Question about Coleman Heating & Cooling
Our coleman evcon 75,000 btu furnace which was installed in 1998 has a hole in the heat exchanger per a tech from the gas company.I understand that thif is still under warranty, where can I get help for this problem.
    Scholar:
  • 121 Answers
You can contact John Stone supply at www.johnstonesupply.com for a store in your area. They can tell you anything you need to know about warranties, they are a Coleman distributor. You can get the parts from them or they will recommend a service company.
Posted on Oct 23, 2008
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
ROLLOUT SWITCH OPEN, COLEMAN EVCON FURNACE
Reset the switch. Check the heat exchanger thoroughly for blockages, cracks or holes. Check induced draft motor for proper operation. Check flue pipe and chimney for obstructions.
Feb 18, 2013 | Rheem Heating & Cooling
Can a wrong gas valve cause a heat exchanger to become deformed?
Hello, I would get another company to come out and check the Furnace. The gas valve starts and stops the flow of gas to the burners and if the gas pressure is not correct, it could be overfiring the burners. So yes they are related. but this is the fault of the service company and if they make mistakes by installing the wrong gas valve then I would look for a differant company.
Nov 18, 2011 | Coleman Propane Forced Air Heater...
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
I have a 15 year old Coleman Propane 130,000 Btu force air furnace, Model #BGU13020 forced air furnace. Afer the unit runs for 5 to 10 minuets, the flame will start to shuter and then it will trip the heat...
DO NOT attempt to repair this yourself. LP gas is a very unforgiving gas. Sounds like your heat exchanger is plugged. Yes it can be removed and checked, BUT it is not recommended. Trust your local repair tech. Any heater 15+ years old should be discarded.
Dec 26, 2008 | Coleman Propane Forced Air Heater...
Coleman evcon furnace
is the air filter clean afc could be dirty
Dec 22, 2008 | Coleman Propane Forced Air Heater...
I have a Coleman/Evcon Presidential ser# 074878. The plumber says the Heat exchanger is cracked. Is this something I can fix myself or is it less expenxive to buy a new furnace?
The heat exchanger is a bear to change. depending on the age of the unit it might be more practical to replace the unit. However unless you trust this service tech I'd get a second opinion, because it is rare that a heat exchanger will crack, plus by law he or she should have shut the furnace down do to carbonminoxde. Especially rare in Coleman Evcon series units.
Oct 21, 2008 | Heating & Cooling
I need to find out what this furnaces tonnage is. Model #UGAB075BUH
Here is what I have
Evcon furnace
Gas
Single stage
80% efficiant
Upflow/horizontal
75,000 btu/h or 6.25 Ton heating capacity
3 Ton blower package
Jun 26, 2008 | Heating & Cooling
Heating & Cooling Logo
96 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
