WASHER DRYER WSM2700WWW
DRYER MAKES HIGH SQUELING PITCH SOUND ON OCCASION
  • 236 Answers
SOURCE: Stacked Washer/dryer
possible the bearings are going. place yor hand in the bottom of the drum and run the drum around and feel the bearings for any wear/ noise/vibration. alteratively the bearings in the motor could have gone and spinning with the belt removed would prove this.
Posted on Jan 20, 2008
  • 131 Answers
SOURCE: high pitch sound
This is the electronics whisteling. This is 'normal' on all electronically controlled machines. On some, it is louder than on others - even of the same model. As long as it continues to function properly, I wouldn't worry about it. If it's about to go out of warranty, you might try and see if the manufacturer will cover the replacement cost. But it's definitely not worth paying $300 to eliminate the whistle.
Posted on Mar 12, 2008
  • 3230 Answers
SOURCE: Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
good luck.....
Posted on Mar 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: my dryer makes this high pitch screaming
In the cradle where the center drum bearing fits is a plastic bearing mounted on a metal bracket. When that plastic bearing wears down the ball begins to contact the metal bracket. Bad things are ahead also. Because now as the drum turn the bracket is cutting into the ball.c44ef56.jpg
A typical Laundry center repair manual
Posted on Mar 12, 2010
SOURCE: Kenmore washer/dryer combo (Model# 41792702200)
I cannot remove the dryer drum from my Kenmore washer/dryer combo in order to remove the bearing, how do I do this???
Posted on Jun 05, 2010
Dryer makes a squeaking/high pitch rubbing noise
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
Apr 06, 2014 | GE DVLR223 Dryers
I replaced water inlet valve on a lg upright washer Now it makes a high pitch sound when filling like there is air in the line . D I need to bleed a line?
Have u fitted the right one it shud b cold blue 4 cold and hot red one,also some times with high water pressure if the valve is only open a little the pressure will mak a noise like air open valves fully
Oct 10, 2013 | Washing Machines
We have 98702. the dryer makes a loud rubbing, or knocking noise. at first listen, it sounds as if there were metal in the dryer rattling around. this is a steady noise. i am interested in fixing myself....
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 25, 2011 | Kenmore 98702 Stacked Washer/Dryer
On my 2000 Audi A4 1.8T when i am accelerating in the higher RPM aroung 4000 is when it starts. But their is a vary high pitch squeling noise i can hear.
Whining high pitched sound from front end...left front wheel bearing or right it could be hope this helps tell me if it does
Dec 03, 2010 | 2000 Audi A4
MATAG DRYER, MAKES A VERY LARGE HIGH PITCH SQUEEL
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 15, 2010 | Maytag Dryers
Won't spin, makes a high pitch sound
Check the pump for something caught in it,remove the pump be careful to look at how the belt goes on,use a large screw driver to see if the pump turns free in either direction.
Sep 21, 2009 | Maytag LSG7806A Front Load Stacked Washer...
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
TV HAS HIGH PITCH SOUNDS
most likely the HOT high voltage transformer is squeling
good luck
please mark the post with a fixya
Feb 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
