Question about HP LaserJet 3050 All-In-One Printer
No Print Cartridge
The electric went off at night and when I checked the printer it said "No Print Cartridge". I have disconnected the unit, hit cancel, taken out the cartridge and reinserted but to no avail. What can I do?
    Sniper:
  • 87 Answers
1--Switch off the printer
2--Remove all paper from all trays
3--Reseat the toner cartridge as the printer is switched Off
4--Restart the printer and check
5--Install the paper in the trays and then check if the issue is sorted
Posted on Oct 30, 2008
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
My printer is working fine but when i hit print the printer does not print any thing
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Jan 07, 2012 | HP Office Equipment & Supplies
Lexmark X6570 printer cartridge black or colour not recognised error 005, they are correct cartridges, contacts are clean, will not print test page, used diagnostic tool and quote: incorrect cartridges,...
The Lexmark X6570 printer uses these cartridges: - #41, #41A, #42, #42A, #43XL, #44XL
Follow the steps below to fix the problem: 1. Remove the print cartridge that is indicated and close the cartridge carrier lid. 2. Close the scanner unit. 3. Disconnect the power cord from the electrical outlet. Wait a few seconds. 4. Reconnect the power cord to the electrical outlet. 5. If the power button is not lit, press it to activate. 6. Reinsert the print cartridge and close the cartridge carrier lid. 7. Close the scanner unit. 8. If the error reappears, then it could be a faulty cartridge. Replace the print cartridge with a new one, close the cartridge carrier lid, and close the scanner unit.
Jul 28, 2011 | Lexmark X6570 InkJet Printer
My canon MX340 won't print, saying there is a printing error 5200. I tried unplugging the printer and turning it off, but it still won't work
I will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see if that fix the problem.
Jul 11, 2011 | Canon PIXMA MX340 Wireless Office...
Every time I turn the printer on it prints an alignment page. How can I stop this?
This happened to me. I just hit the "x" cancel button and it stopped. It tried to do this for several weeks. I just continued to hit cancel on the printer or the check button. When I replaced the ink cartridge the problem went away. Possibly there was a defect in the cartridge that the printer could not complete a sucessful alignment.
Jun 08, 2011 | Dell 926 All-In-One InkJet Printer
Epson r240 fault e90
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-Photo-R240/Drivers-Support?target=article&extn=.html&articleId=3866
Troubleshooting
  1. Clear all print jobs waiting to be printed from the computer before turning off the printer. To fully clear all print jobs you will need to restart the computer. See the following Related Articles if you require help with this step:
  2. Once you have cancelled the print queue and restarted the computer, hold down the button-paper_trash.gif Paper/Bin/Cancel button or dx4400stopbutton.jpg Stop / Clear button for 3-5 seconds.
  3. Power off the printer/All-In-One. After it has powered off, also turn it off at the power point or disconnect its power cable, if possible.
  4. Open the printer lid/scanner unit to make sure any tape securing the ink cartridge holder/print head has been removed. Some printers have a plastic block which helps prevent the ink cartridge holder from moving during transit - make sure that this has been removed/is not in place.
  5. Check for any foreign objects inside the printer that may be causing an obstruction to the print head. Check for torn pieces of paper around the front of the printer and the ink cartridge holder/print head. Carefully remove any paper or other obstructions from the paper path and inside the printer by hand.
  6. Check that the ink cartridge holder/print head is positioned on the right side of the printer (as you look at it from the front). If it is positioned on the left, see the following Related Article: How can I resolve the issue where the print head positions itself on the left / does not return to its home position?
  7. Close the printer cover/scanner unit. Press the On button to power on the product. If the error message still appears, contact your dealer or EPSON.
Feb 28, 2011 | Office Equipment & Supplies
LEXMARK X5450 CODE 1203 ?
This is a cartridge alignment error. Follow the steps below to fix the problem.
6 Reinsert the print cartridges.
2 Disconnect the power cord from the electrical outlet.
3 Reconnect the power cord to the electrical outlet.
4 If the button is not lit, press .
5 Reinsert the black (or photo) print cartridge.
Jun 04, 2010 | Lexmark C533DN InkJet Printer
Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
May 02, 2009 | HP Officejet 5610 All-In-One InkJet...
DELL AIO 922- All in one- Printer won't print
Remove the right ink cartridge (color). You will get an error saying the cartridge is empty, but ignore that. Hit cancel on your printer. Print your job...when your print screen comes up, under preferences check the box for print colors in black and white. Your printer should print just fine without the color cartridge. Ignore the flashing red light.
Sep 06, 2007 | Dell 922 All-In-One InkJet Printer
HP LaserJet 3050 All-In-One Printer Logo
54 people viewed this question
Ben Johnson
