Question about Innovera Mini Wireless Optical Mouse IVR62102
Installing I dont have the manual. I thought all I needed to do was plug it up and click the connect button on the mouse
  • 1 more comment
  • krstluv Oct 23, 2008
    it's ivr62102
  • Anonymous Dec 10, 2008
    i plugged it it's not working
  • iambrose Jan 20, 2009
    i need the install disk for this unit ivr 62102
    President:
  • 2,712 Answers
Can you give me the make and model of the mouse pls?
Posted on Oct 23, 2008
The disk that came with my mouse wont fit in my computer
Posted on Oct 27, 2008
  • kumisawalker Oct 27, 2008
    innovera wireless optical notebook mouse ivr-61020
Connect my leeds 1690 wireless mouse to my laptop
hi Shon.
Connecting a Mouse with a Wireless Receiver.
Plug in your mouse's receiver. The receiver should fit into one of your computer's USB ports. You can typically find USB ports, which are thin, rectangular slots, on the sides of laptops and on the front of desktops' CPU boxes.
  • Plugging in the receiver before turning on the mouse will allow your computer to install any drivers or software needed to use the mouse.
Make sure that your mouse has batteries. To do so, you'll typically flip the mouse over and remove a tray on the bottom, though some mice instead have their batteries in a compartment in the back of the mouse.
  • If you haven't used the mouse in several months, consider replacing the batteries even if they were new when you inserted them.
  • Some mice, such as the Apple Magic Mouse 2, require charging instead of new batteries.
  • 3
    Turn on your mouse. This typically involves manipulating a button on the bottom of the mouse, though you may need to look for the On/Off switch on the side of the mouse.
    • If you can't find the On/Off button, consult your mouse's manual.
    Press your mouse's "Connect" button. This button's location will vary based on your mouse's developer, but you'll usually be able to find this button either between the two mouse buttons or on the mouse's side.
    • Some mice come listed as "plug and play", meaning that you don't need to manually connect them or download any software.
    5
    Move your mouse around. Once you see the cursor begin to move on-screen, your mouse is connected.
    • If your mouse doesn't start moving, try turning it off and then back on. If applicable, you may also want to change the USB port into which the receiver is plugged.
    this link will help you out some more if you need it.
How to Connect Wireless Mouse
Dec 08, 2017 | Leeds Computers & Internet
How do i disable touch pad when mouse is in use
      Click the "Start" button and click "Control Panel." Click "Hardware and Sound" and click the "Mouse" link under Devices and Printers to open the Mouse Properties box. Click the "Touchpad" or "Buttons" tab depending on your PC, then select the "Disable" option next to thetouchpad installed on your computer.
      How to Disable TouchPad While the USB Mouse Is Plugged in
      smallbusiness.chron.com/disable-touchpad-usb-mouse-plugged-52685.html
    Feedback
    How To Turn Off Touchpad When Mouse Is Connected In ...
    www.intowindows.com > Windows 10
    Dec 14, 2015 - How To Turn Off Touchpad When Mouse Is Connected In Windows 10/7/ ... who always use a mouse and don't want to use the built-in trackpad ...
    How to Disable Your Laptop Touchpad ' PCWorld
Jan 31, 2016 | Toshiba Satellite C655D-S5120 Notebook
How di make my mouse work
usb mouse or mouse bad ?
Look at the type of mouse you have.
To date, there are three types of mice: the USB mouse, the PS/2 mouse and the Bluetooth mouse.
USB mice connect with a USB adapter, which has a rectangular shape. Conversely, the PS/2 mouse uses a PS/2 adapter, which is round.
Finally, there's the Bluetooth mouse, which has no external adapters.
Plug the mouse into your machine.
Now, how you do this will depend on the mouse you're using.
With a USB mouse, simply plug your device into your laptop's USB adapter, which will also be rectangular in shape.
For PS/2 mice, you'll need to plug it into a PS/2 adapter. Plug your mouse into the PS/2 end then plug the other end into your laptop's USB adapter.
And for Bluetooth mice, no plugging is required.
Install the mouse drivers.
If your mouse is not plug-and-play, you're going to need to install its drivers. To do this, insert the CD or diskette that came with your device.
The installation should occur automatically.
Pair your mouse, if using a Bluetooth mouse.
At this stage, non-Bluetooth mice are ready to be used.
However, if you are installing a Bluetooth mouse, you must perform one additional step: pairing it to your machine.
To achieve this, use your laptop's touchpad and right-click on your Windows screen. Select the option "Pair Device." From there, follow the on-screen instructions to sync your mouse with yourcomputer.
Place your mouse onto a mouse pad. Before using your mouse, you need to place it onto a mouse pad.
This should be done for all types of mice, whether they are wireless or trackball.
Otherwise, movement will be difficult
mouse pad
Examine your mouse pad.
Dirt and grime can affect performance and slow down mouse sensitivity, if not shut it down altogether.
Make sure the surface of the track pad is clean and that there is nothing that has managed to get beneath it or around any trackball buttons that could affect the pressing and depressing of the component.
Check to see if your mouse pad has been turned off.
