Question about Refrigerators
Ice maker does not produce very much ice
Ice maker does not make alot of ice some times there will only 6 cubes of ice when it has not been used for 24 hours
  • 5,370 Answers
For this problem.click the link below :---http://alltypesofpartsreplacing.blogspot.in/2011/10/ice-maker-didnt-make-ice.html
--------This will help.Thanks.
Posted on Feb 10, 2012
  • 103 Answers
SOURCE: AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Posted on Jun 13, 2009
TheMobilian
  • 8220 Answers
SOURCE: Ice maker is making ice too slowly
Dirty condenser. Clean under the ice box.
IM manual and other stuff
Posted on Aug 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: ice maker does not make much ice
Hi and welcome to FixYa. When an icemaker still makes ice but in a reduced capacity it is usually the result of other problems.
Either there is ice build up on the evaproator coils due a defrosting problem that you do not see or the evaporator fan motor is not running fast enough.
Here is a way to find out. Unplug the unit and use a fan blowing into the freezer compartment for at least 2 hours. This is a manual external defrosting that will rid the evaproator coils of any ice build up.
Plug the unit back in. Over the next 30 hours check to see if your ice made result is much more than before the manual defrost.
If this improves your ice made result then you probably have a defrosting problem with your unit.
You did not say if the cubes were smaller or not so I have to assume the cubes currently are normal in size and that water flow and ice maker fill timing are fine.
Kelly
Posted on Feb 28, 2010
Testimonial: "Thanks Kelly, The information provided is helpful in trying to determine why my ice maker has not been producing a normal amount of ice recently. "
  • 185 Answers
SOURCE: Ice maker only produces 30 cubes per day (24 hrs) since new.
You probably need more water pressure going to the frig. check that first.!!
Posted on Mar 22, 2010
TheMobilian
  • 8220 Answers
SOURCE: The ice maker is not working
There is a way of testing the ice maker.
Diagnostics for ice maker starts on page 27
Posted on Apr 01, 2010
Sub zero 650 slow ice maker
Hi Maureen,
Your sub-zero 650 should produce about 8 cubes every 2 hours. It sounds like the heater beneath the ice maker may be wearing out. Ice makers use a heating mechanism to warm the cubes in the mold and force them to easily eject. If the heater is failing in the back slot, it could cause the ice cube to get stuck. If this is the case, you usually need to replace the part or the entire ice maker.
It is also possible the mechanism isn't properly aligned. You could try adjusting it.
You can find two manual on FixYa here: http://www.fixya.com/support/p24667-sub_zero_650_o_bottom_freezer
Otherwise, I suggest contacting their customer service or a technician: http://www.subzero-wolf.com/contact-and-support/index.aspx
Best of Luck!
Dec 09, 2013 | Refrigerators
How ofter should you clean the Scotsman ice maker?
Every 6 months and change filter unless you notice ice hanging up during harvest and dirty ice then i would every 3 monts.
May 25, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
The ice maker drawer was left open a crack and the ice froze up and now it will not produce ice
Hi. Use a hair blow dryer to thaw out the ice maker. Remove all of the ice, warm up the tubes, be sure the ice cube molds are ice free. THEN close the door and let it make ice. The first set of new cubes will take a long time, often up to 24 hours. Joe
4 thumbs up please. ty
Oct 21, 2010 | Whirlpool GI5FSAXV Bottom Freezer French...
Apr 01, 2010 | Samsung RF265AA Bottom Freezer French Door...
Ice maker stopped making ice
Hi
If the ice maker has completely stopped producing ice then check to see whether the ice maker has been turned off. For this you need to look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary. If the ice maker is producing ice poorly i.e. if it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker is not making ice
hello. i can help.
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly.
Jun 25, 2009 | Sub-Zero 245
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
Ice maker
sounds a liitle to fast actually, its rated for 8 cubes for "harvest"(cycle, and each cycle problably about 1:45, ittl take a while to fill the bucket , perahps 36-48 hours. once filled though maintains good normal use levels.
Oct 29, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Have an LG LFX25960TT refrigerator with in door ice maker. The ice maker only makes 2 to 3 ice cubes at a time. (Too slow for my family's needs.) It appears like it doesn't get enough time to fill. Is...
Check to make sure the water supply to the refrig is good and the inlet screen where the water line connects to the refrig is clean. You can change the amount of water fill by pressing the button on the left side of the ice maker. (indicator lights above button show setting) Selecting "Ice Plus" on front of dispenser panel increases ice production for a 24 hour period. Ice maker should produce 6 cubes per cycle, aprox.. 100 to 130 cubes in 24 hours depending on freezer compartment temp, room temp, number of door openings, etc.
Sep 10, 2008 | LG Refrigerators
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
