Question about Water Heaters
Combi Boiler - Running warm & then cold!? HELP!
I've got a Potterton MAIN COMBI 30HE boiler system.
The problem is it is producing warm(ish) water and then goes cold quite quickly and continues like this whilst running the shower/bath.
The Central heating is running fine and the RAD's are piping hot.
The boiler does fire when the hot tap is on - buts its very annoying when the water is cold... The setting is up as high as it can go for the hot water!?
Can anyone advise?? Thank you in advance!
DG
  • 3 more comments
  • willywoodhea Dec 26, 2008
    i have the same problem but when i isolate the cold flow in to the boiler i still get mains pressure at hot tap heat exchanger ok slight drip from diverter valve pushrod but microswitches are working boiler has been in 18 months and been ok
  • Anonymous Mar 13, 2014
    hot water running hot and cold even though tap is on
  • Anonymous Mar 18, 2014
    cannot get hot water
  • Anonymous Mar 25, 2014
    Mechanical Clock Problem
  • Anonymous Mar 26, 2014
    A 8LT WATER BOILER/TEA /URN.
  • 104 Answers
Mixing valve must be replaced
Posted on Nov 02, 2008
The problem was solved on my system by replacing thermostatic valve on shower and putting non return valves on hot and cold feed to shower . the problem was caused by cold water getting into the hot water line through the shower hope this helps
Posted on Dec 30, 2008
Why does it take two bowls of water before water gets hot on combi boiler
The water isn't maintained hot (unless the central heating is on) in a combi boiler. you will, therefore have to turn the water on, which activates the burner. The burner will then have to heat up the heat-exchanger which then supplies the hot water through cold pipes. Once the pipes are warm, you will receive hot water.
Jan 29, 2015 | Water Water Heaters
I have a Potterton Combi Puma 80e When I use the shower the pressure seems to drop and shower goes cold! except when the central heating is on shower works fine
Does the red status led in the centre of the control board come on when hot water is drawn? You need to remove ONLY the front decorative cover to see the control board, two fixing screws at the base of it. If not the boiler won't fire when the CH is off.
The trigger for this is a pressure switch, replacement of which is beyond DIY scope.
FYV
Feb 11, 2013 | Water Heaters
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
My potterton boiler ignites itself after turning it on then goes out
Assuming this is a combi boiler and you mean that the main gas burner comes on then off:-
How long after - 5-20 secs check overheat thermostat Check the wires to it are firmly in place i.e. making a connection. If Ok? then you can short this out by joining the wires together - do with boiler OFF at mains electricity
Longer - say 1-2 mins check secondary heat exchanger for blockage - usually furred up inside & only solution is replacement
Dec 22, 2009 | Water Heaters
Hot water
there are two main faults with combi boilers not giving hot water. one is a faulty flow sensor, the other is the most common which is a blocked heat exchanger caused by debris and scale in the system. this needs to be flushed out or may require a new heat exchanger depending on the age and condition of the boiler some plumbers may suggest a new boiler.
Mar 02, 2009 | Water Heaters
Combi boiler problem
most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
Jan 22, 2009 | Whirlpool Aquatic Millennium VII -...
COMBI BOILER /CENTRAL HEATING
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Nov 13, 2008 | Water Heaters
Water Heaters Logo
2,572 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
