Question about Singer 7422
Singer Sewing Machine 7422 turns on, but will not stitch...
The lights on the panel flash when initially turned on, but then go off and will not allow to choose stitch. Does not stitch when pedal pushed either.
  • Singer Master
  • 7,365 Answers
Sounds like there something wrong with the computer part of the machine
it needs to be serviced
Posted on Feb 10, 2012
SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Posted on Nov 03, 2008
dupina
  • 110 Answers
SOURCE: Bobbin won't wind Singer 7422
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
Posted on Nov 11, 2008
SOURCE: singer sewing machine 7422
not paying for this
Posted on Apr 19, 2009
  • 139 Answers
SOURCE: SINGER 7422 28 STITCH 2 BUTTONHOLE INSTRUCTION MANUAL
http://www.singerco.com/accessories/manuals.html
Posted on Apr 07, 2010
  • 980 Answers
SOURCE: I have a singer sewing machine model #7422. The
Is the balance wheel turning when you press on the foot control? if it is then the stop motion may not be tight enough
Posted on Sep 19, 2011
Singer 7422 runs for two stitches and then the light flash and beeb and sewing stops
Check the troubleshooting section of the owner's manual. There is something that the machine believes is not correct.
Apr 24, 2017 | Singer Sewing Machines
I have a singer 7422 sewing machine which is made in canada. I want to use it in india. So, what type of step down converter do i need and how much watt.
Hello Gargi Sarkar
The power supply voltage in India is between 220 V and 240 V. Your machine will be ruined if you plug it directly into the power supply in India. There are two options:
1. Use a step down adaptor to 'reduce' the 220 - 240 V to 110V which is what your machine can handle. This may be more practical and economical AND you can use the step-down adaptor for other Canadian electronics.
2. Your sewing machine motor can be changed for a 220 - 240 V motor, but often other parts will need to be changed as well. Also more costly.
Happy Stitching
Sewingirl/
Feb 20, 2017 | Singer 7422
-light_keep_flashing_machine_doesnt_work
Sounds like a computer malfunction. Not much choice but take it for service.
Aug 15, 2016 | Singer Advance 7422 Electronic Sewing...
Why does it keep stopping with lights flashing when filling bobbin?
Singer 7422 keeps stopping with lights flashing when filling ...
www.fixya.com/support/t26006759-singer_7422_keeps_stopping_lights
4 hours ago - Singer 7422 keeps stopping with lights flashing when filling bobbin Machine stops ... Machine stops and red lights flash when loading bobbink.
Dec 13, 2015 | Singer Sewing Machine 7422
I have a singer 7422 sewing machine. When I turn it on all the lights flash on and then nothing. It will not do anything after that.
Make sure your buttonhole lever is not down, and your bobbin winder is not completely or partially engaged. When you turn the machine on, the needle should be at its highest position (ALWAYS turn the hand wheel TOWARDS you--on any machine!). Press the reverse button two or three times--this will reset it.
Jun 13, 2014 | Singer Sewing Machines
Singer 7422 beeps and all lights come on when peddle is pressed.
There are several sensors on this machine that just start causing the machine to malfunction for no apparent reason. One is one the bobbin winder, one on the buttonholer, and one under the machine which workd with the feed. It is far from an exact thing. If you can get to them, sometimes loosening them, moving them about then tightening them seems to 'fix' them. Sometimes not. Wish we could be more exact in explaination but sometimes we will move them repeatedly then they start working. It is hit and miss.
Sep 06, 2009 | Singer 7422
How can I get the bobbin to wind on my singer 7422?
Your machine could be defective. Take it back where it was purchased.
Apr 18, 2017 | Singer 7422
Singer advance 7422
My Singer 7422 seems to be jammed. When I start to make a stitch, the thread from the needle gets caught on something on the bottom and the thread goes over the bobbin.
Jul 16, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 7422 Logo
94 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
