Question about Lexmark X1150 All-In-One InkJet Printer
Labels how to print
How do i get my lexmark x1150 to print 64mm x 33.9mm labels please
    Master:
  • 788 Answers
In your Word processing program (Word, Wordperfect, Writer, etc...) there should be a label module usually found in the Tools menu. From there you can set the size of your label as well as the contents or you can have the program generate a page with a table set to fit your label paper.
Posted on Oct 23, 2008
My lexmark S305 printer wont print from my expressit SX3 program. It is a CD label program and when i try to print from it, it draws the paper through the printer but only prints a very thin line accross...
If other print jobs (go through without any problem) from any other applications on your computer, then the problem could be just from your expressit SX3 program. Please contact Lexmark Technical Support Center to further diagnose this problem.
Sep 24, 2011 | Lexmark C533DN InkJet Printer
This problem is with our church library Lexmark 1240 printer. We put a new black #17 inkjet in, but it prints only blank pages and we have 22 books awaiting labels. When I click on "print...
I believe this is a Lexmark X1240, THis printer is the same as a Dell A920, I do not have a manual for it but in the past I had a user with a similar issue. They had not removed the plastic from the ink cartridge before the inserted the cartridge. Please remove the cartridge and make sure all plastics from the nozzle area have been removed. If that dosen't work then try another print cartridge. Also visit the Lexmark website to make sure you have the latest drivers for the printer, this might resolve the "no labels" issue.
Hope this helps.
Mar 07, 2011 | Office Equipment & Supplies
E260 will not print labels
This printer has capability to print on labels. Here are some tips when printing on labels:
· Use labels designed specifically for laser printers. Check with the manufacturer or vendor to verify that the labels can withstand temperatures up to 210°C (410°F) without sealing, excessive curling, wrinkling, or releasing hazardous emissions.
· Labels can be printed at a higher fusing temperature up to 220°C (428°F) if Label Weight is set to Heavy.
· Select this setting using the Embedded Web Server, or from the printer control panel Paper menu. Label adhesives, face sheet (printable stock), and topcoats can withstand up to 25-psi (172-kPa) pressure without delaminating, oozing around the edges, or releasing hazardous fumes.
· Do not use labels with slick backing material.
· Use full label sheets. Partial sheets may cause labels to peel off during printing, resulting in a jam. Partial sheets also contaminate the printer and the cartridge with adhesive, and could void the printer and cartridge warranties.
· Do not use labels with exposed adhesive.
· Do not print within 1 mm (0.04 in.) of the edge of the label, of the perforations, or between die-cuts of the label.
· Be sure adhesive backing does not reach to the sheet edge. Zone coating of the adhesive at least 1 mm (0.04 in.) away from edges is recommended. Adhesive material contaminates the printer and could void the warranty.
· If zone coating of the adhesive is not possible, remove a 2-mm (0.06-in.) strip on the leading and driver edge, and use a non-oozing adhesive.
· Portrait orientation works best, especially when printing bar codes.
· Use only paper label sheets. Vinyl, pharmacy, and dual-sided labels are not supported.
For further assistance, please contact Lexmark Technical Support.
Mar 04, 2011 | Lexmark E260dn Laser Printer
How do Print Labels?
If you click on the Lexmark printer file there should be a task section where you tell it you want to print labels and it will walk you thru it. Hope this helps.
Oct 28, 2010 | Lexmark X2600 InkJet Printer
I have a Lexmark 1235 (OLD), it is not compatible
Below is a link that is untested but is advertised as being a Vista driver for your printer. Feel free to try it and see if it solves your problems. Best of luck.
Greg
http://greg.margo.home.comcast.net/x125vista.zip
p.s. Please post back with results if you try it; there are many with the same issue and I'd like to help as many as I can.
May 11, 2009 | Lexmark X125 All-In-One InkJet Printer
How to print labels on my Lexmark X7350
how do i print labels on mylexmark x3350 printer please
Oct 08, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark 125 Prints Labels with color cartridge
I kicked the **** out of it and it started to print. I don't recommend it if you are afraid you may damage the electronics. The way I saw I spent damn near 70 dollars on some useless print cartidges nothing was wrong with them. The error message kept saying ADD CARTRIDGES. Anyway I'm thinking about a new printer anyhow.
Aug 28, 2008 | Lexmark X125 All-In-One InkJet Printer
Lexmark x75
I DONT HAVE CD PROGRAM THE MY LEXMARK X75 PRINTER
Jul 11, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
74 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
