Question about Gateway Computers & Internet
I get a message disk failure check cable when I try to boot my gateway 564GE computer. What does this mean, and what do I need to do
    Sergeant:
    Champion:
  • 390 Answers
Try replacing the sata cable that goes from the hard drive to the motherboard.if that doesnt work then move the sata cable to another port on the board.
Posted on Feb 10, 2012
mikaljalil
  • 15 Answers
SOURCE: DISK BOOT FAILURE
If you reinstalled the memory correctly it should fire right back up. But try this, when press the power button, hit delete and go to set up, under PC management find the Boot Order String, select the Floppy as the first device if you have one, the Hard drive as the second Device and the CD/DVD as the last device. Should go straight to the hard drive as the primary boot device. Hope this helps.
Posted on Jul 05, 2008
alxz
  • 89 Answers
SOURCE: disk boot failure
sounds like a hard disk drive problem. If you are comfortable with working inside your computer, you can open the case and remove the cables to the hard disk, and re-connect them again firmly.
Posted on Jul 07, 2008
  • 397 Answers
SOURCE: my laptop says a disk
"PXE-E61 MEDIA TEST FAILURE CHECK CABLE"
This means that the motherboard and harddrive are not communicating correctly, there is no data cable to connect the harddrive to the motherboard on a laptop the harddrive connecting plug is soldered directly to the the motherboard.
Either your harddrive is dying, or your motherboard has gone faulty. Laptop repairs are quite involved, if you are not familiar with taking laptops apart I would suggest you get profesional help with this problem.
If you want to have a go yourself I can point you in the direction of websites I use when doing laptop repairs.
Posted on Sep 10, 2008
  • 82 Answers
SOURCE: Disk Boot Failure
Any system can be recovered, although it depends on what is wrong.. this error can mean no info on the hard disk, or damaged hd...more than likely whoever had the computer erased it for data's sake...I would've...get an os and load it.
Posted on Aug 08, 2009
  • 2678 Answers
SOURCE: PXE-E61 media test failure check cable
Your unit is telling you that there is a cable problem (between HDD & MoBo) try a new one or if you have another drive with same cable swop over.
Posted on Sep 18, 2009
Display PXE-E61: Media Failure, Check Cable PXE-MOF: Exiting Intel Boot Agent Will not boot to windows. I boot from the hard drive and still get an error
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 25, 2012 | Gateway MX8741 Notebook
Gateway nv7915u error message i'm getting is pxe-e61 media test failure check cable pxe-m0f exiting broadcom pxe rom no bootable device--insert boot disk and press any key but when i do that nothing...
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Nov 04, 2011 | Gateway NV7915u Notebook
When I turn the computer on, I get the following message: PXE-E61 media test failure, check cable PXE-M0F exiting intel boot agent Reboot and select proper boot device or insert boot media in selected...
This happens when the BIOS can't find the hard disk. If you're lucky it's just the hard disk that has failed, if you're not it's the motherboard itself the one that failed.
To find out which replace the hard disk with a good one then try to boot in th BIOS - if you can it's the hard disk, if you can't it's the motherboard.
Nov 26, 2010 | Gateway 510 X (10272197) PC Desktop
When i start the laptop it shows media test failure,check cable exiting pxe rom os not found
Your computer is configured to try to "boot" from several devices:
* floppy-disk
* CD/DVD drive
* disk-drive
* network (via connecting to a "boot-server" on your local network)
So, "media test failure" means that no Ethernet cable is connected to the network-port on the computer. So, if you are trying to boot from a "boot-server" over the network, check that the Ethernet cable is connected, and check that the boot-server is processing boot-requests.
Thus, the PXE (Pre eXecution Environment) is exiting, because it cannot boot from the network -- no Operating System was accessible over the network.
So, enter BIOS SETUP, and disable the "network boot" option,
if no boot-server exists.
Also, put a boot-disk into the floppy-drive, or the CD/DVD drive,
or, most importantly, check that your disk-drive is working.
If your disk-drive is not getting power, or its "data" cable is not connected, or if the disk-drive has a problem, then Windows cannot be read from the disk, and so the computer tries an "alternate" boot-device.
Sep 03, 2010 | Computers & Internet
Have a gateway Mt3708 it started turning off on its own now I have no screen. I had gotten message reading as follows: YUKON Pxe V4.17.8.1 (alpa) (20060116) (C) copyright 2003-2006 Marvell (R) all rights...
when the logo comes on, press the "tab" key. It should turn the logo off and show you what the computer is doing. This may help:
THIS IS FOR HP AND COMPAQ USERS (it might help others as well)
i had the same problem with my compaq preasrio v6000.
ALL U HAVE TO DO IS
1- START UP UP UR COMPUTER AND PRESS F10
2-GO TO DIAGNOSTICS
3-RUN A HARD DISK TEST
IF IT PASSES THEN YOU JUST NEED TO RE-INSTALL TO YOUR OPERATING SYSTEM
IF NOT YOU WILL HAVE TO CHANGE YOUR HARD DISK.
Or try this:
Go into the BIOS.. Go into the BOOT options.. and hit Shift+1 to disable the Realtek boot option.. pop in the disk you want to boot from.. and make sure you set your boot options to CD-Rom and then HDD.. and just wait.. be patient.. and the blue screen (for booting) will show up! :)
Mar 15, 2010 | Computers & Internet
I have a latitude c610 and on start up a message saying media test failure check cable.can any one help.
Press F2 to go into the BIOS and reset it to factory defaults and reboot the laptop. If you still get the same message, go back into the BIOS and see if the hard drive is showing up in there, if it is then that means the OS has corrupt files and you would need to wipe out the drive and restore the laptop back to factory defaults.
If the BIOS doesn't show the hard drive in the BIOS then that means the hard drive is bad and would need to be replaced.
Jan 01, 2010 | Dell Latitude C610 Notebook
Hoow do you open gateway MX6440. No audio. Bootup
Typically, a computer tries to "boot" from several devices:
1. 3.5-inch diskette
2. internal CD-ROM
3. internal disk-drive
4. USB memory-stick
5. network (if a "boot-server" can be found on the network)
6. external diskette
7. external CD-ROM
8. external disk-drive
So, in your case, either
* the "boot-order" _EXCLUDES_ your disk-drive,
* your disk-drive is not connected,
* your disk-drive is connected, but is "dead" (not responding)
Not being able to boot from the disk-drive, your computer probes, via the network, for a "boot-server". Finding none, your computer reports, in a strange way, that "network cable is not connected to a boot-server".
So, the "check cable" means that the Ethernet cable between the network-port on your computer and the boot-server may be "unconnected".
What this could mean is that your disk-drive is "dead".
Take the computer to a qualified technician, for more trouble-shooting.
Nov 18, 2009 | Gateway MX6440 (6585) PC Notebook
My tosiba a70-kl1 starts up with a black screen and error messages stating "PXE-E61: Media tes failure, check cable" and "PXE-M0F: Eiting PXE rom"
You haved enabled the capability for your computer to "boot" itself by reading from a boot-server connected to your network-cable.
But, the network-cable is unplugged, resulting in the "check cable" message.
What this _could_ mean is that the computer primarily tried, and failed, to boot from your disk-drive, and secondarily tried, and failed, to boot from your CD-ROM, and so it made a tertiary triy, which failed, to boot from the "network", i.e., that your hard-drive is not functioning.
Reboot, and enter "BIOS setup", and disable the "boot from network" option, to get rid of those error-messages. But, it's still possible that your disk-drive is malfunctioning.
Sep 14, 2009 | Toshiba Satellite A70 Notebook
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
