Question about Sylvania Salus RT500RF
Wired a salus program wireless thermostat to a biasi combi boiler but when thermostat fires up for heat boiler does not fire up pretty sure i have wired it correctly
When my remote central heating thermostat is in sleep mode the boiler will occasionally ignite of its own free will What can I do to prevent this.?
Many times the factory wiring on the boiler is set up to maintain boiler temperature with a built-in aqua-stat. The thermostat then controls the circulator pump to transfer heat from that loop to the structure. So, if this is the case, your programmable stat may just be controlling the circulator. There are many, many control AND piping configurations to boilers. Some very different than others.
Dec 14, 2014 | Sylvania Salus RT500RF
My Baxi Combi 80e boiler turns the heating on randomly. With the wall thermostat turned down and even with the boil switched to hot water only the heating still fires up when unwanted.
If the thermostat wire run passes anywhere through, beside or inside any metal surfaces and the wires touch any of the metal its the same as if you turn the stat to on. I've seen this a few times. Easiet way to detect it, if its inside the house is at night in the dark. Look around when its doing this you may see the small spark when it goes on. Otherwise you will need to inspect the entire run from the stat to the untis, etc.
Jun 23, 2014 | Heating & Cooling
Biasi combi boiler with red light flashing at honeywell r6660d
Here is the biasi site that should have your manual. With no model number, I hope this helps.
Feb 15, 2014 | Honeywell Programmable Thermostat Heater
Setting start temperature on central heating thermostat
It sounds like your heating system has to little capacity to heat the home properly. 21 degrees is a reasonable temperature to expect but if the unit is running all the time and can't reach 21 degrees the heater is too small.
As far as setting the thermostat here is a link to the instructions.
http://www.salus-controls.pl/data/product/attach/rt300rf_-_eng.pdf
Nov 22, 2013 | Heating & Cooling
I do not have a room thermostat connected to my oil fired central heating boiler. I want to install a wireless room thermostat to avoid having to run cable. how do i go about this and which is the best...
All wireless wall thermostats are Millivolt controlled. rather than having an 18 or 24 volt (transformer) wired wall thermostat. Before purchasing any wireless wall thermostat, you need to determine what your oil fired boiler requires for activation. My experience tells me, that it's going to require either 18 or 24 volts. In which case a wireless thermostat won't work.
Hope this helped you and thanks for choosing FixYa.
Aug 11, 2011 | Heating & Cooling
Vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Mar 25, 2009 | Water Heaters
Baxi Combi 80e
i need to know boiler specifics- make and model but sounds like either the air pressure switch seized or the main printed circuit board, if the boiler has an overheat thermostat please ensure that the little red button hasnt popped out because this will prvent the boiler firing up- refer to the manufacturers instructions for location of the o/heat stat
May 05, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
154 people viewed this question
Top Sylvania Heating & Cooling Experts
tractorman44
tractorman44
Rani wadia
Rani wadia
Jay Plesset
Are you a Sylvania Heating and Cooling Expert? Answer questions, earn points and help others
