Sound but no picture on vivo ltv40fhd
Well it 3 mounts old and there is no picture but there is sound is there anything that I can do
4 Suggested Answers
  • 58 Answers
SOURCE: sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
Posted on Dec 08, 2008
  • 6 Answers
SOURCE: No sound, and no picture today. Everything was fine yesterday. 3 years old
is the tv a rear projection if so it the bulb you will need to replace it
Posted on May 30, 2009
  • 8457 Answers
SOURCE: No picture
Ur LCD inverter board it dead.Replaced this board will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board shape.
Posted on Apr 21, 2010
Transmission
Did it do it under hard acceleration? or just a normal take off. I have heard of engine mounts or tranny mount bushings getting old (not mileage old but just aging) causing a thump or clunking sound in between shifting. What happens is the tranny actually hits the undercarriage of the vehicle during high torque situations such as shifting gears. I have also seen the mount retaining nut back off of the mounts and the only thing holding everything in place is gravity. Another possibility is drive shaft u-joint problems, but if it were it would probably be making the noise more often. I dont think there is actually anything wrong with the transmission itself as usually when they go bad they dont magically get better. Hope this helps. Good luck!
Nov 16, 2013 | 2000 Cadillac Escalade
We have lost the picture on our 42 inch hp plasma tv model pl4260n, we get sound but no picture?? is this a known issue? probably 3 to 5 years old , just happened in the middle of destination truth. nobody...
If it is not a loose connection (internally), it may be most probably related to your picture tube. Check it out and if found faulty get it replaced. If your are in any warranty period (I don't think so since it is 3-5 years old), don't do anything and just inform them, or else you will loose your warranty security.
Apr 17, 2010 | HP PL4260N 42 in. Plasma HDTV
Hello I have a Pentax spot matik film camera. This camera comes with a lense with thread ... I was thinking in buy some of your lenses ( rokinon) 800- 1600mm. I would like to know if it will work in my...
The hard part will be getting a T-mount for the old Pentax screw mount. If you already have one, you should have no trouble. It won't even matter which one you buy, since you'll be removing the mount that comes with it and using the old Pentax screw instead.
If you don't have a T-mount, then you're going to have to hunt for one. You don't want to buy anything that's marked "for Pentax", since anything current will be the Pentax-K bayonet mount, not the old Pentax screw mount.
Feb 09, 2010 | Rokinon 800mm f80 Lens
SOUND BUT NO PICTURE
I had the same problem today with the same symptoms. I tried a power reset, removing the cables, checked all inputs and got the same symptoms.
I found a temporary fix. When I turned the TV on, I immediately press the backlight but on the remote until the bar appears then lower the setting down to 10. This may take a couple of tries of powering the TV off/on. Once I got the setting lowered to 10, the picture stayed on. If you invoke any of the presets it will change this setting. I'm going to call someone and try to get more information on a permanent fix.
I hope this helps, at least I got the picture back.
Jan 27, 2009 | Westinghouse SK-32H540S 32 in. LCD TV
No picture No sound
how did you remove the stand attached to the tv? But i have heard of this happening before too..They tend to just die..
Dec 23, 2008 | TruTech PM1919BXA1 19 in. LCD TV
Dec 07, 2008 | iLO 3200 32 in. LCD Television
TV SCREEN GOES BLANK
Yes your inverter is bad, I have the same problem my set is about 1 and 1/4 years old. Because Olevia makes a terrible product there inverters are attached directly on to the panel, which means they will only sell the inverter along with the panel i.e $700+ to replace + $100 dollars labor if u don't know how to fix it ur self. I am currently searching to find the manufacture that makes the inverters because olevia will not disclose that information. I believe it is darfon, if so the inverter should cost about $150-200 depending. If you dont believe you can fix it ur self ur best bet is try and sell the set for scrap take ur $100 or so dollar and buy a quality product! Oh and dont call there support they will tell 10 different things before u find out this long for seen truth!
May 04, 2008 | Olevia LT37HVS 37 in. LCD HDTV
No picture, sound works. Screen flickering
That problem is caused by the Y Sustainer board.
Oct 12, 2007 | Toshiba 50HP66 50 in. Plasma Television
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
