Question about Neff B1691 Single circotherm super Stainless Steel Electric Oven
Temperature setting Temp dial has to be spun like a roulette wheel until the required temp shows up. A new control unit costs about 160 pounds plus taxes plus fitting charges etc. Is there any maintenance intervention that could solve the problem - eg WD 40 , cleaning of contacts ( if they can be accessed etc) The temperature set dial has to be moved clockwise and anti-clockwise in order to set the relevant setting (you need to have safe cracking skills) not that I have.. Is it possible to clean and refit the dial or is a replacement the only way to solve the problem??
    Sergeant:
    Champion:
  • 331 Answers
The temprature  dial is loose. which is quite clear
may be some  filling up will   do the job  but ..
if it does not work  u might  have to consider a replacement  i know it is a costly affair  but will have to  take it
try to  see if u can get a cheaper replacement  if it  is an old unit...
Posted on Oct 23, 2008
    Master:
  • 848 Answers
Try cleaning if that does not work you need to go for replacement .......
no other way........
regarding skills you should be very careful and taking all precautionary steps before cleaning.......
My kitchenaid works fine however I have hit something and when I press the bake button it shows 180 degrees instead of 350 all of a sudden. How do I reset it? I tried shutting off the breaker but that...
you neglected to mention the model this is , but most of the ovens made by them , when switched to bake , 1st show the temp you adjust then after thrirty seconds or so show the actual temp of oven (this number will change) the set temp function can be adjusted to anything in the ovens heat range 100-450) using the arrow keys anytime in the bake cycle , just touching a arrow key will change display to set temp screen , from actual temp display
Mar 07, 2015 | KitchenAid Ovens
Oven temperature on Neff 195305317 circotherm oven
hi remember that electric can kill you even if it is unplugged, if you don't know what components are likely to hold charge or have large inductance get someone else to fix it.
you need to get the service manual as tis will have fault finding charts, part numbers, location of sensors etc. If you can't get manual then:
Not likely to be temp limiter as this cuts out if temp is too hot. Find temp probe, may be ntc, mercury vapour switch etc. take probe out disconnect leads and measure resistance, heat, or cool, probe measure resistance if not significantly different (ie 10k to 100k or 100k to 300k) then probe is shot. Take probe to spares place, get replacement and refit. Be very careful to refit leads exactly as they came out, don't want insulation to melt and oven to become live. test with oven or meat thermometer as new sensor may need calibration. Should be accurate to within 10C or so
hope this helps
Nov 10, 2012 | Neff Ovens
Hotpoint ew81n cooker. Non working oven thermostat has been replaced. The cooker temperature is hotter than the dial reading. What can I adjust to make them the same?
Hi.
Unfortunately, the oven thermostat is non adjustable.
However, it is normal for oven temperatures to vary by + or - 10% of the setting.
This is acceptable, so to compensate, set the temp 10% less of the required temp setting.
Make sure you have the sensor fitted correctly inside the oven compartment
Make sure that the thermometer is accurate if you are checking the temperature with one.
Feb 23, 2011 | Hotpoint Ovens
When I start the self cleaning cycle After about 15 minutes it starts beeping and the display shows F5. The unit is about 10yrs old. What could this be?
This could a bad temperature sensor or a bad clock.(ERC).
Disconnect the power.
Remove the rear panel.
Unhook the temperature sensor wire and test the temp sensor with a volt/ohm meter set for ohms.
A plus/minus reading of 1100 ohms is good.
If temp sensor reads good replace the ERC(clock).
Nov 28, 2010 | Jenn-Air W30400P Stainless Steel Electric...
Oven tempeture lower than setting by 100 degrees on 350. even after pre-heat cycle. slightly more accurate at higher temps. i have a regular oven thermometer to check it. it was working well until...
Hey-  Let's fix this thing.  Several things can affect indicated/actual temperature.  The temp probe should test ok across it's lead wires at around 1100ohms. The computer usually shows a fault if the circuit is open, but won't show a code if it hasn't failed completely.  The next suspect is the igniter for the oven burner.  These can become weak with age, affecting gas flow to burner. Testing igniter is not really possible when it comes on and the part is usually replaced.  The regulator is next in line, occasionally causing variable flow to burner.  As you can see, quite a bit to consider.  On site diagnostics is usually required, but this gives you a start.  Installation instructions are available for all parts.     Please acknowledge this post if my info and time spent helps you.  Have more info if needed.  Thanks- Ed
Mar 26, 2010 | Electrolux Ovens
Our ARG7302WW range is missing the temperature sticker for the dial...where should 350 degrees be and does it go up in temp clockwise?
Hello- The background panel is screened with gradients, but is expensive and hard to find. The easiest solution is to purchase an oven thermometer and allow to set for about 20 min at an indicated 350deg. Make sure that dial knob is tight and mark with a line at that point. Use a fine point sharpy, and clean surface before marking. Turn off, let cool, and turn to the new 350 mark and see if temp comes up and matches 350deg on thermometer. If it works ok, try marking 325, 375, 400, etc. ---Yes,  Clockwise is up in temp. Let me know if this info helps.   Have more if needed-  Thanks - Ed
Mar 16, 2010 | Ovens
My hotpoint BD31 fan oven's temperature is about 30 degrees higher than the setting on the dial. What's the possible cause of this? Could it be that the fan mechanism isn't working?
If the fan was not working, then it would not get very hot at all as then fan forces the hot air around inside the oven.
Most manufactures allow a tolerance of plus or minus 10 degrees variation in temperature from the temp setting., so setting at 200 would give you 220 with 10 % plus, or 180 with 10 % minus, so yours is outside the acceptable range.
You can compensate by setting the thermostat 30 degees lower than normal, or the more expensive option, is to have a new thermostat fitted.
In my experience, compensating for the variation in temp, is a satisfactory solution.
However, if it gets worse, then your only course of action, is to replace the stat.
Trust this answers your question.
Nov 28, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Oven will not achieve setpoint temperature.
You may not need anything. Most people test their oven with a dial type oven thermometer. They are slow to react and often not very accurate. When I test an oven or install a new thermostat, I use a digital thermometer with a remote temperature probe, hanging from the center of the oven, which shows the temp in tenths of a degree. I let the oven cycle on and off at least three times, then take the high and lower readings on the next cycle and average that out to see what the actual oven temp is. Most of the time, if there is a dial type thermometer in the oven it is very slow to react. After 3 to 5 cycles, they often show close to what the actual oven temp is, but the only way to know for sure is to use the more accurate digital thermometer. Most ranges with digital displays can be adjusted + or - about 35 degrees. Check your users manual for this info, but don't mess with it until you have checked the oven with a digital thermometer! Please don't bother rating this solution, as anything but a Fix-Ya drops my score. Thanks.
Jan 08, 2009 | Amana Ovens
Neff B1691 Single circotherm super Stainless Steel Electric Oven Logo
134 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
