Question about Canon Office Equipment & Supplies
I have an E803 error code on a Canon CLC 1100 I think it is the power supply where can I get one?
ginko
  • 19396 Answers
SOURCE: CANON CLC 1100 ERROR CODE E079 CAN YUO HELP ME?
E079 is in effect a drum fault. If you tell me your location I will find the price for a drumkit in your area, in UK should be between 50 and 80 punds
Posted on Feb 18, 2008
this error:
E005
200
Posted on Mar 25, 2008
SOURCE: Canon Error code E803
thank you very much, that was the problem.
Posted on Jul 28, 2008
  • 4 Answers
SOURCE: Canon CLC 1150 - E804
The laser scanner motor cooling fan has stopped to rotate in error.
sandip.creation@gmail.com
Posted on May 06, 2009
  • 4 Answers
SOURCE: Canon CLC 1100 E072 0202
E072 0202 means :
The transfer drum cleaner brush motor (M8) is faulty.
The polishing roller motor (M9) is faulty.
The motor drive system is subjected to an overload.
The attraction/transfer locking cam motor (PM7) is faulty.
The attraction/transfer locking cam HP sensor (PS8) is faulty.
The registration path driver PCB is faulty.
The DC driver PCB is faulty.
The CPU PCB is faulty.
The attraction/transfer looking cam HP sensor does not go '1' within 4 sec after the attraction/transfer locking cam motor has started to rotate.
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Error Code: E071 0007
I got an error code on my canon clc 1100:
E071 0007
Aug 19, 2010 | Canon CLC 1110 Copier
Error e803 checked power supply next to ac cord
Well most likely its a low voltage problem, check power outlet (110/220) or you need to replace the low voltage power supply board. Before replacing the power supply board you must check that the voltage is 24V by using a volt meter.
Jan 22, 2010 | Canon Office Equipment & Supplies
Error code e020 with sub code 140 on canon clc
This code refere the developing assembly locking plate.Please verify the plate mounted and the developer sensor,the toner hopper sensor or the toner hopper motor.
Dec 12, 2009 | Canon Office Equipment & Supplies
Error code E803 on canon IR330
E-803 ON CANNON IR400, WHAT IS THE RESET PROCEDURE FOR THE SAME.
Jan 03, 2009 | Office Equipment & Supplies
  1. e803 is a problem with the scanning lamp. Does the lamp light up when you power on or does it go right in to error code?
Jul 23, 2008 | Canon ImageRUNNER 330s Copier
it may be the fuse board or the relay near the fuse board that is arcing
May 19, 2008 | Canon CLC 1150 Color Copier
Error Message E020, 0400 for canon CLC 1120 Color copier. please give your assitance
This error has to do with Toner concentration of the Black ( 04 ) part of the sub code. The "00" has to do with the reference level or signal value for black. Look to see if the Black toner sensor is soiled. You have to swing out the toner hopper assembly to access the sensor. You will see two thin gray cables coming down from under the control panel. Since you have access to both assemblies - toner and paper jam detect - carefully remove both and clean with canned air. Be careful since you are so near to the $800 drum. Replace both and test. If you still have problems and the drum is old, several years, and has over 40,000 copies on it, you may have to have the drum changed and I recommend a tech do it. Good Luck.
Oct 29, 2007 | Canon CLC 1120 Color Copier
48 people viewed this question
old marine
old marine
