Question about Sony Bravia KDL-32V4000 32 in. LCD TV
4 red standby flashes!!! Need help!!!!
Hey, So I have had this TV for a few years or so and only recently It shut off once by itself and then blinked a few times. At first I ws able to switch it back on again and all was fine. However 4 days ago the same thing happens so I switch it back on like last time but within 10 minutes or so it switched off. I then pull the plug at the back and left it off for a few days and today when i switched it back on it immediatly switched back off again flashing the red light 4 times before a second or two break and repeats the process. I looked on this site for answers but not sure which is the right one. I read that it could be a bulb issue or it could be a power issue. I also read It could be a fuse problem. So I opened up my TV (I just unscrewed the screws at the back and took out the back panel so i could have a closer look. Everything looks find and I am not sure what the problem could be. I do not have a warranty on this TV no more and from what I have read Sony seem to be useless at customer service anyways. I was hoping that It would be a dust issue but there Is not much dust in the TV and I have no idea what It could be. Apart from wild guesses is there any definative answer which could be given from just the 4 red blinks? The usermanual says contact a sony centre but I will not do this based on the experience for others and I do not wish to pay loads for It to be fixed either. I can do the soldering and stuff myself If It Is required but jsut want to know what Is the problem. Would be greatful for a response. Thanks in advanced for anyone who can help. Dean
  • Dean A Feb 09, 2012
    Another thing which I did not understand was how I might need a new bulb? Whilst looking at this LCD TV I do not understand where this bulb would be and why you would need one as I thought bulbs were for projector typs TV's.
  • 22 Answers
There are a few things to ponder here...probably the high voltage inverter power board is shutting down due to excess power drawn from CCFL(cold cathode fluorescent lamps) . This will happen eventually as a carbon track starts to grow down the tube drawing more current . There has to be a lot of hours for this to happen .
Sony was not free from the bad capacitor affliction...an ESR tester is not an expensive investment unless you only use it once but it can find bad caps that are not showing signs of ***** ie:leakage ,swelling.
failing ballast transformers would be replaced by new inverter board . This would be a last resort without schematic and instrumentation to get hard data to find culprit .
The CCFL tubes can be replaced and may be worth the time and effort with sweat equity . At approx 40.00 usd for 10 you would have to decide for a mere 32 inch LCD TV .
I would spend the money to get an LED TV and get longer service life and possibly better features ie: smart TV
Hugh
Posted on Mar 11, 2017
SOURCE: red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Posted on Feb 09, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Posted on Feb 14, 2009
  • 197 Answers
SOURCE: I have a Sony KDL-32V2500, bought two tears ago.
bad inverter pcb
Posted on Jun 07, 2009
dsacco86
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
SOURCE: 55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Posted on Sep 28, 2009
Samsung TV not turning ON. My email address is prk Please help... Much appreciated.
Its power supply I will tell you how to fix you need to get few things first
Jan 29, 2016 | Samsung Televison & Video
Sony KDF-42WE655 Won't power on. Red Power/Standby light blinks 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 21, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
I own a Sony KP-51WS520 that has been down in the basement unused (unplugged) for 2 years. I decided to set up my "man cave" and went to turn on the TV. It started right up but after shutting...
Hi Hank,
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. There is no user replaceable Lamp in KP51WS520 TV.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 16, 2011 | Sony Televison & Video
RED STAND/BY LIGHT WILL COME ON BLINK SEVERAL TIMES, HEAR A CLICK SOUND A FEW TIMES BUT TV WILL NOT COME ON,
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Sony Televison & Video
TV on Standby
There is a Sony S3000 protect blinks table:ebf219b.gif
May 27, 2010 | Sony KDL-32S3000 32 in. LCD Television
The red standby light is flashing twice with a pause, then twice and a pause etc. There's no picture or sound and the light flashed whether we have the tv on or off. Any suggestions?
This blinking is a diagnostic code. Please update this with the model number. These sets contain circuitry that will shut the set down and display a code like this when a problem is detected. With the model number, I can look up the problem and provide potential repair suggestions.
Thanks,
Dan
Aug 20, 2009 | Televison & Video
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Daewoo dvn14f6n
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
Feb 15, 2018 | Televison & Video
Sony Bravia KDL-32V4000 32 in. LCD TV Logo
82 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
