Question about LG LRSC26920TT Side by Side Refrigerator
LRSC26920SW side by side refrigerator powers off and must be plugged in to fix
Powers off and must be repluged to repair
Heated seats
could be that a separate fuse runs the element to heat the seat, or relay. try unplugging the connector under the seat and replug in to see if that fixes it. check for power at the feed side of the loom plug before you replug it to the seat .
Sep 08, 2014 | 2003 Mercury Grand Marquis
Repeat, corrected model number
Try unplugging the fridge and replugging it in. On this model if it doesn't cool, the display/temperature reading for the unit may start beeping like crazy. Resetting it sometimes fixes this. If you hear the compressor motor kick on, and it doesn't cool within 24 hours, your fridge will need a major repair. If it doesn't turn on at all, you may need a less expensive repair.
Nov 27, 2013 | Frigidaire FRS3R5EMB Side by Side...
Is there a reset button somewhere on my frig? My children left the freezer door open and now my frig isn't working.
Unplug for about 5 minutes and then replug power. This in most case's will reset the motherboards memory. After this possible solution I will not be allowed to send a clickable link to a Service Manual to assist you but I can send you a link to your models exact model providing your model was made for the America's LG, Whirlpool, GE, Etc: and most Refrigerators design's and that you are able to locate you model number. To contact me click here=> appl...@yahoo.com
Thank You, Sea Breeze
Refrigerators
Freezers
Jun 04, 2011 | LG Refrigerators
Kitchen aid superba architrend series s/s refrigerator purchased in 2001 when house built. Everything in freezer thawed today, pulled, took cardboard off back and cleaned with sweeper then replugged and...
Call someone to look at it. There is a fuse that can be replaced but I have no idea what was damaged. $200 repair if possible $85 tech visit if no repair possible
Jan 27, 2011 | KitchenAid Superba Architect KSCS25INSS...
Hello, My Bosch B22CS50SNS Side by Side Refrigerator no longer has lights in the refrigerator or freezer section. The control panel on the freezer door does not have power and does not function. The...
The solution for this problem is to in plug the fridge and wait then plug it back in If that does not fix it thenyou need to call the company and see if they can give you a quote of how much it will cost to fix it and there is a way to make the repair cost less is to purchase an extended warranty and then have them come and fix it
Jan 02, 2011 | Bosch B22CS80SNS (220 cu ft) Side by Side...
No power to the side by side refrigerator
replacing the mother board is the option that a repair person uses if they are authorized on the back of the unit there is a square plate remove it and you will see the mother board. on the bottom right of the mother board is the culprit fuse. its soldered in. you will have to go to an electronic store and get another fuse and either replace it or have them replace it for you. i went to radio shack and picked up the fuse holder, soldered it in and in the future will only need to replace fuse.
Good luck..............
Jul 28, 2010 | Kenmore 57029 Side by Side Refrigerator
Refridgerator side is freezing while set to the lowest setting
usually the most times a thermostat will go will be upon moving ref to different location or unpluging it and repluging back in later would go with replacing thermo. hope this helps
May 21, 2009 | Amana ASD2628HE Side by Side Refrigerator
Went to put groceries in frig and found it not on
yoor lights should be on at the very least, i would check the outlet , plug in a hair dryer or something, no internal lights means you have no incoming power supply
Dec 17, 2008 | Maytag MCD2257HES Side by Side...
Maytag msd2756de side-by-side: loud clicking noise from top right of refrigerator
sounds like the adaptive defrost controller part number 61005988. not to bad to repace, the top control panel is removed by pulling down on both rear corners ( youls find little finger holes across the top rear panel to free and pulll foward, the n there are 2 1/4in screws across th efron of control, and 2 phillips head screws jus behind each light bulb, one last 1/4in screw directly on back wall will drop entire panel adn after that youl see the control in the right hand corner unplug the old replug the new . DISCONNECT POWER PRIOR TO REPAIR<
Oct 22, 2008 | Maytag MSD2756G Side by Side Refrigerator
LG LRSC26920TT Side by Side Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
