Question about Garden
Small engine won't start
I have a craftsman ready start 21 inch 6.50 mower with a briggs and stratton motor. It has fresh gas, new plug, new key, the keyway is not damaged, gas to the plug. It's a 124T02, 3847B2. I can't get it to even act like it wants to start. Thanks for your help. Also plug gapped at 0.30.
  • wadingriver
    wadingriver Feb 16, 2012
    Before the new gas, was it left for months with gas in the tank?The Jet at the bottom of the Carburetor bowl can clogg easily with the junk they are passing off as gas these days.
    Sergeant:
  • 316 Answers
Hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.~~
Posted on Feb 20, 2012
  • 109 Answers
SOURCE: Craftsman 21'' Lawn mower won't start
In order for there to be a spark at the plug, make sure the plug is grounded to the engine, it will not "fire" if it isn't.
Remove the cover with the crankrope, there should be a thin black wire going to the coil, going to a ground lug that kills the engine. Try unplugging this wire and re-check the fire...if it fires, there is a fault in this wire and should be replaced. The mower will run without it, but will not stop without "choking" out the engine
Posted on Apr 16, 2009
  • 2692 Answers
SOURCE: can't find oil drain plug on eager-1 mower
Disconnect the sparkplug andf ground it. Turn the push mower on it side and scrap away all the grass from under the deck and look for the plug. If you cannot find one, drain the oil out from  the fill tube into a pan, buy turning it onto it's side into the pan.
Posted on May 06, 2009
  • 110 Answers
SOURCE: my craftsman push type mower (briggs and stratton
Most likely a blocked vent in the fuel cap. 3 mins is too long for a fuel system problem if that's not it, so if there's still a problem, suspect the ignition coil is failing when itt gets hot.
Posted on Oct 02, 2009
  • 75 Answers
SOURCE: gap setting for briggs-stratton 6.5 lawn mower
I believe it is 0.040 on a regular spark plug gapper
Posted on Nov 07, 2009
  • 152 Answers
SOURCE: LOOKING FOR A MANUAL FOR A 21" CUT SELF PROPELLED
try putting your serial number and model number here. http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
Posted on Aug 08, 2010
Craftsman 21 hp lawn tractor motor seems frozen
Did it leak oil & seize up
Can you turn it over by hand
Is a belt or bearing preventing the motor
from turning?
May 08, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a briggs & Stratton 675 series engine in a Craftsman front wheel drive rotary mower which won't start. It was fully serviced and used 3 times this season but now it won't start. It
if it has hit a object, the flywleel key is partially sheared, and needs to be replaced. they are very inexpensive,CHEAP. this will through the engine out of time just enough it wont start.
Apr 16, 2013 | Briggs & Stratton Garden
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Craftsman Mower - 625 Briggs and Stratton Engine. The mower starts after I prime it 3 times. Starts up and runs at only half speed. I have taken the whole thing apart, changed the gas, cleaned the carb,...
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
May 09, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Briggs and Stratton Troy Built 21inch 190cc 650 series Gas Powered self propelled Lawn Mower. I moved to new house and the movers lost the manual. I bought it last year so only one seasons use. How do I...
If how you described you unit is true you do not have an electric mower you have a gas powered mower, you DO NOT have a battery!!!??? Place the throttle lever to choke position and prime carb with primer bulb 3-5 times then pull cord. Wala!!!! It's running rite. That guy at Loews must have been smokin somthin. Good Luck...
Apr 22, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
My brand new Briggs and Stratton Lawnboy won't start!!!
if you play with it u will void the warrantee. call the dealer u got it from
Apr 02, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
190cc 3in1 briggs and stratton mower wont start... new plug and good spark..any ideas..
Take the carburator apart and clean it. Also, clean needle and seat. Please let me know if this helps.
Apr 24, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
372 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
