Question about GE Kitchen Ranges
Need a schematic for 1969 GE Electric Stove Model J43902WH
Need a schematic or wiring diagram for a July 1969 GE electric stove
  • 126 Answers
SOURCE: have stove ..no manual
need to know the age of stove
Posted on Dec 10, 2007
SOURCE: need color code/wiring diagram info for Enterprise electric range installation of thermostat
I need the Oven knob for the front panel. The numbers have rubbed off on mine. Thanks, in advance, for your help!
Posted on Jul 28, 2008
jumptrout51
  • 3361 Answers
SOURCE: electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Posted on Mar 12, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE Profile Electric Stove - Buttons for oven don't work
What you need is a new clock control. About $200.00.
Posted on Mar 15, 2009
  • 969 Answers
SOURCE: Just purchased new electric stove. The old stove
Normaly black, white, copper (ground) is a 2-wire 110 volt, black white, red, copper is a 3-wire 220volt circuit. You must have a 3-wire cicuit run from circuit breaker box to stove connector.
Posted on Apr 30, 2009
I need help with my electric stove wanna clean and take top off but can't figure out if I can or not and don't even know what kind it is to look it up I found its serial number / model but can't figure out...
Unplug the stove. Once this is done, you can disconnect the View all achievements ┬╗elements by unplugging them from their connector. You can then lift up the top to clean underneath and around. This is a GE stove, and the data plate will provide the model and serial number. They are normally located on the back or on a easy accessible location like near the over door.
If you need a user manual, try Googling the user name and model number and the word manual.
Always do this type of work with the stove unplugged to prevent electrical shocks or possible burns.
Feb 05, 2015 | Kitchen Ranges
Need a wiring diagram for a rse37bal3
Your Frigidaire motorcycle has an electric stove?
Most stoves I have worked with in the past have had the wiring diagram glued either to the back or under the top. I have never seen one installed on a motorcycle, however.
Feb 16, 2013 | Motorcycles
Ge stove oven get a f4 fault
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.What is the model number?
Nov 08, 2012 | GE Stove/Range/Oven Oven Control -...
Wiring Diagram Defy 521 Electric Stove
NEED A WIRING DIAGRAM OF A DEFY 521 ELECTRICAL STOVE
Sep 29, 2012 | Kitchen Ranges
Stove burners will not light
I went directly to GE's website and found the diagrams for my stove with the parts listed. Thats what I needed !
Thank you,
Penny
Jun 29, 2009 | GE Kitchen Ranges
I have a GE electric profile stove. The range is working the stove is not. What should I look for.
the electric profile stoves have a set of electronic relays in the top of the stove where the digital settings are. the most likely problem is the control module that allows the electrical power to pass through it --is bad or damaged. also there may be a fuse link that blew out. The ovens and stove tops are usually on seperate relays. If the relays are solid state (soldered) you will need a technician to replace the relay. If it is just screwed to a panal board you could replace it yourself. Do you have the papers that came with the stove?? if so there should be information on the parts and ordering. also, there should be a schematic diagram of parts location on the stove. This will show you where the relays are located and which is the oven and stove top. or you could go online to www.ge.com and locate the parts and diagrams for replacement.
Oct 13, 2008 | GE Kitchen Ranges
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
