Question about Bloomfield 8571 Coffee Maker
Instructions for bloomfield 8752 same as 8571?
Our church also upgraded to bloomfield 8752 from a bunn that was on the Ark. No instructions. Must this be attached to a water source, or can we fill manually? Thanks!
    Problem Solver:
  • 11 Answers
Most (and this is one of them) coffee makers of this type can be used either way. Having it connected to the wall is more convenient but not necesary. Also if the macine will be unused most of the time it would be better and save power for the church if the pot is unplugged during the week since the water in the tank evaporates during the week which caused it to build scale faster and may damage the machine. Just plug it in when you need it and wait for the brew light to come on. Still faster than a drip maker and saves the church money.
Posted on May 20, 2013
I have a 8571. Bought it used. No instruction Manual. Plug it in, turn on the left burner, poor in water water immediately drains through. I that a valve problem?
Posted on Oct 30, 2008
  • sjbeach2001 May 20, 2013
    It's supposed to do that. These machines work by keeping 2 1/2 pots of water hot at all times. the button on front is for connecting it to a water supply so you don't have to pour water in the top.
THIS IS USED IN OUR CHURCH AND IT ONLY FILLS A 1/4 OF THE POT IT NEVER FILLS UP. AND ALWAYS USES THE WATER TANLK UP QUICKLY EVEN THOUGH IT HAS IT'S OWN WATER FEED.
First brew a pot without water, to find your current level. Next open the faucet and check the water flow, if it has a nice flow no stopping or spurting, then your water connection is good. Now adjust the brew level, the adjustment instructions are on the inside of the front panel. If after making adjustments you get the same result then the solenoid is blocked.
Nov 04, 2009 | Bunn CDBCF APS-DV AirPot Brewer
How do I set the brew ratio?
Hello, I have worked on many bunn and other make ice tea makers but am not too familiar with this one, but as is common to all there should be 2 timers, one for the hot one for the cold. They are normally located under the top panel or inside the front panel. for 3 gallons you should be brewing 64oz of hot water through the 1oz tea bags (3-4) depending on taste as a rule of thumb. Please feel free to comment again if you have any other questions. Good Luck! Mike
Aug 15, 2009 | Bloomfield 8742 iced tea brewer, 3 gallon
Our church received a Bloomfield Koffee King model 8571 and no instructions on how to set up and use the coffee machine.
Hi, Get 2 pots place one under the spray head with the filter cone in....now fill the other coffee pot and start to pour water through the lid top front...keep pouring water through (about two and a half pots) until water starts to pour through the cone....now the tank is full plug her in and turn on the power switch at the back and also the front if there is one....place filter in cone..put coffee in filter...pot on burner...wait about 25 minutes until water in tank is hot...when light on front comes on pour another pot of cold water through the top and you will get a pot of hot coffee in bottom....I also think this machine can be hard wired into water main....get plummer to hook up...follow same procedure but instead of pouring water through top for coffee..hit brew switch. if it poors too much of too little you will find a timer in the machine you can adjust to allow more or less water...hope this helps.
Jun 25, 2009 | Bloomfield 8571 Coffee Maker
Resevoir tank not filling
If you will get the model and date code located on the bottom of the unit and contact customer service, we will be able to help troubleshoot and resolve your issue.
May 11, 2009 | Bunn NHB Coffee Maker
How to prep to brew good coffee
Hello, that sounds fairly good, as you describe it. Here is a link to your units manual:
http://www.bunnomatic.com/pages/techdocs/manuals/pourbrew_warm.html
go to the bottom of the page, and select the operation manual for a VPR. It is advisable to let the unit sit for approx. 20 minutes after filling, cold water works best, and you need to make sure that you pour the water in before you plug it in, as the heat circuit is always on, whether water is in it or not, including if all the water has evaporated. The manual for the unit should answer your questions.
Hope that helps, and thank you.
Mar 08, 2009 | Bunn VPR Coffee Maker
Bloomfield 8543 Filters
bunn rt filters fit this machine
Jan 27, 2009 | Bloomfield 8543 Coffee Maker
Lost manual need cleaning instructions
You can download the operating manual for your machine in pdf format right to your computer from www.bunn.com By the way, I wouldn't personally put vinigar in any Bunn machine, as it takes forever to run enough water through them to get rid of the vinigar taste.
Jul 15, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
Bloomfield 8571 Coffee Maker Logo
223 people viewed this question
Top Bloomfield Coffee Makers & Espresso Machines Experts
Leakfixr
Kelley Hopper
frankecoffee
Level 1 Expert
Are you a Bloomfield Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
