Question about Samsung Televison & Video
Screen strobing intermitantly
Le46c580j1k
What would make the screen strobe after turning on.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 30, 2015 | Televison & Video
My coby flatscreen comes on and works but strobes flashing light but works good just with strobing light ! whats going on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz,...
Display shows lines and color not displayed properly
A line vertically down the screen (usually bright green) is a failed column strobe. This can be caused by the connections at the top of the screen failing or the strobe chip starting to die.
Random colours can be caused by a cracked screen or a failed video card.
Best to take it to a repair shop for it to be assessed.
Jun 23, 2014 | Toshiba Satellite C850-BT2N11 Laptop
My Samsung TV model LE46C580J1K started with problems yesterday when for no reason in the middle of watching a programme the picture went red and looked like a colour negative photograph. I couldn't change...
Sounds like main board fault. Contact any service technician, or the authorized service center to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 24, 2014 | Samsung Televison & Video
Vizio screen flashing
ok when mine did that i shut it off then on then off then on again four times then unpluged it and plugged it back in and waited for a few minutes and it was fine if that don't work then its most likely an internal problem and it would have to be fixed by a professional
Feb 05, 2014 | Televison & Video
When I turn on My RCA L40fhd41 40" television, the LCD screen constantly blinks on and off like a strobe light. The power light stays on constantly, but the screen continues to blink
Dec 12, 2010 | RCA L40FHD41 40. in HDTV
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
Both Display Screens on Kyocera Strobe phone stopped working.
I would suggest taking it to the phone company and asking them for help. The phone might still be under warranty, and you might be able to get it fixed.
But if that doesn't help, you can often buy new display screens for phones and install them quite easily.
I would suggest looking on ebay for a screen for them.
Also, it may cost a little more, but you can buy a new phone exactly like this one for about 60 dollars on e-bay. This would be a last resort, but it is an option.
Hope this helps!
Dec 29, 2008 | Kyocera Strobe K612B Cellular Phone
Studio Strobe not firing with Coolpix
The Coolpix line of cameras require a "tip positive" sync connection to an external strobe unit (when using the Nikon AS-15 Flash Sync Adapter). On some external Studio Strobe units the sync polarity is easy to change because of the type of plug: On this type of connector simply turn the plug around and insert it with the male pin connectors in the other holes. Other types of connectors (such as the standard "phono" plug) are not generally changeable by the user. If the Coolpix does not fire an external strobe check with the strobe manufacturer for sync polarity info.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Televison & Video Logo
18 people viewed this question
Jerry Greenberg
Jerry Greenberg
