Question about George Foreman GR30CB Indoor Grill
Coating peeling The cooking surface is bubbling and starting to come off in some spots. I have only used a dishrag and the cleaning toool that came with the grille. Is there any way you can replace this grille?
  • 944 Answers
These guys supply all parts available http://www.esalton.com/control/contactus here is a link to the manual if you need it; http://www.esalton.com/static/manuals/GR30.pdf Hope this helps :)
Posted on Mar 27, 2007
My Scanpan wok has bubbled on the tatanium surface I now think it is not safe to use
not ideal
the flakes and scrapings of the pans coating
will end up in the cooked food
happenes with all non stick pan surfaces
using metal utensils , over heating . age of pan
Jan 13, 2017 | The Kitchen Appliances - Others
Paint bubbling and peeling soon after painting a newly rendered wall........how do we fix it?
Sorry for the paint peeling and bubbles. It's not the drywall tape that has bubbles... right? Paint can react like this when it is applied over a sanded wall that has not been cleaned and still has a layer of drywall dust on it. When primer is applied to the wall, it is best to use something to push the paint on the surface to combine the dust with the paint. This could be done using a paint pad but should be more than just rolled on. The paint needs to mix with the dust and stir it in with the paint so the paint get under the dust. You might try thinning the paint a little to allow for better attraction to the wall. So now how do you repair this? By scraping the loose paint off and starting with a new coat. You know. it could also just be bad paint.
Aug 02, 2014 | Drywall
Peeling nonstick coating
It can't be fixed. In the future, use only plastic cooking utensils so they won't scratch off the non stick coating. You can line the pan with foil if it is a baking pan, if it's a frying pan, there's no fixing it.
Apr 07, 2014 | KitchenAid 16-Inch by 13.5-Inch Roaster...
Hey, I was just wondering if there was anyway to fix damage done on the top of my board. On the top just right of my toe, their is a gash where the surface is pulled up but still connected. I called a...
Chips in any well used snowboard are inevitable, but you can prolong the life of the board by taking care if this right away. The best thing to do is to fix any spot that is peeling with epoxy. If the part that is peeling is large, it might be best to use a razor blade/xacto knife and cut it off around where it stops peeling. Make sure the area where the board is peeling is clean and completely dry. Then mix up some two-part epoxy; the 15 or 30 minute cure type which you can buy at any general store should be fine. Spread the epoxy evenly across the area where the peeling top layer meets the second layer beneath. If you left the part of the top layer that is peeling, spread epoxy in any crevices made by the two layers. Allow this to dry naturally (do NOT apply heat, as this could cause bubbling and make things worse). Once the epoxy dries, you can either let it be, or lightly file or sand any rough spots of epoxy. You then shouldn't have to worry about the peeling anymore.
Nov 29, 2010 | Burton Fix Snowboard
Need to repaint bubbled and peeling paint on top of dryer
The choice is yours. Money often motivates these decisions. If the model number you have this listed under is correct, the top panel price is roughly $108 to $160 depending on the color you need. White or Bisquit is the cheapest, while Pewter is the most expensive. If you wish to replace it, appliancepartspros.com carries it for the cheapest price.
If you wish to paint it, remove the panel from the dryer first by locating and removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off. This will allow you to work on it in a more convenient location and avoid any overspray from paint on your appliance. Make sure you clean the surface throughly to remove anything that may have caused the paint to bubble and peel in the first place (Ospho is commonly used to clean metal surfaces in preparation for painting - clean AFTER you sand). I would sand with a fine grit sand paper or emery cloth to ensure you don't leave any surface scratches. Prime the entire panel to provide a good surface for the new paint to adhere to. Once the primer is dry, apply a couple of good coats of appliance paint. If you have questions, please let me know. I hope this helps you.
Sep 06, 2009 | Whirlpool GEW9250 Electric Dryer
Teflon coating bubbling in spots
Sadly there's not much you can do here then. If it has started to bubble it only takes one swipe from a utensil to break it open and I had to get rid of my 12 year old tefal pot because of a very similar problem.
Teflon sprays exist on the market to spray light coatings on mechanics. However it is not fit for utensils or anything that may be consumed out of. You should just invest in a new set.
Please rate thanks.
Jul 24, 2009 | Kitchen Appliances - Others
I have several sandwich toasters but the Tefal coating keeps flaking off. I want the know where I can buy spray-on Tefal coating to re-cover the toasting surface?
Don't use the spray on teflon. It will kill you. It is used as an industrial coating but it isn't food grade. You would be safer, using wheel bearing grease to cook your food. The problem with nonstick cookware is, once it starts to break down, there's nothing you can do except either replace the item or scour it off and use a cooking spray.
Jun 28, 2009 | Breville Kitchen Appliances - Others
The nonstick coating is peeling
That has happened to me many times. You would think with the prices of kitchen cook ware that would last longer. I have turned a once nice pan that cost lots of bucks in to a camping pan. Sad ,but true but if you can find a can of spray on tephlon you can re coat the dish.Look in specialty hardware stores . Or you may be able to buy a can on line. The stuff is out there. good luck DFD please rate me TK U
Apr 11, 2009 | Cook's Essentials Cooks Essentials Dual...
Trying to find replacement parts for a george foreman grill
I haveproblem with grill surface bubbling/peeling. Where can I buy a replacement grill cooking surface in Area code 28739.
Thank you, Mr. W. Coddington
Apr 20, 2008 | George Foreman GGR50B Grill
Non-stick surface coming off
I find that in viewing this site that the listed " solution" is not a solution at all! This skillet has a defective design and coating and should be recalled!
Sep 03, 2007 | Rival S16RB Electric Skillet
George Foreman GR30CB Indoor Grill Logo
90 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