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option. Click on it and you will see the option to enable your device, then click OK. If this does not work,
Check the manufacturer of your laptop (for example, Toshiba) and then navigate to their official website. Find an area for Software and Drivers, and move on to that area.
Enter your laptop number (check your documentation/manuals and/or the bottom of the computer) and look through the drivers that are presented as a result of this number input.
It could be that your mouse pad simply needs updated drivers. Find the driver that corresponds to your computer and mouse pad (for example, most Acer laptops use a Synaptics touch pad).
Then, click on download.
Once the drivers have downloaded, double click them to ensure they install, restart your laptop, and your mouse pad should be working again.
hope this helps
Sep 09, 2012 | Compaq Presario CQ57-339WM
I have a problem with the mouse for 5euro This technique tknm110 mouse and the problem that I have a normally lit mouse is a optical mouse, but mouse does not work ... it's two the same, at first I...
Hello ania1997,
I've seen this 'problem' before.
First, disconnect the "Mouse."
Next, click on the "Start Button."
Now, click on the "Control Panel," in the 'start menu'.
Scroll in the Control Panel, and select the "Mouse" applet!
Open the [Mouse Properties], by 2x clicking or,
Right clicking,and open.
From here you want to [Disable the Touchpad Device].
!Beware, that now, you may have to "Manually Navigate."
Without the 'mouse; you will use the "Tab, Arrows, and 'Enter' buttons,
to perform tasks, if the 'optical mouse' doesn't work the first time.
"Restart the computer."
Connect the "Optical Mouse."
"The {Mouse should be detected automatically}."
If you need help with anything else?
"Write a 'comment'; I'll be here to assist you!"
"Best Regards"
Jul 28, 2011 | Computers & Internet
How do i get mu souris wireless mouse to work?
if your OS is Vista or Windows 7, you dont need to installed its driver.... all you gonna do is placed a new battery to the wireless mouse, plug the USB of its interface, start the PC, wait until it was properly detected and installed by System....... then pressed the "connect button" located at the bottom of your wireless mouse and at the interface module, and Presto!!!........... Goodluck!!!
Feb 27, 2011 | HP Wireless Optical Mouse
Cant click on anything..
If the red sensor that glows (on the bottom) is not on or flashing, you need new batteries. In that case, pry open the battery cover and replace. If it is on and it's not working. Try one of these things.
  1. Click the reset button on both, the mouse and the usb adapter.
  2. Making sure the device is installed properly, if not you might need a new mouse.
Hope this helped. Message me if it does or doesn't and I'll try to help more. (I have a Targus wireless mouse for my Toshiba laptop)
Good luck.
Jan 03, 2010 | Logitech Cordless Mouse
How do I install/begin using wireless mouse? It worked before then batteries ran out and I can't remember if I need a disc to re-install.
Most Logitech wireless mouse are just Plug-n-Play and it does not require any driver installation. All you have to do is to plug the wireless dongle to the computer and connect the mouse. Here's what you need to do:
1. Make sure that the batteries are fresh or fully charged.
2. Turn ON the mouse using the switch button.
3. Locate the connect button on the dongle (receiver) and then press it once.
4. Hold down the connect button underneath the mouse for 5 secs. and then release it. And the mouse should work.
If the mouse is not responding, then hold down the connect button on the dongle and on the mouse at the same time for 5 secs. and then release them both. Move the mouse around.
Hope this helps and have a great day!
Jul 17, 2009 | Logitech Cordless Mouse
Razer Mamba Problem
I had this same issue when the software hung. I thought my mouse was dead(no lights, no response when plugged in on my Vista machine). The way I solved it was to goto my XP machine(this may work in Vista 32bit too but I have 64bit and didn't wanna chance it) and install the firmware update software.
After installing the software, run it and get to the screen that tells you to hold down the pairing button when connecting the mouse. Then make SURE your mouse is turned OFF via the ON/OFF switch on the bottom, then HOLD the pairing button on the bottom of the mouse and connect the USB cable. When you do this, you should see a note that XP sees a bootloader and it will want to install a driver for it. Let XP install automatically. When it is done installing the driver, click next on the software screen and it should say it sees the mouse and the UPDATE button should be green. Click it and it will update. This should work, even if it looks like your mouse is dead(no lights when plugged in and not being recognized properly).
The key parts are make sure the mouse is OFF(vai the switch on the bottom) before starting and also make sure you hold the pairing button down when connecting the USB cable. If your system doesn't see a bootloader when you connect the mouse, the update won't work properly.
Jun 21, 2009 | Computers & Internet
User manual for lx6 cordless optical mouse, logitech
i have logitech LX 6 cordless optical mouse... it dont work... i put in usb that connecting mouse and then turn on (mouse). The problem is that is worked maybe 2 hours ago...and now dont... can you help???
Jan 23, 2009 | Logitech Cordless Optical Mouse
Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Jan 22, 2009 | Dynex Wireless Keyboard/Optical Mouse...
Innovera Mini Wireless Optical Mouse IVR62102 Logo
455 people viewed this question
Top Innovera Computers & Internet Experts
Mister Danger
Foxgrove
Level 1 Expert
Are you an Innovera Computer and Internet Expert? Answer questions, earn points and help others
