Question about Stanley 12 - 905 Contractor Grade No.5 Smooth Bottom Jack Plane
I need an assembly diagram for a Stanley #5.
Which way does the blade face up, and where does the chip breaker go?
I recently bought a #5, used, and I am not sure that it was assembled correctly.
  • Anonymous Apr 15, 2009
    same
  • 35 Answers
I need an assembly diagram for a Stanley #5. - plane_parts_web1.jpgplane_parts_weI need an assembly diagram for a Stanley #5. - plane_parts_web3.jpg /><img src=plane_parts_web5.jpg I hope it helps.
Posted on Nov 01, 2008
How do i assemble a stanley block plainer
1, Lay pencil on the table top, place body of plane with the front (toe) resting on the pencil, so the light passes beneath the front and middle of the plnes body.
2, lay blade, bevel side up, in to body of plane, ideally sharp end is sticking out of the mouth ever so slightly., 1/2-1mm.
3, Release the knob or lever cam on the lever cap and place on top of blade.
4, tighten knob/turn leaver till it tightens on the blade. and your ready.
5, If the blade isn't protruding the mouth correctly then:
6, Loosen a knob/lever a little to allow the blade to just move, adjust the blade forwards/sidways, lock it in place by re tighten the knob/lever.
Plane a thin piece of wood, re adjust as necessary till wafer thin shavings collect in the mouth ontop of the bevel.
Aug 29, 2014 | Bailey Stanley 12-920 - Block Plane
I have a stanley 99e. i took it apart ti change the blade, without paying attention, and now i can't re-assanble it properly. I can't find any instructions online.
Hi.
See here the Stanley knife disassembly. If you have a 99E there may be an additional plastic part that is not shown in the diagram. The plastic tab is located at the back of the blade.
Jun 02, 2011 | Stanley Utility Knife
I bought a used stanley router and don't know how to take the old blade out. I like to change the blade.
There will be a button to push in which will lock the spindel. After locking the spindel you need to undo a nut using a wrench or spanner.
Apr 09, 2011 | Stanley Hand Tools
Need re-assembly instructions for jack hammer BR67130M.
Hello Mayham, you will have to contact Stanley's Tech Dept and have them fax or e-mail the diagram to you. Please call 503·659·5660 and they should be able to help. Let me know if this works.
Dec 03, 2010 | Stanley Proto Stanley Br67 Hydraulic...
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
Reassembly of trimmer blades to motor body
Put the ware plate on the support bar.
On top of that install one blade facing up.
Then install the other blade facing down.
Put the bolts up through the support bar
Install the little rubbing blocks on bolts in slots in blades.
Place top stiff plate on top and install nuts.
Replace grease in gear box with stihl hedge trimmer grease onyy
Mar 19, 2009 | Garden
Lawnmower lbade assembly sequence
1. install round washer first flat side facing you.
2. round plastic washer next flat side facing the washer.
3. next step blade.
4. next step square plastic washer label facing you.
5. then the square metal washer, make it flash with the shaft flat side.
6. tighten nut by hand at first then use impact tool if you have.
Jun 08, 2008 | Black & Decker 19" Electric Lawnhog...
Stanley 12 - 905 Contractor Grade No.5 Smooth Bottom Jack Plane Logo
2,135 people viewed this question
Top Stanley Crafts & Hobbies Experts
Steve Mason
Tony Crow
Are you a Stanley Craft and Hobby Expert? Answer questions, earn points and help others
