Question about Hoover Washing Machines
Hoover HSWD166 heater fault - Hoover Washing Machines
2 Suggested Answers
SOURCE: HOOVER HSWD166 Washing Machine stop
Well, with just this symptom, it's pretty hard to tell exactly, and so, rather than tell you here i have given you a link to download a service manual, in here are all the troubleshooting steps that you should perform to isolate and hopefully remedy your issue.
http://elektrotanya.com/hoover_hswd166.pdf/download.html
below is a DIY, How To website to assist you also.
http://www.acmehowto.com/howto/appliance/washer/washer.php
Posted on Jul 11, 2011
Hoover VHD sensor Dry shows Eo8 vibrate badly and stops any suggestions please regards Peter
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/specific-faults/3070-hoover-vision-hd-washing-machine-fault-codes.pdf
Mar 09, 2015 | Hoover Washing Machines
Hot point ariston aqualtis condenser dryer fault code f07
F07
Heater relay stuck
Check wiring
Check electronic control PCB
Jun 21, 2014 | Hoover Dryers
Aqualtis fault code f07
Heater relay stuck
  • Check wiring
  • Check electronic control PCB
Jun 21, 2014 | Hoover Washing Machines
Hoover hnd325
It's probably the heater element that has gone, but it could be a simpler fault like the pressure switch not activating. See this video it should give you the general idea
Aug 04, 2013 | Dishwashers
I have a hoover wmh148df washing machine which keeps coming up with fault code E05 can anyone help me find out what this is
Hello there,
E05 is a temperature sensor fault.Now there are a few things to check before replacing the sensor. Remove the back panel on the washer. There is a heater on the bottom. On the side is a circular sensor with a couple wires attached to it.
First make sure all wires are connected.
Try tracing wires to board to make sure they are not cut or disconnected along the way.
If wires are good remove sensor and check for scaling on surface.
If scaling is present clean the sensor then put it back on and try a load. If problem persists you will need to replace the sensor.
Now sometimes the main board can cause this.
If all else fails replace the board.
Nov 01, 2012 | Hoover Washing Machines
What is error code 16
If it is an Optima with a brushless motor (I only have those fault codes for Hoover), 'E16' means 'water heater element insulation fault'. Sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 31, 2011 | Hoover Washing Machines
E14
E14 is a Heating fault. Check heater and associated wiring, Check thermistor/thermostat, or it may be the module.
Jul 30, 2011 | Hoover Washing Machines
Eo5 keeps coming up
Indicates a fault with the heater or the thermistor (temp. sensor). Both located at the bottom rear of the drum.
Jan 14, 2011 | Hoover AAA140 Front Load Washer
Hoover HW5513M cuts out the main RCD trip during a wash program
take back off and check heater for faulty to earth. one way is to disconnect heater, run machine and see if fault has gone
Sep 09, 2008 | Hoover Washing Machines
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
