I have a Hi grade w76th which was dropped and charger would not work. We tried charger again and it sparked and now nothing will happen.
  • 32,281 Answers
It is possible youe laptop is beyond repair. You need to take it to computer repair shop and get a quote. They may charge for a quote unless you go ahead with the repair.
I suggest you put your money towards a new laptop, laptop model today are cheaper and and more powerful.
Posted on Feb 10, 2012
2 Suggested Answers
  • 2567 Answers
SOURCE: Hi, Nothing happens when I
Motherboard is defective & needs to be replaced with a new one.
You can find a replacement motherboard by searching on e-bay.com with the motherboard's model number. This could be found under the RAM.
Posted on Oct 09, 2010
Have an Acer M5-538P-5859 Lap top, that is 1 mo old. It is a Windows 8. It was left on with only battery power, for a number of days. I plugged in the charger and nothing happens--No lights on, no p
If you let the battery charge for about ten hours it might work. If you just want to see if the computer will work remove the battery and try with the charger plugged in. If you don't need to carry the computer around a battery is not needed. Some batteries will not recharge if they have been discharged too much. If you are going to use it with a battery I suggest that you set your power setting to turn the computer off after a period of unuse and this problem won't happen again. Check Ebay for a battery replacement.
Oct 30, 2014 | Computers & Internet
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
I have received as a gift a Canon FS300 Digital Video Camcorder . The first time I used it, I followed instruction on how to charge the battery with CA-570 Compact Power Adapter which was included. It wok...
Hi!
Almost sure there is nothing wrong with your battery, charger and camcorder.
The battery loose power even when doing nothing, especially when it is a NiMH type.
Please charge the battery for a couple of hours and try again to start the camcorder.
Aug 09, 2011 | Canon VIXIA FS300 Flash Media Camcorder
Just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
May 21, 2010 | Pride Mobility Products GoGo Ultra X...
I dropped my psp on the ground, it wont turn on. I tried to plug the charger in, it did nothing, what should I do?
Try taking out your battery, plug the charger in, put in your battery again... turn PSP on.
Works for me!
Oct 20, 2009 | Sony PlayStation Portable (PSP) Console
MY GARMIN WON'T TURN ON WHAT CAN I DO
first of all, leave it charging for 2-3hrs.
take the SD card out if you have it inside
try then to turn it on
if nothing happens - then press reset button on the bottom side of device (hidden behind plastic sticker, but marked)
then try again to turn it on
if nothing happens - take it to authorized service center
Aug 19, 2009 | Garmin nuvi 250W GPS Receiver
18V cordless drill charger #981832-001
Hi again, Because of the age of these batteries, this may or may not work but you have nothing to lose. The theory here is that over time, oxides built little bridges in a ni cad battery between the anode and cathode thus shorting the battery, shocking the battery burns those bridges and if the cells are still intact it will work again. So take your stronger battery or cables and being sure to observe the correct polarity touch or brush the positive to positive and negative to negative several times. The first times will spark and then as the bridges burn the spark will decrease. Put the battery in the charger and the charge light should come on. Leave the battery in the charger until it reaches a full charge. If after this procedure you still have the defective indication, then the cells were bad and you will still have to replace the battery. Good luck, please let me know how this works for you!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 26, 2009 | Craftsman Drills
Only turns on when connected to a charger
Try using somone elses battery first before bying a new one
then if it works you need a new battery
this happens all the time with laptops and whatnot
just buy a battery and everything should be fine
Dec 17, 2008 | Sony PlayStation Portable (PSP) Console
Hi, I have a Canon 300D camera, I have fully charged both batteries I have but it is still not working, I reloaded the battery on numerous occasions as it tells you to in the troubleshooting, I have...
If the actual batteries are working properly, a solution would be replaceing the batteries with others with more miliAmps. Also your problem could be a bad battery charger. I want to remind you that you need Li-Ion batteries for your type of camera and a Li-Ion battery charger.Try that and see if it helps you.If not try to explain what really happened and I'll try my best.
Aug 31, 2008 | Canon Cameras
A sidekick3 that dont power on
well the same thing happen to me but i call t-mobile and they tell me to press @ 1 and 0 at the same time and it should reset it self it doesn't work for me but you can try it
Mar 20, 2007 | T-Mobile Sidekick II
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
