
d) Economode: this settings use less toner of your printer. This is useful for mostly draft printings. You can turn this button on freely of other printing-quality settings.
Select the needed settings. Test a print.
And if it is perfect you wont be charge to give recommendation...lol
Aug 12, 2009 | Samsung SRP 350 Thermal Printer
Can't figure out how to adjust darkness/tone for printer output
Below you can see a step by step procedure on how to change the print quality of your work....you need to make test printouts in order for you to see the results....at the end there is a link to the manual for your printer...GOOD LUCK!!!
Print-quality settings affect print resolution and toner usage.
Use the following procedure to change print-quality settings:
1. Open the printer Properties (or Printing Preferences in Windows 2000 and XP).
2. On the Paper/Quality tab or the Finishing tab (the Paper Type/Quality tab for some Mac drivers),
select the print quality setting you want to use. The following options are available:
● 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
● 1200 dpi effective output quality: This setting provides 1200 dpi effective output quality
using FastRes 1200.
● 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology
● EconoMode: Text is printed using less toner. This setting is useful when you are printing
drafts. You can turn on this option independently of other print-quality settings.
Manual
Apr 13, 2009 | Office Equipment & Supplies
Printing from online comes out very light
Typically, the quality of images and text on websites is very low resolution to keep the file size down in order for them to load more quickly on your screen. Just because it looks good on your screen doesn't mean it will print the same. There are just fewer dots per inch in the text and images and they can appear faint and low quality when printed. Look for a print icon on some web pages as it will be at least formatted properly to fit the page and some are of better quality than printing what is on the screen.
When it comes to emails, if the text is in a color, especially blue, they will tend to print light. Change your printer settings to print grayscale and that should help sharpen things up about as much as is possible.
sharvey400
Dec 03, 2008 | HP Office Equipment & Supplies
Text becomes unreadable after one page of printing
model of the printer ? sound like a
heating device problem.
Aug 10, 2008 | Dell A920 InkJet Printer
Phaser 6250 black toner is super light
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Click on Knowledge base from this site , then in the search box enter poor black quality. Look under black is faded or missing
Apr 08, 2008 | Xerox Phaser 6250N Printer
Dell 1600n All-In-One Laser Printer Logo
4,776 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
